查看: 2528|回复: 2
MC9S08AW60
发表于 2015-7-23 18:32:58 | 显示全部楼层 |阅读模式
MC9S08AW60用P&E MULTILINK 烧写程序出现在下面错误怎么解决
Device MC9S08AW60_FLASH is secured
Error:  Protect Command Failed.  Device is secured. Please unsecure or do a mass erase operation.
An invalid preference was passed to the GDI protocol plugin(HC/RS/S12Z GDI Protocol Adapter)
Error: Protect Command Failed.Device is secured. Please unsecure or do a mass erase operation.
发表于 2015-8-11 07:01:25 | 显示全部楼层
根据提示,片子被加密了。先使用codewarrior工具栏上的闪电图标,去mass erase这个片子,能够成功完成,后面就好了
发表于 2015-9-9 16:37:23 | 显示全部楼层
应该是被保护了,开发环境有解锁的功能的
GMT+8, 2025-9-18 11:43 , Processed in 0.081726 second(s), 21 queries , MemCache On.
