查看: 738|回复: 0
[求助] 求助imx6q使用4.19.35版本编译imx-image-multimedia,无法显示桌面
    发表于 2023-7-5 23:35:54 | 显示全部楼层 |阅读模式
    紧急求助使用yocto编译的4.19.35_1.1.0,X11桌面无法显示,以下是X11日志:
    X.Org X Server 1.20.4
    X Protocol Version 11, Revision 0
    [   146.663] Build Operating System: Linux 5.4.0-131-generic x86_64
    [   146.664] Current Operating System: Linux imx6q 4.19.35-1.1.0+g8507afc3a397 #1 SMP PREEMPT Sun Jul 2 07:50:04 UTC 2023 armv7l
    [   146.664] Kernel command line: console=ttymxc0,115200 root=/dev/mmcblk3p2 rootwait rw video=mxcfb0:dev=ldb,VGA_1024768 video=mxcfb1ff video=mxcfb2ff video=mxcfb3ff
    [   146.665] Build Date: 30 June 2023  04:27:38AM
    [   146.666]
    [   146.666] Current version of pixman: 0.38.0
    [   146.667]         Before reporting problems, check http://wiki.x.org
            to make sure that you have the latest version.
    [   146.667] Markers: (--) probed, (**) from config file, (==) default setting,
            (++) from command line, (!!) notice, (II) informational,
            (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
    [   146.670] (==) Log file: "/var/log/Xorg.0.log", Time: Tue Apr 25 10:00:36 2023
    [   146.671] (==) Using config file: "/etc/X11/xorg.conf"
    [   146.671] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
    [   146.672] (==) No Layout section.  Using the first Screen section.
    [   146.672] (==) No screen section available. Using defaults.
    [   146.672] (**) |-->Screen "Default Screen Section" (0)
    [   146.672] (**) |   |-->Monitor "<default monitor>"
    [   146.674] (==) No device specified for screen "Default Screen Section".
            Using the first device section listed.
    [   146.674] (**) |   |-->Device "i.MX Accelerated Framebuffer Device"
    [   146.674] (==) No monitor specified for screen "Default Screen Section".
            Using a default monitor configuration.
    [   146.674] (**) Option "BlankTime" "0"
    [   146.674] (**) Option "StandbyTime" "0"
    [   146.674] (**) Option "SuspendTime" "0"
    [   146.674] (**) Option "OffTime" "0"
    [   146.674] (==) Automatically adding devices
    [   146.674] (==) Automatically enabling devices
    [   146.674] (==) Automatically adding GPU devices
    [   146.674] (==) Max clients allowed: 256, resource mask: 0x1fffff
    [   146.674] (WW) The directory "/usr/share/fonts/X11/misc/" does not exist.
    [   146.674]         Entry deleted from font path.
    [   146.674] (WW) The directory "/usr/share/fonts/X11/TTF/" does not exist.
    [   146.674] (WW) The directory "/usr/share/fonts/X11/OTF/" does not exist.
    [   146.674] (WW) The directory "/usr/share/fonts/X11/Type1/" does not exist.
    [   146.674] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
    [   146.674] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
    [   146.675]         Entry deleted from font path.
    [   146.675] (==) FontPath set to:
    [   146.675] (==) ModulePath set to "/usr/lib/xorg/modules"
    [   146.675] (II) The server relies on udev to provide the list of input devices.
            If no devices become available, reconfigure udev or disable AutoAddDevices.
