在线时间393 小时
UID123826
注册时间2009-4-22
NXP金币2
TA的每日心情 | 难过 2021-12-15 16:01 |
- 377
- 2023-8-16
本文内容转载来自:http://www.for68.com/jidianyingyu/
1. A amplifier ==> A类放大器,甲类放大器
2. A And Not B gate ==> "禁止"门,A"与"B"非"门
3. a frame ==> a形杆
4. a pole ==> a形杆
5. a register ==> 累加寄存器
6. A, a ==> A相,安培
7. a.c. balance indicator ==> 交流平衡指示器
8. a.c. bridge ==> 交流电桥
9. a.c. current calibrator ==> 交流电流校准器
10. a.c. current distortion ==> 交流电流失真
11. a.c. induced polarization instrument ==> 交流激电仪
12. a.c. potentiometer ==> 交流电位差计
13. a.c. resistance box ==> 交流电阻箱
14. a.c. standard resistor ==> 交流标准电阻器
15. a.c. voltage distortion ==> 交流电压失真,交流电压校准器
16. A/D converter, analogue digital converter ==> 模-数转换器,A/D转换器
17. A/D, analog/digital ==> 模拟/数字,模拟量/数字量
18. A/M station, automatic/manual station ==> 自动/手动操作器
19. AA conductor, aluminium magnesium alloy conductor ==> 铝镁合金导线
20. Abbe comparator ==> 阿贝比长仪
21. abbertite ==> 黑沥青
22. abbreviated ==> 简化的,缩写的,简缩的
23. abbreviation ==> 简写,缩写词,略语
24. abend ==> 任务异常结束
25. aberrant ==> 异常的
26. aberrant source ==> 异常误差来源
27. aberration ==> 相差,偏差,色差,光行差,失常,反常
28. aberration characteristic ==> 相差特性
29. aberration curve ==> 相差曲线
30. ability of anti prereduced component ==> 抗先还原物质能力
31. ability of bearing taxation ==> 负税能力
32. ability of harden ==> 硬化性能
33. ablative thickness transducer [sensor] ==> 烧蚀厚度传感器
34. abnormal ==> 反常的,不正规的,异常的
35. abnormal current ==> 异常电流,事故电流
36. abnormal end of task ==> 任务异常结束
37. abnormal glow discharge ==> 反常辉光放电
38. abnormal heating ==> 异常发热,事故发热
39. abnormal low voltage arc ==> 反差低压电弧
40. abnormal overload ==> 异常过载,事故过载
41. abnormal overvoltage ==> 异常过电压,事故过电压
42. abnormal radiation ==> 异常辐射
43. abnormal reflection ==> 异常反射
44. abnormal voltage ==> 异常电压,事故电压
45. abort ==> 故障,失灵
46. abort light ==> 紧急故障信号
47. above critical state ==> 超临界状态,临界以上的,超临界的
48. above earth potential ==> [对地]电位,[对地]电势
49. above thermal ==> 超热的
50. abradant material ==> 研磨材料
51. abrasion ==> 磨损,磨蚀
52. abrasion machine ==> 磨耗[试验]机
53. abrasion proof component of burner ==> 燃烧器耐磨件
54. abrasion resistance ==> 抗磨力,耐磨度,耐磨,抗磨性
55. abrasion testing machine ==> 磨损试验机
56. abrasive action ==> 磨损作用
57. abrasive blast equipment ==> 喷砂设备
58. abrasive blast system ==> 喷砂清理系统
59. abrasive blasting ==> 喷砂法,喷丸法
60. abrasive wheel cutting off machine ==> 砂轮切割机
61. abrupt change ==> 突然变化
62. abrupt change of voltage ==> 电压突变
63. abrupt curve ==> 陡曲,急弯曲线
64. abruption ==> 断裂
65. ABS, American Bureau of Standard ==> 美国标准局
66. abscissa ==> 横坐标
67. abscissa axis ==> 横座标轴
68. absence of collector ==> 无集电环
69. absence of commutator ==> 无换向器,无整流子,无转换器
70. absence of offset ==> 无偏置,零偏移
71. absolute ==> 绝对的
72. absolute accuracy ==> 绝对精确度
