在线时间46 小时
UID2094162
注册时间2017-8-7
NXP金币0
TA的每日心情 | 擦汗 2020-1-10 11:05 |
签到天数: 13 天 连续签到: 1 天 [LV.3]偶尔看看II
- 382
- 2020-11-12
使用 驱动位于:rtthread-rt-thread-v4.0.2\rt-thread\bsp\imxrt\libraries\drivers\drv_eth.c ,
在此基础上添加了引脚初始化。
IOMUXC_SetPinMux(IOMUXC_GPIO_AD_B0_09_GPIO1_IO09, 0U);
IOMUXC_SetPinMux(IOMUXC_GPIO_AD_B0_10_GPIO1_IO10, 0U);
IOMUXC_SetPinMux(IOMUXC_GPIO_B1_04_ENET_RX_DATA00, 0U);
IOMUXC_SetPinMux(IOMUXC_GPIO_B1_05_ENET_RX_DATA01, 0U);
IOMUXC_SetPinMux(IOMUXC_GPIO_B1_06_ENET_RX_EN, 0U);
IOMUXC_SetPinMux(IOMUXC_GPIO_B1_07_ENET_TX_DATA00, 0U);
IOMUXC_SetPinMux(IOMUXC_GPIO_B1_08_ENET_TX_DATA01, 0U);
IOMUXC_SetPinMux(IOMUXC_GPIO_B1_09_ENET_TX_EN, 0U);
IOMUXC_SetPinMux(IOMUXC_GPIO_B1_10_ENET_REF_CLK, 1U);
IOMUXC_SetPinMux(IOMUXC_GPIO_B1_11_ENET_RX_ER, 0U);
IOMUXC_SetPinMux(IOMUXC_GPIO_AD_B1_04_ENET_MDC, 0U);
IOMUXC_SetPinMux(IOMUXC_GPIO_B1_15_ENET_MDIO, 0U);
IOMUXC_SetPinConfig(IOMUXC_GPIO_AD_B0_09_GPIO1_IO09, 0xB0E9U);
IOMUXC_SetPinConfig(IOMUXC_GPIO_AD_B0_10_GPIO1_IO10, 0xB0E9U);
IOMUXC_SetPinConfig(IOMUXC_GPIO_B1_04_ENET_RX_DATA00, 0xB0E9U);
IOMUXC_SetPinConfig(IOMUXC_GPIO_B1_05_ENET_RX_DATA01, 0xB0E9U);
IOMUXC_SetPinConfig(IOMUXC_GPIO_B1_06_ENET_RX_EN, 0xB0E9U);
IOMUXC_SetPinConfig(IOMUXC_GPIO_B1_07_ENET_TX_DATA00, 0xB0E9U);
IOMUXC_SetPinConfig(IOMUXC_GPIO_B1_08_ENET_TX_DATA01, 0xB0E9U);
IOMUXC_SetPinConfig(IOMUXC_GPIO_B1_09_ENET_TX_EN, 0xB0E9U);
IOMUXC_SetPinConfig(IOMUXC_GPIO_B1_10_ENET_REF_CLK, 0x31U);
IOMUXC_SetPinConfig(IOMUXC_GPIO_B1_11_ENET_RX_ER, 0xB0E9U);
IOMUXC_SetPinConfig(IOMUXC_GPIO_AD_B1_04_ENET_MDC, 0xB0E9U);
IOMUXC_SetPinConfig(IOMUXC_GPIO_B1_15_ENET_MDIO, 0xB829u);
static void imxrt_enet_phy_reset_by_gpio(void)
gpio_pin_config_t gpio_config = {kGPIO_DigitalOutput, 0, kGPIO_NoIntmode};
GPIO_PinInit(GPIO1, 9, &gpio_config);
GPIO_PinInit(GPIO1, 10, &gpio_config);
/* pull up the ENET_INT before RESET. */
GPIO_WritePinOutput(GPIO1, 10, 1);
GPIO_WritePinOutput(GPIO1, 9, 0);
rt_thread_delay(100);
GPIO_WritePinOutput(GPIO1, 9, 1);
相关初始化:
/* Get default configuration. */
* config.miiMode = kENET_RmiiMode;
* config.miiSpeed = kENET_MiiSpeed100M;
* config.miiDuplex = kENET_MiiFullDuplex;
* config.rxMaxFrameLen = ENET_FRAME_MAX_FRAMELEN;
ENET_GetDefaultConfig(&config);
config.interrupt = kENET_TxFrameInterrupt | kENET_RxFrameInterrupt;
config.miiSpeed = imxrt_eth_device.speed;
config.miiDuplex = imxrt_eth_device.duplex;
/* Set SMI to get PHY link status. */
sysClock = CLOCK_GetFreq(kCLOCK_AhbClk);
dbg_log(DBG_LOG, "deinit\n");
ENET_Deinit(imxrt_eth_device.enet_base);
dbg_log(DBG_LOG, "init\n");
ENET_Init(imxrt_eth_device.enet_base, &imxrt_eth_device.enet_handle, &config, &buffConfig, &imxrt_eth_device.dev_addr[0], sysClock);
dbg_log(DBG_LOG, "set call back\n");
ENET_SetCallback(&imxrt_eth_device.enet_handle, _enet_callback, &imxrt_eth_device);
dbg_log(DBG_LOG, "active read\n");
ENET_ActiveRead(imxrt_eth_device.enet_base);
现象:
能正常读写PHY芯片数据,以太网发送数据时,无法进入发送事件中断回调函数?
查看到配置的PLL Enet Freq = 50000000