    [   146.675] (II) Loader magic: 0x1cbd90
    [   146.675] (II) Module ABI versions:
    [   146.675]         X.Org ANSI C Emulation: 0.4
    [   146.675]         X.Org Video Driver: 24.0
    [   146.675]         X.Org XInput driver : 24.1
    [   146.675]         X.Org Server Extension : 10.0
    [   146.678] (--) using VT number 3
    [   146.679] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
    [   146.681] (II) xfree86: Adding drm device (/dev/dri/card0)
    [   146.681] (II) no primary bus or device found
    [   146.681]         falling back to /sys/devices/platform/platform:Vivante GCCore/drm/card0
    [   146.681] (II) LoadModule: "glx"
    [   146.682] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
    [   146.688] (II) Module glx: vendor="X.Org Foundation"
    [   146.688]         compiled for 1.20.4, module version = 1.0.0
    [   146.688]         ABI class: X.Org Server Extension, version 10.0
    [   146.688] (II) LoadModule: "vivante"
    [   146.689] (II) Loading /usr/lib/xorg/modules/drivers/vivante_drv.so
    [   146.690] (II) Module vivante: vendor="X.Org Foundation"
    [   146.690]         compiled for 1.20.4, module version = 1.0.0
    [   146.690]         ABI class: X.Org Video Driver, version 24.0
    [   146.690] (II) VIVANTE: fb driver for vivante: VivanteGC500, VivanteGC2100,
            VivanteGCCORE
    [   146.690] (WW) Falling back to old probe method for vivante
    [   146.691] (II) Loading sub module "fbdevhw"
    [   146.691] (II) LoadModule: "fbdevhw"
    [   146.691] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
    [   146.691] (II) Module fbdevhw: vendor="X.Org Foundation"
    [   146.691]         compiled for 1.20.4, module version = 0.0.2
    [   146.691]         ABI class: X.Org Video Driver, version 24.0
    [   146.691] (II) VIVANTE(0): using default device
    [   146.721] (II) VIVANTE(0): Device preferred mode 'fb0':U:1024x768p-46
    [   146.721] (II) VIVANTE(0): Creating default Display subsection in Screen section
            "Default Screen Section" for depth/fbbpp 16/16
    [   146.721] (==) VIVANTE(0): Depth 16, (==) framebuffer bpp 16
    [   146.721] (==) VIVANTE(0): RGB weight 565
    [   146.721] (==) VIVANTE(0): Default visual is TrueColor
    [   146.721] (==) VIVANTE(0): Using gamma correction (1.0, 1.0, 1.0)
    [   146.721] (DB) xf86MergeOutputClassOptions unsupported bus type 0
    [   146.721] (**) VIVANTE(0): mExaHwType:1
    [   146.721] (II) VIVANTE(0): checking modes against framebuffer device...
    [   146.721] (II) VIVANTE(0): checking modes against monitor...
    [   146.721] (II) VIVANTE(0): Virtual size is 0x0 (pitch 0)
    [   146.721] (==) VIVANTE(0): DPI set to (96, 96)
    [   146.721] (II) Loading sub module "fb"
    [   146.722] (II) LoadModule: "fb"
    [   146.722] (II) Loading /usr/lib/xorg/modules/libfb.so
    [   146.723] (II) Module fb: vendor="X.Org Foundation"
    [   146.723]         compiled for 1.20.4, module version = 1.0.0
    [   146.723]         ABI class: X.Org ANSI C Emulation, version 0.4
    [   146.723] (II) Loading sub module "exa"
    [   146.723] (II) LoadModule: "exa"
    [   146.724] (II) Loading /usr/lib/xorg/modules/libexa.so
    [   146.724] (II) Module exa: vendor="X.Org Foundation"
    [   146.724]         compiled for 1.20.4, module version = 2.6.0
    [   146.724]         ABI class: X.Org Video Driver, version 24.0
    [   146.833] (II) VIVANTE(0): printing discovered frame buffer 'fb0' supported modes:
    [   146.833] (II) VIVANTE(0): Modeline "U:1024x768p-46"x0.0   50.00  1024 1064 1124 1344  768 775 785 806 -hsync -vsync -csync (37.2 kHz eP)
    [   146.861] (II) VIVANTE(0): Output DISP4 BG - DI1 has no monitor section
    [   146.861] (II) VIVANTE(0): Printing probed modes for output DISP4 BG - DI1
    [   146.861] (II) VIVANTE(0): Modeline "U:1024x768p-46"x46.2   50.00  1024 1064 1124 1344  768 775 785 806 -hsync -vsync -csync (37.2 kHz eP)
    [   146.861] (II) VIVANTE(0): Output DISP4 BG - DI1 connected
    [   146.861] (II) VIVANTE(0): Using exact sizes for initial modes
    [   146.861] (II) VIVANTE(0): Output DISP4 BG - DI1 using initial mode U:1024x768p-46 +0+0
    [   146.861] (II) VIVANTE(0): imxDisplayPreInit: virtual set 1024 x 768, display width 0
    [   146.862] (II) VIVANTE(0): VivPreInit: adjust display width 1024
    [   146.940] (II) VIVANTE(0): reserve 4177920 bytes for on screen frame buffer; total fb memory size 8359936 bytes; offset of shadow buffer 4177920
    [   147.011] (II) VIVANTE(0): hardware: DISP4 BG - DI1 (video memory: 8164kB)
    [   147.053] (II) VIVANTE(0): FB Start = 0x75ae9000  FB Base = 0x75ae9000  FB Offset = (nil)
    [   147.054] (II) VIVANTE(0): test Initializing EXA
    会一直卡在"test Initializing EXA",卡一会儿后,X11会自动重启,然后又是这样,求各位大佬帮忙,万分感谢!
    我知道答案 目前已有0人回答
    GMT+8, 2025-9-19 11:19 , Processed in 0.092288 second(s), 21 queries , MemCache On.
