在线时间4067 小时
UID3441752
注册时间2017-11-21
NXP金币754068
签到天数: 266 天 [LV.8]以坛为家I
- 32023
- 2024-4-25
i.MX8M Mini 烧录固件
NXP i.MX8M Mini烧录固件的方式主要通过uuu工具进行烧录, 这个工具本身开源,但是提供给开发者烧录的方式及其不友好, 不得不吐槽。
烧录固件
如果没有uuu的文档,真心看不懂uuu.auto的语法。其中应该主要是为兼容Linux烧录,封装了fastboot协议而写的一套规则。
烧录固件 : uuu uuu.auto
- <font size="3" face="微软雅黑">uuu.auto
- uuu_version 1.0.1
- SDP: boot -f imx-boot-imx8mmevk-sd.bin-flash_evk
- # This command will be run when use SPL
- SDPU: delay 1000
- SDPU: write -f imx-boot-imx8mmevk-sd.bin-flash_evk -offset 0x57c00
- SDPU: jump
- # This command will be run when ROM support stream mode
- SDPS: boot -f imx-boot-imx8mmevk-sd.bin-flash_evk
- FB: ucmd setenv fastboot_dev mmc
- FB: ucmd setenv mmcdev ${emmc_dev}
- FB: ucmd mmc dev ${emmc_dev}
- #FB: flash -raw2sparse all sdcard.img
- FB: flash -raw2sparse all core-image-minimal-imx8mmevk-20190521120542.rootfs.sdcard
- FB: flash bootloader imx-boot-imx8mmevk-sd.bin-flash_evk
- FB: ucmd mmc partconf ${emmc_dev} 0 1 0
- FB: done
- </font>
复制代码 调试快速烧录
开发板开机进入uboot界面
- <font size="3" face="微软雅黑">fastboot ttyUSB1 (指定烧录口)</font>
复制代码 PC端通过uuu运行
- <font size="3" face="微软雅黑">uuu FB: flash -raw2sparse all sdcard.img`</font>
复制代码 系统分区
一般的系统分区可以通过dts中的参数配置,比如Amlogic A113X
- <font size="3" face="微软雅黑">// arch/arm64/boot/dts/amlogic/xxx.dts
- mtd_nand {
- compatible = "amlogic, aml_mtd_nand";
- dev_name = "mtdnand";
- status = "disable";
- reg = <0x0 0xFFE07800 0x0 0x200>;
- interrupts = < 0 34 1 >;
- pinctrl-names = "nand_rb_mod","nand_norb_mod", "nand_cs_only";
- pinctrl-0 = <&all_nand_pins>;
- pinctrl-1 = <&all_nand_pins>;
- pinctrl-2 = <&nand_cs_pins>;
- device_id = <0>;
- /*fip/tpl configurations, must be same
- * with uboot if bl_mode was set as 1
- * bl_mode: 0 compact mode; 1 descrete mode
- * if bl_mode was set as 1, fip configeration will work
- bl_mode = <1>;
- /*copy count of fip*/
- fip_copies = <4>;
- /*size of each fip copy */
- fip_size = <0x200000>;
- nand_clk_ctrl = <0xFFE07000>;
- plat-names = "bootloader","nandnormal";
- plat-num = <2>;
- plat-part-0 = <&bootloader>;
- plat-part-1 = <&nandnormal>;
- bootloader: bootloader{
- enable_pad ="ce0";
- busy_pad = "rb0";
- timming_mode = "mode5";
- bch_mode = "bch8_1k";
- t_rea = <20>;
- t_rhoh = <15>;
- chip_num = <1>;
- part_num = <0>;
- rb_detect = <1>;
- nandnormal: nandnormal{
- busy_pad = "rb0";
- plane_mode = "twoplane";
- t_rea = <20>;
- t_rhoh = <15>;
- chip_num = <2>;
- part_num = <3>;
- partition = <&nand_partitions>;
- rb_detect = <1>;
- nand_partitions:nand_partition{
- * if bl_mode is 1, tpl size was generate by
- * fip_copies * fip_size which
- * will not skip bad when calculating
- * the partition size;
- * if bl_mode is 0,
- * tpl partition must be comment out.
- tpl{
- offset=<0x0 0x0>;
- size=<0x0 0x0>;
- logo{
- offset=<0x0 0x0>;
- size=<0x0 0x200000>;
- recovery{
- offset=<0x0 0x0>;
- size=<0x0 0x1000000>;
- boot{
- offset=<0x0 0x0>;
- size=<0x0 0xF00000>;
- system{
- offset=<0x0 0x0>;
- size=<0x0 0x82000000>;
- </font>
复制代码 而针对NXP i.MX8M Mini这边,并没有提供DTS的配置方式,而是通过uuu工具来实现的。官方资料中提供了kernel_emmc.uuu参考例子。
- <font size="3" face="微软雅黑">// create partition
- FBK: ucmd mmc=`cat /tmp/mmcdev`; PARTSTR=[font=微软雅黑][size=3]
- [/size][/font]
- [font=微软雅黑][size=3]
- [/size][/font]
- [/size][/font]
- [/size][/font]
- [font=微软雅黑][size=3]文章出处:CSDN[/size][/font]
- [/size][/font]
- [/size][/font]
- [/size][/font]
- 10M,500M,0c\n600M,,83\n'; echo "$PARTSTR" | sfdisk --force /dev/mmcblk${mmc}</font>
文章出处:CSDN
