查看: 1211|回复: 2
【2020年度庆典二】NXP 社区越办越好
    郁闷
    2021-8-25 16:50
  • 签到天数: 57 天
    发表于 2021-1-5 16:08:59 | 显示全部楼层 |阅读模式
    NXP 产品牛X!
    祝 NXP 社区越办越好!
    签到
    郁闷
    2021-8-25 16:50
  • 签到天数: 57 天
     楼主| 发表于 2021-1-5 16:16:15 | 显示全部楼层
    * Copyright 2017-2019 NXP
    * All rights reserved.
    * SPDX-License-Identifier: BSD-3-Clause
    #include <stdio.h>
    #include <string.h>
    #include "fsl_common.h"
    #include "fsl_debug_console.h"
    #include "fsl_cache.h"
    #include "ff.h"
    #include "diskio.h"
    #include "fsl_sd_disk.h"
    #include "jpeglib.h"
    #include "display_support.h"
    #include "board.h"
    #include "sdmmc_config.h"
    #include "pin_mux.h"
    #include "fsl_gpio.h"
    #include "clock_config.h"
    * Definitions
    #define APP_FB_HEIGHT  DEMO_BUFFER_HEIGHT
    #define APP_FB_WIDTH   DEMO_BUFFER_WIDTH
    #define APP_FB_START_X DEMO_BUFFER_START_X
    #define APP_FB_START_Y DEMO_BUFFER_START_Y
    * For better performance, by default, three frame buffers are used in this demo.
    * If the memory region is not large enough, user can define to 2 to override
    * this value.
    #ifndef APP_FB_NUM
    #define APP_FB_NUM 3 /* LCD frame buffer number. */
    #endif
    /* Use RGB888 format by default, for some display controllers don't support
    * RGB888, use XRGB8888
    #ifndef APP_USE_XRGB8888
    #define APP_USE_XRGB8888 0
    #endif
    #if APP_USE_XRGB8888
    #define APP_FB_BPP    4 /* LCD frame buffer byte per pixel, XRGB888 format, 32-bit. */
    #define APP_FB_FORMAT kVIDEO_PixelFormatXRGB8888
    #else
    #define APP_FB_BPP    3 /* LCD frame buffer byte per pixel, RGB888 format, 24-bit. */
    #define APP_FB_FORMAT kVIDEO_PixelFormatRGB888
    #endif
    /* Cache line size. */
    #ifndef FSL_FEATURE_L2CACHE_LINESIZE_BYTE
    #define FSL_FEATURE_L2CACHE_LINESIZE_BYTE 0
    #endif
    #ifndef FSL_FEATURE_L1DCACHE_LINESIZE_BYTE
    #define FSL_FEATURE_L1DCACHE_LINESIZE_BYTE 0
    #endif
    #if (FSL_FEATURE_L2CACHE_LINESIZE_BYTE > FSL_FEATURE_L1DCACHE_LINESIZE_BYTE)
    #define APP_CACHE_LINE_SIZE FSL_FEATURE_L2CACHE_LINESIZE_BYTE
    #else
    #define APP_CACHE_LINE_SIZE FSL_FEATURE_L1DCACHE_LINESIZE_BYTE
    #endif
    * For better performance, the frame buffers are located in cachable region and
    * the cache line maintanance is handled in this demo. The start address of
    * frame buffer, and the size of frame buffer, are aligned to the cache line
    * size.
    #ifndef APP_FB_ALIGN
    #if (APP_CACHE_LINE_SIZE > 0)
    #define APP_FB_ALIGN APP_CACHE_LINE_SIZE
    #else
    #define APP_FB_ALIGN 1
    #endif
    #endif /* APP_FB_ALIGN */
    #ifndef APP_FB_STRIDE_BYTE
    #define APP_FB_STRIDE_BYTE (APP_FB_WIDTH * APP_FB_BPP)
    #endif
    #define APP_FB_SIZE_BYTE (SDK_SIZEALIGN(APP_FB_STRIDE_BYTE * APP_FB_HEIGHT, APP_FB_ALIGN))
    #ifndef APP_FB_USE_FIXED_ADDRESS
    #define APP_FB_USE_FIXED_ADDRESS 0
    #endif
    * Prototypes
    static status_t sdcardWaitCardInsert(void);
    static void APP_BufferSwitchOffCallback(void *param, void *switchOffBuffer);
    * Variables
    static dc_fb_info_t fbInfo;
    * When new frame buffer sent to display, it might not be shown immediately.