73. absolute ampere ==> 绝对安培(电流的标准MkS单位,等于0.1abampere)
74. absolute block ==> 绝对闭塞
75. absolute calibration ==> 绝对校准,绝对法校准
76. absolute capacitivity ==> 绝对电容率,绝对介电常数
77. absolute capacity ==> 绝对容量
78. absolute coding ==> 绝对编码
79. absolute coil ==> 独立线圈
80. absolute colorimetric ==> 绝对色度
81. absolute constant ==> 绝对常数
82. absolute damping ==> 绝对阻尼,振荡完全停止
83. absolute delay ==> 绝对延迟
84. absolute density ==> 绝对密度
85. absolute dielectric constant ==> 绝对介电常数,绝对电容率
86. absolute displacement ==> 绝对位移
87. absolute efficiency ==> 绝对效率
88. absolute electrical units ==> 绝对电单位
89. absolute electrode potential ==> 绝对电极电势
90. absolute electromagnetic unit ==> 绝对电磁单位
91. absolute electrometer ==> 绝对静电计
92. absolute electrostatic unit ==> 绝对静电单位
93. absolute error ==> 绝对误差
94. absolute error of measurement ==> 测量的(绝对)误差
95. absolute galvanometer ==> 绝对检流计
96. absolute gravimeter ==> 绝对重力仪
97. absolute gravity survey ==> 绝对重力测量
98. absolute humidity ==> 绝对湿度
99. absolute level ==> 绝对级
100. absolute measurement ==> 绝对测量
101. absolute method ==> 绝对法
102. absolute method of measurement ==> 绝对测量法
103. absolute moisture of the soil ==> 土壤绝对湿度
104. absolute peak ==> 绝对峰值
105. absolute permeability ==> 绝对磁导率
106. absolute permittivity ==> 绝对电容率
107. absolute potential ==> 绝对电势
108. absolute pressure ==> 绝对压力
109. absolute pressure transducer ==> 绝对压力表
110. absolute pressure transducer[sensor] ==> 绝对压力传感器
111. absolute read out ==> 单独读出
112. absolute resolution ==> 绝对分辨率
113. absolute salinity ==> 绝对盐度
114. absolute sensitivity ==> 绝对灵敏度
115. absolute slip ==> 绝对转差率
116. absolute speed drop ==> 绝对转速降
117. absolute speed rise ==> 绝对转速升
118. absolute speed variation ==> 绝对转速变动
119. absolute stability ==> 绝对稳定性
120. absolute stability of a linear system ==> 线性系统的绝对稳定性
121. absolute static pressure of the fluid ==> 流体绝对静压
122. absolute system of electrical units ==> 绝对电单位制
123. absolute temperature ==> 绝对温度
124. absolute temperature scale ==> 绝对温标
125. absolute term ==> 绝对项
126. absolute unit ==> 绝对单位
127. absolute voltage drop ==> 绝对电压降
128. absolute voltage rise ==> 绝对电压上升
129. absolute zero ==> 绝对零度
130. absorbance ==> 吸光度
131. absorbed current image ==> 吸收电流象
132. absorbent carbon ==> 活性碳吸收器电路
133. absorber circuit ==> 吸收器电路
134. absorbing gas ==> 吸收气体
135. absorbing load ==> 吸收负载
136. absorptance ==> 吸收比
137. absorptiometer ==> 吸收光度计
138. absorption ==> 吸收
139. absorption band ==> 吸收带
140. absorption capacitor ==> 吸收电容器(消弧用)
141. absorption cell ==> 吸收池
142. absorption circuit ==> 吸收电路
143. absorption coefficient ==> 吸收系数
144. absorption constant ==> 吸收常数
145. absorption control ==> 吸收控制
146. absorption correction ==> 吸收修正
147. absorption current ==> 吸收电流
