查看: 487|回复: 0
MCU 开发常用缩略语整理
    5 天前
  • 签到天数: 597 天
    发表于 2023-4-19 19:58:19 | 显示全部楼层 |阅读模式
    缩略语 定义
    ECC 纠错码
    CPU 中央处理单元(MCU的一部分)
    CRC Cyclic Redundancy Check 循环冗余校验
    DED 双重错误检测
    SEC 单错误校正
    DTCM 数据紧耦合存储器
    ITCM 指令紧耦合存储器
    ISR 中断服务程序
    MCU 微控制器单元
    MDMA 主存储器直接存取
    POR 上电复位
    RAM 随机存取存储器
    SRAM 静态 RAM
    RWW 同时读写(Read While Write)
    DFT Design For Test
    I2CInter Integrated Circuit
    SPISerial Peripheral interface
    I3CImproved Inter Integrated Circuit
    SMP 对称多处理器(Symmetrical Multi-Processing)
    SDR 单数据速率(Single Data Rate )
    DDR 双倍数据速率(Double Data Rate )
    RDP Read Protection
    WDP Write Protection
    PPC Peripheral access Permisson Controller
    LDO Low Dropout Regulator(低压差线性稳压器)
    ISP In-System Programming: In-System programming (ISP) is programming or reprogramming the on-chip flash memory, using the boot loader software and USART, I2C, or SPI serial port. This can be done when the part resides in the end-user board.
    IAP In Application Programming: In-Application (IAP) programming is performing erase and write operation on the on-chip flash memory, as directed by the end-user application code.
    RCG Reference Clock Generator
    ISA Instruction Set Architecture(指令集体系结构)
    CSR Control and Status Register
    Pipeline Flush 流水线冲刷
    IF Instruction Fetch 指令取指
    ID Instruction Dcode 指令译码
    BPU breakpoint unit (BPU)
    RAS Return Address Stack
    RISCReduced Instruction Set Computer
    CISCComplex Instruction Set Computer
    OTPOne-Time Programmable (OTP) ROM
    Idiom RecognitionIdiom Recognition
    DMIPSDhrystone Million Instructions executed Per Second
    IPS Instructions executed Per Second
    MIPS Million Instructions executed Per Second
    RAWread-after-write
    ESDElectro-Static discharge
    Tsu建立时间(Tsu:set up time)
    Th保持时间(Th:hold time)
    MPCMemory Protection Controller (MPC)
    PPCPeripheral Protection Controller (PPC)
    BOD Brown-out detect
    JTAG Joint Test Action Group
    SWD Serial Wire Debug
    DUT Device Under Test(被测设备)
    PIC, PID Position-independent code, position-independent data.
    DDF IAR device description file format
    SFE  section end
    DCD  Device Configuration Data
    XIP  Excute In Place
    GMT+8, 2024-5-6 08:33 , Processed in 0.093661 second(s), 18 queries , MemCache On.
