查看: 29460|回复: 22
[原创] EMMC 5.0 and EMMC 5.1 work on i.MX6
发表于 2016-8-30 15:53:40 | 显示全部楼层 |阅读模式
EMMC5.0 and EMMC 5.1 work on i.MX6
在我们i.MX6Q/Dual Sabre Board的参考设计中eMMC IC 使用的是Sandisk SDIN5C2-8 (4.41),在i.MX6Reference manual datasheet我们知道compatible with the MMCSystem Specification version 4.2/4.3/4.4,而且在datasheet中有关于uSDHCmodule详细的细节描述,在手册中可以看到“fullycompliant with the MMC command/response sets and Physical Layer as defined inthe Multimedia Card System Specification, v4.2/4.3/4.4/4.41, includinghigh-capacity (> 2 GB) HC MMC cards.EMMC4.4/4.41在我们默认的BSP是支持,而且在我们新releasedBSP是有支持eMMC4.5的。
随着技术的发展,但是eMMC4.4有可能会停产,被Emmc4.5甚至是更高版本的EMMC5.0 EMMC5.1。更多的客户也会选择更高的版本替代。那 How to make the eMMC 4.5 , EMMC 5.0 and EMMC 5.1 work on i.MX6 ?
如果EMMC4.5 或者EMMC5.0 /5.1 能向下和eMMC4.4兼容的话,那么它可以工作在eMMC4.4模式下,这样eMMC4.5eMMC5.0 /5.1就可以在i.MX6上工作了。Booting from a eMMC 4.5 device or high version isnot supported,  boot ROM will fall back to the eMMC4.4  standard whena eMMC4.5 or high version capable device is detected. In BSP it is possible tobypass eMMC version checking, so that eMMC v4.5 or high version can work aseMMC v4.4 cards, no specific v4.5 feature supported. Only basic read/writeoperations are supported.
在源码中,我们可以看到:
In the source code we can change check value of card->ext_csd.rev.
Take the eMMC 4.5 work as example, the current i.MX6 Linux BSP(L3.0.35_4.1.0) has added code to interface with an eMMC4.5 card to operate asan eMMC4.4 card. Change the value of card->ext_csd.rev5 to 6, now eMMC 5.0 can work as an eMMC 4.4. The code drivers/mmc/core/mmc.c:
And for the EMMC 5.0 and EMMC5.1, modify the kernelto support eMMC 5.0 and 5.1 extended CSD revisions, as shown below:
/drivers/mmc/core/mmc.c :
if (card->ext_csd.rev > 6){              //The '6' has to be replaced with '[color=#E2***39]7
' For EMMC5.0
                                                          //  The '6' has to be replacedwith '[color=#E2***39]8'  For EMMC5.1
               pr_err("%s: unrecognised EXT_CSD revision %d\n",
                       mmc_hostname(card->host), card->ext_csd.rev);
                err = -EINVAL;
                goto out;
After modifying the code we need to rebuild the thefirmware uImage used for MfgTool . Update the uImage in Mfgtool , and it canflash successful.
Then the eMMC version 5.0 and 5.1 can be used with i.MX6 based boards.
  • 签到天数: 11 天
    优秀版主
    发表于 2016-8-30 16:15:53 | 显示全部楼层
    终于来了
    郁闷
    2016-11-8 09:21
    发表于 2016-8-30 20:34:59 | 显示全部楼层
    之前听说emmc 4.4 可能会停产,这篇文章来的好及时,赞一个。
     楼主| 发表于 2016-8-31 10:03:50 | 显示全部楼层
     楼主| 发表于 2016-8-31 10:04:45 | 显示全部楼层
    现在有的客户已经开始使用emmc4.5或者emmc5.0版本的了,这里要稍微做一些改动。
    2019-11-15 11:44
  • 签到天数: 117 天
    发表于 2016-9-9 15:02:51 | 显示全部楼层
    我来赚金币,先实现一个小目标。
     楼主| 发表于 2016-9-13 16:10:31 | 显示全部楼层
    风之狼 发表于 2016-9-9 15:02
    我来赚金币,先实现一个小目标。
    发表于 2016-9-20 11:06:15 | 显示全部楼层
    小智MM 我修改了那个参数,把生成的uiamge放在了os 固件库下,但是烧写的时候出现错误
    Net:   got MAC address from IIM: 00:00:00:00:00:00
    FEC0 [PRIME]
    ## Booting kernel from Legacy Image at 10800000 ...
       Image Name:   Linux-3.0.35
       Image Type:   ARM Linux Kernel Image (uncompressed)
       Data Size:    5124768 Bytes =  4.9 MB
       Load Address: 10008000
       Entry Point:  10008000
       Verifying Checksum ... Bad Data CRC
    ERROR: can't get kernel image!
    MX6SDL SABRESD-MFG U-Boot >
    找不到内核,我的是imx6双核 安卓系统 内核是3.0.35
    今天天气不错!签到!
     楼主| 发表于 2016-9-22 14:52:00 | 显示全部楼层
    Net:   got MAC addr ...
    你这里是u-boot启动后,command line的参数没有设置正确。这样,你在我们论坛中建个帖子,把问题和你使用的板子简单描述一下。你在这里发,有时候收不到通知,看不到问题。问题更新的话,也不方便查看~~
    发表于 2016-10-17 16:43:05 | 显示全部楼层
    LZ,我很懒。能不能推荐几款 eMMC 5.0  或者 5.1的?
    还是,eMMC 兼容的,都可以呼唤,海力士、东芝、闪迪都可以吗?
    GMT+8, 2026-2-22 03:39 , Processed in 0.102968 second(s), 29 queries , Redis On.
