查看: 24354|回复: 14
[分享] 【经验分享】飞思卡尔IMX6处理器的GPIO配置方式
发表于 2014-6-24 09:21:20 | 显示全部楼层 |阅读模式
在linux或android系统中,假如我们要配置飞思卡尔IMX6处理器的GPIO管脚,比如是GPIO_19这个管脚,那么要像这样:
#define MX6Q_PAD_GPIO_19__GPIO_4_5                              \
                                (_MX6Q_PAD_GPIO_19__GPIO_4_5| MUX_PAD_CTRL(NO_PAD_CTRL))
其中_MX6Q_PAD_GPIO_19__GPIO_4_5定义为:
  #define _MX6Q_PAD_GPIO_19__GPIO_4_5         \
         IOMUX_PAD(0x0624, 0x0254, 5, 0x0000, 0, 0)
这个IOMUX_PAD宏是定义GPIO的关键宏,其原型为:
#define IOMUX_PAD(_pad_ctrl_ofs, _mux_ctrl_ofs, _mux_mode, _sel_input_ofs,
       _sel_input, _pad_ctrl)
IOMUX_PAD宏有6个参数,每个参数的意思是:
参数
含义
_pad_ctrl_ofs
控制寄存器的偏移地址(16进制)
_mux_ctrl_ofs
MUX控制寄存器的偏移地址(16进制), 用于选择引脚的功能
_mux_mode
MUX模式,bit0~3,范围0~7
_select_input_ofs
SELECT_INPUT寄存器偏移地址(16进制)
_select_input
Daisy Chain模式, bit0~1,范围0~3
_pad_ctrl
bits to be set in register _pad_ctrl_ofs for  configuration selection
具体的含义要结合IMX6数据手册【Chapter 36 IMOUX Controller(IOMUXC)】的内容。
以下就GPIO_19这个管脚的配置进行说明:
1_pad_ctrl_ofs
找到数据手册:
从上图可知:_pad_ctrl_ofs = 0x624
2_mux_ctrl_ofs_mux_mode
找到数据手册的内容:
如上图,_mux_ctrl_ofs取值为0x254,_mux_mode范围为000~110
只有_mux_mode = 0时,_select_input_ofs和_select_input才有效,其余时候_select_input_ofs和_select_input 都为0。
3_select_input_of_select_input
当_mux_mode = 0时,_select_input_ofs的取值需参考数据手册:
(由于论坛中发帖限制,这里附件只能放三个,所以详细内容参考附件文档。)
此时_select_input_ofs=0x8e8,_select_input=0x1
4_pad_ctrl
_pad_ctrl一般取值为0
综上所述,GPIO_19的配置宏定义如下:
  #define _MX6Q_PAD_GPIO_19__KPP_COL_5            \
         IOMUX_PAD(0x0624, 0x0254, 0, 0x08E8, 1, 0)
#define _MX6Q_PAD_GPIO_19__ENET_1588_EVENT0_OUT     \
         IOMUX_PAD(0x0624, 0x0254, 1, 0x0000, 0, 0)
  #define _MX6Q_PAD_GPIO_19__SPDIF_OUT1           \
         IOMUX_PAD(0x0624, 0x0254, 2, 0x0000, 0, 0)
  #define _MX6Q_PAD_GPIO_19__CCM_CLKO         \
         IOMUX_PAD(0x0624, 0x0254, 3, 0x0000, 0, 0)
  #define _MX6Q_PAD_GPIO_19__ECSPI1_RDY           \
         IOMUX_PAD(0x0624, 0x0254, 4, 0x0000, 0, 0)
  #define _MX6Q_PAD_GPIO_19__ENET_TX_ER           \
         IOMUX_PAD(0x0624, 0x0254, 6, 0x0000, 0, 0)
  #define _MX6Q_PAD_GPIO_19__SRC_INT_BOOT         \
         IOMUX_PAD(0x0624, 0x0254, 7, 0x0000, 0, 0)
以上的宏定义来自imx6的linux源码的arm/arch/palt-mxc/include/mach/iomux-mx6q.h
希望对大家有帮助~~
imx6 GPIO配置.pdf (263.71 KB, 下载次数: 354)
 楼主| 发表于 2014-6-24 09:25:04 | 显示全部楼层
RE:【经验分享】飞思卡尔IMX6处理器的GPIO配置方式
支持一下~~
 楼主| 发表于 2014-9-19 15:42:33 | 显示全部楼层
为何没有人顶一下呢
 楼主| 发表于 2014-9-19 15:42:54 | 显示全部楼层
自己支持一下哈~~
  • 签到天数: 46 天
    发表于 2016-9-24 22:11:49 | 显示全部楼层
    谢谢,明白了
    2017-10-19 11:01
  • 签到天数: 18 天
    发表于 2016-11-8 09:25:22 | 显示全部楼层
    谢谢,正在学习
    有点累
    发表于 2016-11-18 18:02:43 | 显示全部楼层
    感谢分享!
    发表于 2017-5-26 14:07:12 | 显示全部楼层
    非常感谢楼主分享,先收下,以后用的着
    发表于 2017-6-8 10:36:42 | 显示全部楼层
    感谢分享
    郁闷
    2018-12-5 15:26
    发表于 2018-3-16 17:51:56 | 显示全部楼层
    你好,现在正在学习,刚刚开始,请问一下,IO口配置好之后,是直接在程序里使用这个宏定义就行了吗?
    签到啊~
    GMT+8, 2026-4-22 02:05 , Processed in 0.114127 second(s), 31 queries , Redis On.