    * Application could use callback to get new frame shown notification, at the
    * same time, when this flag is set, application could write to the older
    * frame buffer.
    static volatile bool s_newFrameShown = false;
    static void *volatile s_fbList       = NULL; /* List to the frame buffers. */
    /* This struct contains the JPEG decompression parameters */
    static struct jpeg_decompress_struct cinfo;
    /* This struct represents a JPEG error handler */
    static struct jpeg_error_mgr jerr;
    #if APP_FB_USE_FIXED_ADDRESS
    static void *g_frameBuffer[APP_FB_NUM] = {
        (void *)APP_FB0_ADDR,
    #if (APP_FB_NUM > 1)
        (void *)APP_FB1_ADDR,
    #endif
    #if (APP_FB_NUM > 2)
        (void *)APP_FB2_ADDR,
    #endif
    #else
    SDK_ALIGN(static uint8_t g_frameBuffer[APP_FB_NUM][APP_FB_SIZE_BYTE], APP_FB_ALIGN);
    #endif
    AT_NONCACHEABLE_SECTION(static FATFS g_fileSystem); /* File system object */
    AT_NONCACHEABLE_SECTION(static FIL jpgFil);
    * Code
    /* Get the empty frame buffer from the s_fbList. */
    static void *APP_GetFrameBuffer(void)
        void *fb;
        fb = s_fbList;
        if (NULL != fb)
            s_fbList = *(void **)fb;
        return fb;
    /* Put the unused frame buffer to the s_fbList. */
    static void APP_PutFrameBuffer(void *fb)
        *(void **)fb = s_fbList;
        s_fbList     = fb;
    * @brief  Jpeg Decode
    * @param  file:    pointer to the jpg file
    * @param  buff:     pointer to the image line
    void jpeg_decode(FIL *file, uint8_t *buffer)
        uint8_t *jpg_buffer;
        uint8_t *jpg_buffer_aligned;
        uint8_t *read_pos;
        UINT jpg_size;
        UINT bytesRead;
        UINT bytesRemain;
        // Decode JPEG Image
        JSAMPROW row_pointer[1] = {0}; /* Output row buffer */
        uint32_t row_stride     = 0;   /* physical row width in image buffer */
        // Step 1: allocate and initialize JPEG decompression object
        cinfo.err = jpeg_std_error(&jerr);
        // Step 2: Initialize the JPEG decompression object
        jpeg_create_decompress(&cinfo);
        jpg_size = f_size(file);
        jpg_buffer = (unsigned char *)malloc(jpg_size + 2 * APP_CACHE_LINE_SIZE);
        if (jpg_buffer == NULL)
            PRINTF("Error: memory allocation error\r\n");
            assert(false);
    #if APP_CACHE_LINE_SIZE
        jpg_buffer_aligned = (void *)(SDK_SIZEALIGN((uint32_t)jpg_buffer, APP_CACHE_LINE_SIZE));
    #else
        jpg_buffer_aligned = jpg_buffer;
    #endif
        bytesRemain = jpg_size;
        read_pos    = jpg_buffer_aligned;
        DCACHE_CleanInvalidateByRange((uint32_t)jpg_buffer_aligned, jpg_size);
        while (bytesRemain > 0)
            f_read(file, read_pos, bytesRemain, &bytesRead);
            bytesRemain -= bytesRead;
            read_pos += bytesRead;
        jpeg_mem_src(&cinfo, jpg_buffer_aligned, jpg_size);
        // Step 3: read image parameters with jpeg_read_header()
        jpeg_read_header(&cinfo, true);
        // Step 4: set parameters for decompression
        cinfo.dct_method = JDCT_FLOAT;
         * Resize to fit the screen, the actual resize rate is:
         * cinfo.scale_num / 8, the cinfo.scale_num must be in the range of 1 ~ 16
        if ((cinfo.image_width * APP_FB_HEIGHT) > (cinfo.image_height * APP_FB_WIDTH))
            cinfo.scale_num = APP_FB_WIDTH * 8 / cinfo.image_width;
        else
            cinfo.scale_num = APP_FB_HEIGHT * 8 / cinfo.image_height;
        if (cinfo.scale_num < 1)
            cinfo.scale_num = 1;
        else if (cinfo.scale_num > 16)
            cinfo.scale_num = 16;
        // Step 5: start decompressor
        jpeg_start_decompress(&cinfo);
        row_stride = APP_FB_STRIDE_BYTE;
        /* Place the output image to the center of the screen. */
        buffer += row_stride * ((APP_FB_HEIGHT - cinfo.output_height) / 2);
        buffer += APP_FB_BPP * ((APP_FB_WIDTH - cinfo.output_width) / 2);
        while (cinfo.output_scanline < cinfo.output_height)
            row_pointer[0] = &buffer[cinfo.output_scanline * row_stride];
            jpeg_read_scanlines(&cinfo, row_pointer, 1);
        // Step 6: Finish decompression
        jpeg_finish_decompress(&cinfo);
        // Step 7: Release JPEG decompression object
        jpeg_destroy_decompress(&cinfo);
        free(jpg_buffer);
    static int MOUNT_SDCard(void)
        FRESULT error;
        const TCHAR driverName[3U] = {SDDISK + '0', ':', '/'};
        // clear FATFS manually
        memset((void *)&g_fileSystem, 0, sizeof(g_fileSystem));
        /* Wait for the card insert. */
