在线时间4063 小时
UID3441752
注册时间2017-11-21
NXP金币759412
TA的每日心情 | 开心 3 天前 |
签到天数: 266 天 [LV.8]以坛为家I
- 31909
- 2024-3-29
i.MX 8MM从SD卡启动失败MMC card init failed!
编译固件
- <font face="微软雅黑" size="3">bitbake -k core-image-minimal
- //编译出的固件
- core-image-minimal-imx8mmevk-20190508073946.rootfs.sdcard.bz2
- //压缩固件
- sudo bzip2 -d core-image-minimal-imx8mmevk.sdcard
- //得到固件
- core-image-minimal-imx8mmevk.sdcard
- //写入SD卡
- sudo dd if=imx8mmevk-avs-synaptics-1.9.sdcard of=/dev/sd<part> bs=1M && sync
- </font>
复制代码 1.第一次写入的SD卡为8GB/SanDisk , 提示如下,并没有成功启动
- <font face="微软雅黑" size="3">U-Boot 2018.03-imx_v2018.03_4.14.78_1.0.0_ga+g7ade5b4 (May 08 2019 - 08:18:47 +0000)
- CPU: Freescale i.MX8MMQ rev1.0 1800 MHz (running at 1200 MHz)
- CPU: Commercial temperature grade (0C to 95C) at 47C
- Reset cause: POR
- Model: FSL i.MX8MM EVK board
- DRAM: 2 GiB
- TCPC: Vendor ID [0x1fc9], Product ID [0x5110], Addr [I2C1 0x52]
- Power supply on USB2
- TCPC: Vendor ID [0x1fc9], Product ID [0x5110], Addr [I2C1 0x50]
- MMC: FSL_SDHC: 0, FSL_SDHC: 1
- // 这里提示错误
- Loading Environment from MMC... *** Warning - No block device, using default environment
- Failed (-5)
- No panel detected: default to MIPI2HDMI
- adv7535_init: Can't find device id=0x3d, on bus 1
- Display: MIPI2HDMI (1920x1080)
- Video: 1920x1080x24
- In: serial
- Out: serial
- Err: serial
- BuildInfo:
- - ATF d6451cc
- - U-Boot 2018.03-imx_v2018.03_4.14.78_1.0.0_ga+g7ade5b4
- flash target is MMC:0
- MMC card init failed!
- </font>
复制代码 2.第二次写入的SD卡为256Mb , 可以成功启动
- CPU: Commercial temperature grade (0C to 95C) at 50C
- Reset cause: POR
- DRAM: 2 GiB
- Loading Environment from MMC... *** Warning - bad CRC, using default environment
- Failed (-5)
- In: serial
- Out: serial
- Err: serial
- BuildInfo:
- - ATF d6451cc
- switch to partitions #0, OK
- mmc0 is current device
- Net:
- Warning: ethernet@30be0000 using MAC address from ROM
- eth0: ethernet@30be0000
- Fastboot: Normal
- Normal Boot
- Hit any key to stop autoboot: 0
- ** Unable to read file boot.scr **
- 23065088 bytes read in 1249 ms (17.6 MiB/s)
- Booting from mmc ...
- 43009 bytes read in 16 ms (2.6 MiB/s)
- ## Flattened Device Tree blob at 43000000
- Booting using the fdt blob at 0x43000000
- Using Device Tree in place at 0000000043000000, end 000000004300d800
- Starting kernel ...
- </font>
复制代码 结论
8GB/SanDisk的提示,应该有些SD卡识别不了导致
- <font face="微软雅黑" size="3">Loading Environment from MMC... *** Warning - No block device, using default environment
- </font>
文章出处:CSDN