148. absorption curve ==> 吸收曲线
149. absorption damper ==> 1.减振器2.消音器
150. absorption edges ==> 吸收边
151. absorption effect ==> 吸附效应
152. absorption factor ==> 吸收系数
153. absorption hygrometer ==> 吸收温度表
154. absorption loss ==> 吸收损耗
155. absorption plane ==> 吸收面
156. absorption spectrum ==> 吸收频谱,吸收光谱
157. absorption wavemeter ==> 吸收式波长计
158. absorption X ray spectrometry ==> 吸收X射线谱法
159. absorptive dielectric ==> 吸收性电介体
160. absorptive power ==> 吸收能力
161. absorptivity ==> 吸收率
162. absorptivity of an absorbing ==> 吸引材料的吸收率
163. abstract ==> 文摘,摘要
164. abstract code ==> 抽象代码,理想码
165. abstract system ==> 抽象系统
166. abundance sensityivity ==> 丰度灵敏度
167. abutment pole ==> 中缩磁极(中间载面小的磁极)
168. abutting ends ==> 相邻线端
169. ac ==> 交流
170. AC AC LVDT displacement transducer ==> 交流差动变压器式位移传感器
171. AC analog computer ==> 交流模拟计算机
172. AC and DC hybrid simulation system ==> 交直流混合仿真系统
173. AC bridge ==> 交流电桥
174. AC circuit breaker ==> 交流断路器
175. AC commutator motor ==> 交流换向器式电动机,交流整流子电动机
176. AC commutator type exciter ==> 交流换向器式励磁机
177. AC commutatorless and brushless motor ==> 交流无刷无换向器电动机
178. AC component ==> 交流分量
179. AC distribution ==> 交流配电
180. AC distribution system ==> 交流配电系统
181. AC earth relay ==> 交流接地继电器
182. AC electromagnet ==> 交流电磁铁
183. AC excitation ==> 交流励磁
184. AC exciter ==> 交流励磁机
185. AC filter ==> 交流滤波器
186. AC gate signal ==> 交流控制极信号
187. AC generator ==> 交流发电机
188. AC indicator ==> 交流指示器
189. AC load line ==> 交流负载线
190. AC load switching ==> 交流负载转接,交流负荷切换
191. AC network computer ==> 交流网络计算机,交流计算台
192. AC network distribution ==> 交流网络配电
193. AC pilot relaying ==> 交流补助线继电保护系统,交流引线[纵差]继电保护
194. AC relay ==> 交流继电器
195. AC servomechanism ==> 交流伺服机构
196. AC servomotor ==> 交流伺服电动机
197. AC shunt motor ==> 交流串激电动机
198. AC transmission ==> 交流电
199. AC trigger ==> 交流触发器
200. AC two phase generator ==> 二相交流发电机
201. AC voltage stabilizer ==> 交流电压稳定器,交流稳定器
202. AC watt hour meter ==> 交流电度表
203. AC welder ==> 交流电焊机
204. AC winding ==> 交流绕组
205. AC&DC hybrid simulation system ==> 交直流混合仿真系统
206. academic corruption ==> 学术腐败
207. academic fraud ==> 学术欺诈
208. academic power ==> 学术权力
209. acaroid resin ==> 乔木树脂
210. accelerate ==> 加速
211. accelerated ageing ==> 加速老化
212. accelerated ageing test ==> 加速老化试验
213. accelerated aging ==> 加速老化试验
214. accelerated burn-up test ==> 加速燃耗试验
215. accelerated by a spring ==> 弹簧加速的
216. accelerated clarification ==> 加速澄清
217. accelerated clariqier ==> 加速沉降器
218. accelerated combustion ==> 加速燃烧
219. accelerated corrosion test ==> 加速腐蚀试验
220. accelerated depreciation ==> 加速折旧
221. accelerated distance protection system ==> 加速式距离保护系统
222. accelerated draft ==> 加速通风
223. accelerated erosion ==> 加速侵蚀
224. accelerated fatigue ==> 加速疲劳
