楼主: gunslinger
[S12] P&E USBMULTILINK 不能调试MC9S12XET256吗?
发表于 2014-6-18 22:24:31 | 显示全部楼层 |阅读模式
使用这个仿真器对MC9S12XET256好像不好使啊!!调试时会出现“
executing C_layout.hwl
!OPEN source 0 0 60 39
NO CONNECTION
!Source < attributes MARKS off
!OPEN assembly 60 0 40 31
!Assembly < attributes ADR on,CODE off,ABSADR on,SYMB off,TOPPC 0xF88C
!OPEN procedure 0 39 60 17
!Procedure < attributes VALUES on,TYPES off
!OPEN register 60 31 40 25
!Register < attributes FORMAT AUTO,COMPLEMENT None
!OPEN memory 60 56 40 22
!Memory < attributes FORMAT hex,COMPLEMENT None,WORD 1,ASC on,ADR on,ADDRESS 0x80
!OPEN data 0 56 60 22
!Data:1 < attributes SCOPE global,COMPLEMENT None,FORMAT Symb,MODE automatic,UPDATERATE 10,NAMEWIDTH 16
!OPEN data 0 78 60 22
!Data:2 < attributes SCOPE local,COMPLEMENT None,FORMAT Symb,MODE automatic,UPDATERATE 10,NAMEWIDTH 16
!OPEN command 60 78 40 22
!Command < attributes CACHESIZE 1000
!bckcolor 50331647
!font 'Courier New' 9 BLACK
!AUTOSIZE on
!ACTIVATE Data:2 Command Procedure Data:1 Source Register Assembly Memory
done C_layout.hwl
Loading Target ...
IO registers loaded for MC9S12XET256 from E:\FreeScale\IDE\prog\REG\MCU02DC.REG
USB HCS08/HCS12 MULTILINK detected - Flash Version 5.83
Speed test (ESC to abort) ...
done.
Could not find appropriate io_delay_cnt.
executing .\cmd\P&E_Multilink_USB_startup.cmd
!// At startup the commands written below will be executed
Target Ready
done .\cmd\P&E_Multilink_USB_startup.cmd
Startup command file correctly executed.
executing .\cmd\P&E_Multilink_USB_preload.cmd
!// Before load the commands written below will be executed
RUNNING
done .\cmd\P&E_Multilink_USB_preload.cmd
Preload command file correctly executed.
FP: FLASH parameters loaded for MC9S12XET256_V1(NVMIF2 rev 1,1,1,1,1) from E:\FreeScale\IDE\prog\FPP\mcu02DC.fpp
done.
executing .\cmd\P&E_Multilink_USB_postload.cmd
!// After load the commands written below will be executed
done .\cmd\P&E_Multilink_USB_postload.cmd
Postload command file correctly executed.
main 0xFE8044'L T
RUNNING ALREADY
有人遇到同样的问题吗?
我知道答案 目前已有9人回答
 楼主| 发表于 2014-6-18 22:27:05 | 显示全部楼层
回复:P&E USBMULTILINK 不能调试MC9S12XET256吗?
会出现这个对话框。
发表于 2014-6-19 14:33:21 | 显示全部楼层
RE:P&E USBMULTILINK 不能调试MC9S12XET256吗?
你看看USBMULTILINK支持的芯片里有没有你这个16位的芯片呢,如果没有肯定是不支持的。我帮你看看啊,马上回复你。
发表于 2014-6-19 14:38:17 | 显示全部楼层
USB multilink有好多呢,你是哪种啊:
[url=https://www.freescale.co
m/zh-Hans/webapp/sps/site/prod_summary.jsp?code=S12XE&fpsp=1&tab=Design_Tools_Tab]https://www.freescale.co
m/zh-Hans/webapp/sps/site/prod_summary.jsp?code=S12XE&fpsp=1&tab=Design_Tools_Tab[/url]
点进去看看有没有你的芯片就知道了。
 楼主| 发表于 2014-6-20 00:36:08 | 显示全部楼层
 谢谢你的热心,我用的是这个仿真器:看说明支持HC(S)12(X)啊,不知为什么不行?
 楼主| 发表于 2014-6-20 16:46:19 | 显示全部楼层
unsecure12_install.exe
谁有这个软件共享下吧,网上找不到啊,官网下不了!!!
发表于 2014-6-23 13:31:20 | 显示全部楼层
你这个调试器的确是支持的。
你MCU的板子有没有问题啊,不一定就是仿真器的问题呢。
你板子之前能下程序吗?
发表于 2014-6-23 13:44:17 | 显示全部楼层
unsecure12_install.exe这个要到PE的官网找,但是他们的搜索是基于google的,所以貌似不好用。
发表于 2014-6-24 16:17:18 | 显示全部楼层
楼主查查链接线把,还有你之前的板子好不好用啊?是自己画的吗?
查看一下接口设计对不对啊。
发表于 2014-6-26 12:02:31 | 显示全部楼层
回复第 2 楼 于2014-06-18 22:27:05发表:
会出现这个对话框。
与目标设备通信失败。
目标MCU没有时钟 或 BDM的时钟设置有问题 或 锁了。
还是检查一下硬件吧。
GMT+8, 2025-10-31 05:50 , Processed in 0.119979 second(s), 30 queries , MemCache On.
