查看: 3046|回复: 1
[其他] 关于定时器
发表于 2010-5-26 15:01:48 | 显示全部楼层 |阅读模式
问一个很菜的问题,怎么使定时器输出口为普通I/O口,因为我发现关闭定时器后输出口为高电平
我知道答案 目前已有0人回答
    发表于 2010-5-27 08:57:58 | 显示全部楼层
    RE:关于定时器
    Each TPM channel is associated with an I/O pin on the MCU. The function of this pin depends on the
    configuration of the channel. In some cases, no pin function is needed so the pin reverts to being controlled
    by general-purpose I/O controls. When a timer has control of a port pin, the port data and data direction
    registers do not affect the related pin(s). See the Pins and Connections chapter for additional information
    about shared pin functions.
    这个是手册上说明的,大概意思是定时器不影响普通IO口的功能,可以设置IO口的方向和电平状态。
    GMT+8, 2025-10-27 00:37 , Processed in 0.081071 second(s), 22 queries , MemCache On.