225. accelerated life test ==> 快速寿命测试,加速寿命试验
226. accelerated load test ==> 加速载荷试验
227. accelerated motion ==> 加速运动
228. accelerated oxidation ==> 加速氧化
229. accelerated particle ==> 加速粒子
230. accelerated test ==> 加速试验
231. accelerating ==> 加速度
232. accelerating agent ==> 加速剂
233. accelerating anode ==> 加速阳极
234. accelerating by gravity ==> 重力加速度
235. accelerating chamber ==> 加速室
236. accelerating constant ==> 加速常数
237. accelerating electrode ==> 加速电极(电子管的)
238. accelerating force ==> 加速力
239. accelerating force curve ==> 加速力曲线
240. accelerating load ==> 加速负荷
241. accelerating potential ==> 加速电位,加速电势
242. accelerating relay ==> 加速继电器
243. accelerating torque ==> 加速转矩
244. acceleration ==> 加速,加速度
245. acceleration constant ==> 加速常数
246. acceleration error coefficient ==> 加速度误差系数
247. acceleration factor ==> 加速系数
248. acceleration lag ==> 加速滞后
249. acceleration of gravity ==> 重力加速度
250. acceleration relay ==> 加速继电器
251. acceleration simulator ==> 加速度仿真器
252. acceleration time ==> 加速时间
253. acceleration transducer[sensor] ==> 加速度传感器
254. accelerationg voltage ==> 加速电压
255. accelerative force ==> 加速力
256. accelerator ==> 加速器
257. accelerometer ==> 加速度计
258. accent lighting ==> 重点照明
259. acceptability criteria ==> 验收标准
260. acceptable life ==> 有效使用寿命
261. acceptable limit ==> 容许极限
262. acceptance criteria ==> 验收标准
263. acceptance of the mass filter ==> 滤质器的接收容限
264. acceptance proof test ==> 新绝缘绕组投运前试验
265. acceptance specification ==> 验收规范
266. acceptance test ==> 验收试验,验[交]收检验
267. acceptance test specification ==> 验收测试规范
268. acceptor ==> 1.接收器(计算机的),2.受主(半导体的),受主
269. acceptor circuit ==> 接受器电路,带通电路
270. acceptor impurity ==> 受主杂质(半导体中的)
271. acceptor resonance ==> 电压谐振,串联谐振
272. access ==> 存取
273. access arm ==> 存取臂
274. access gap ==> 存取差距
275. access mechanism ==> 存取机构
276. access panel ==> 罩板
277. access scan ==> 取数扫描
278. access selector ==> 存取选择器
279. access time ==> 存取时间
280. accessibility ==> 可及性,可达性
281. accessor ==> 存取机构
282. accessories of testing machine ==> 试验机附件
283. accessory apparatus ==> 辅助设备
284. accessory drove ==> [厂用]辅机传动
285. accessory for a measuring instrument ==> 测量仪表的附件
286. accessory hardware ==> 附属硬件
287. accessory of limited interchangeability ==> 有限互换附件
288. accessory power supply ==> 辅助电源
289. accidental coincidence ==> 偶然重合,偶然符合
290. accidental error ==> 偶然误差
291. accidental exposure ==> 事故辐射
292. accidental failure ==> 偶然故障,偶然失效
293. accidental jamming ==> 偶然干扰
294. accidental torque ==> 异常转矩
295. accommodate ==> 调节
296. accommodation ==> 调节,调适
297. accounting program ==> 记帐程序
298. accounting routine ==> 费用计算程序
299. accreditation ==> 认可,委任,任命, IEEE to beef up its global accreditation role.