        if (sdcardWaitCardInsert() != kStatus_Success)
            PRINTF("Card not inserted.\r\n");
            return -1;
        // Mount the driver
        if (f_mount(&g_fileSystem, driverName, 0))
            PRINTF("Mount volume failed.\r\n");
            return -2;
    #if (FF_FS_RPATH >= 2U)
        if (f_chdrive((char const *)&driverName[0U]))
            PRINTF("Change drive failed.\r\n");
            return -3;
    #endif
        // Open file to check
        error = f_open(&jpgFil, _T("/000.jpg"), FA_OPEN_EXISTING);
        if (error != FR_OK)
            PRINTF("No demo jpeg file!\r\n");
            return -4;
        f_close(&jpgFil);
        return 0;
    void APP_InitDisplay(void)
        uint8_t i;
        void *freeFb;
        status_t status;
        for (i = 0; i < APP_FB_NUM; i++)
            memset(g_frameBuffer[i], 0, APP_FB_SIZE_BYTE);
            APP_PutFrameBuffer(g_frameBuffer[i]);
        BOARD_PrepareDisplayController();
        status = g_dc.ops->init(&g_dc);
        if (kStatus_Success != status)
            PRINTF("Display initialization failed\r\n");
            assert(false);
        g_dc.ops->getLayerDefaultConfig(&g_dc, 0, &fbInfo);
        fbInfo.pixelFormat = APP_FB_FORMAT;
        fbInfo.width       = APP_FB_WIDTH;
        fbInfo.height      = APP_FB_HEIGHT;
        fbInfo.startX      = APP_FB_START_X;
        fbInfo.startY      = APP_FB_START_Y;
        fbInfo.strideBytes = APP_FB_STRIDE_BYTE;
        if (kStatus_Success != g_dc.ops->setLayerConfig(&g_dc, 0, &fbInfo))
            PRINTF("Error: Could not configure the display controller\r\n");
            assert(false);
        g_dc.ops->setCallback(&g_dc, 0, APP_BufferSwitchOffCallback, NULL);
        /* Get the first frame buffer and send to display controller. */
        freeFb = APP_GetFrameBuffer();
        if (freeFb == NULL)
            PRINTF("Error: Could not get frame buffer\r\n");
            assert(false);
        memset(freeFb, 0, APP_FB_SIZE_BYTE);
        g_dc.ops->setFrameBuffer(&g_dc, 0, freeFb);
        /* For the DBI interface display, application must wait for the first
         * frame buffer sent to the panel.
        if ((g_dc.ops->getProperty(&g_dc) & kDC_FB_ReserveFrameBuffer) == 0)
            while (s_newFrameShown == false)
        s_newFrameShown = true;
        g_dc.ops->enableLayer(&g_dc, 0);
    * @brief Main function
    int main(void)
        int i = 0;
        FRESULT error;
        char jpgFileName[10];
        void *freeFb;
        uint32_t oldIntStat;
        BOARD_ConfigMPU();
        BOARD_InitPins();
        BOARD_BootClockRUN();
        BOARD_InitDebugConsole();
        PRINTF("SD JPEG demo start:\r\n");
        APP_InitDisplay();
        // Init the SD card
        if (0 != MOUNT_SDCard())
            PRINTF("SD card mount error. Demo stopped!");
            return -1;
        while (1)
            // format the filename
            sprintf(jpgFileName, "/%03d.jpg", i++);
            // open it
            error = f_open(&jpgFil, jpgFileName, FA_READ);
            if (error != FR_OK)
                i = 0;
                continue;
            /* Get free frame buffer and convert the jpeg output to it. */
            do
                oldIntStat = DisableGlobalIRQ();
                EnableGlobalIRQ(oldIntStat);
            } while (NULL == freeFb);
            PRINTF("Decoding %s...", jpgFileName);
            jpeg_decode(&jpgFil, freeFb);
            PRINTF("done!\r\n", jpgFileName);
            f_close(&jpgFil);
            DCACHE_CleanInvalidateByRange((uint32_t)freeFb, APP_FB_SIZE_BYTE);
             * Wait for the previous set frame buffer active.
            /* Now new frame is ready, pass it to LCDIF. */
        BOARD_SD_Config(&g_sd, NULL, BOARD_SDMMC_SD_HOST_IRQ_PRIORITY, NULL);
        /* SD host init function */
        if (SD_HostInit(&g_sd) != kStatus_Success)
            PRINTF("\r\nSD host init fail\r\n");
            return kStatus_Fail;
        /* power off card */
        SD_SetCardPower(&g_sd, false);
        /* wait card insert */
        if (SD_PollingCardInsert(&g_sd, kSD_Inserted) == kStatus_Success)
            PRINTF("\r\nCard inserted.\r\n");
            /* power on the card */
            SD_SetCardPower(&g_sd, true);
        else
            PRINTF("\r\nCard detect fail.\r\n");
        return kStatus_Success;
        APP_PutFrameBuffer(switchOffBuffer);
    //代码补在这里了
    //SDK路径是:SDK_2.8.6_EVK-MIMXRT1064\boards\evkmimxrt1064\jpeg_examples\sd_jpeg\mdk
    签到
  • 签到天数: 266 天
    发表于 2021-1-8 09:25:45 | 显示全部楼层
    感谢分享
    签到签到
    GMT+8, 2024-5-12 23:45 , Processed in 0.103838 second(s), 20 queries , MemCache On.