300. accreditation of testing laboratory ==> 测试实验室的认可
301. accumulated dose ==> 累积剂量
302. accumulated error ==> 累积误差,积累误差
303. accumulated time difference ==> 累积时差
304. accumulated total punch ==> 累计穿孔机
305. accumulating counter ==> 累加计数器
306. accumulation ==> 积蓄
307. accumulation of electricity ==> 电积累
308. accumulation of heat ==> 热力储存,蓄热
309. accumulation of rounding errors ==> 舍入误差积累
310. accumulation quotient register ==> 累加-商寄存器
311. accumulative carry ==> 累加进位
312. accumulative error ==> 累计误差
313. accumulative raingauge ==> 累积雨量器
314. accumulator ==> 二次电池,累加器,储线器/补偿器
315. accumulator battery ==> 蓄电池组,蓄电池
316. accumulator capacity ==> 蓄电池容量
317. accumulator cell ==> 蓄电池单元
318. accumulator charge ==> 蓄电池充电
319. accumulator charger ==> 蓄电池充电器
320. accumulator discharge ==> 蓄电池放电
321. accumulator drive ==> 蓄电池牵引
322. accumulator feeding ==> 蓄电池馈电
323. accumulator insulator ==> 蓄电池绝缘体
324. accumulator jump instruction ==> 累加器转移指令
325. accumulator plate ==> 蓄电池极板
326. accumulator railcar ==> 电瓶机动车
327. accumulator rectifier ==> 蓄电池整流
328. accumulator room ==> 蓄电池室
329. accumulator switch ==> 蓄电池开关
330. accumulator switchboard ==> 蓄电池配电盘
331. accumulator voltage ==> 蓄电池电压
332. accuracy ==> 准确,精[准]确度
333. accuracy class ==> 精[准]确度等级,精度等级
334. accuracy control ==> 精确控制
335. accuracy grade ==> 准确度,精度等级
336. accuracy life ==> 精确度寿命
337. accuracy limit factor of a protective current transformer ==> 保护用电流互感器的精确度极限因数
338. accuracy of measurement ==> 测量精度,测量准确度,测量精确度
339. accuracy of reading ==> 读数准确
340. accuracy of the wavelength ==> 波长精确度
341. accuracy rating ==> 准确度,精确度限
342. accurate position indicator ==> 正确位置指示器
343. ACE, area control error ==> 区域控制偏差, A negative value indicates a condition of under-generation relative to system load and imports, and a positive value denotes over-generation.
344. acetate wire ==> 醋酸绝缘线
345. acetylene pressure gauge ==> 乙炔压力表
346. acetylene regulator ==> 乙炔减压器
347. achromat ==> 消色差透镜
348. acid ==> 酸
349. acid activation ==> [用]酸激活
350. acid battery ==> 酸性蓄电池
351. acid proof ==> 耐酸的
352. acid proof paint ==> 耐酸涂料/耐酸油漆
353. acid radical ==> 酸根,酸基
354. acid resistant insulation ==> 耐酸绝缘
355. acid resistant motor ==> 耐酸电动机
356. acid resisting ==> 耐酸的
357. acid rinsing shop stamping warehouse ==> 酸洗工段房-冲压库
358. acidic resin ==> 酸性树脂
359. acknowledge character ==> 肯定字符
360. acknowledge circuit ==> 警告电路,认可电路
361. acknowledge signal ==> 肯定信号,证实信号
362. acknowledgement ==> 确认,肯定应答
363. acknowledging contactor ==> 认收开关,认收接触器
364. aclinic line ==> 无倾线
365. acoustic absorbant ==> 吸声物质
366. acoustic amplitude logger ==> 声波幅度测井仪
367. acoustic beacon ==> 水声信标
368. acoustic conductance ==> 声导率
369. acoustic current meter ==> 声学海流计
370. acoustic element ==> 声学元件
371. acoustic emission ==> 声发射
372. acoustic emission amplitude ==> 声发射振幅
373. acoustic emission analysis system ==> 声发射分析系统
374. acoustic emission detection system ==> 声发射检测系统
375. acoustic emission detector ==> 声发射检测仪
376. acoustic emission energy ==> 声发射能量
377. acoustic emission event ==> 声发射事件
378. acoustic emission preamplifier ==> 声发射前置放大器
379. acoustic emission pulser ==> 声发射脉冲发生器
380. acoustic emission rate ==> 声发射信号,声发射率
381. acoustic emission signal processor[conditioner] ==> 声发射信号处理器
382. acoustic emission source ==> 声发射源
383. acoustic emission source location and analysis system ==> 声发射源定位及分析系统
384. acoustic emission source location system ==> 声发射源定位系统
385. acoustic emission spectrum ==> 声发射频谱
386. acoustic emission technique ==> 声发射技术
387. acoustic emission transducer[sensor] ==> 声发射换能器
388. acoustic fatigue ==> 声疲劳
389. acoustic impcdance ==> 声阻抗
390. acoustic impedance ==> 声阻抗
391. acoustic impulse ==> 声脉冲
392. acoustic logging instrument ==> 声波测井仪
393. acoustic malfunction ==> 声失效
394. acoustic matching layer ==> 声匹配层
395. acoustic material ==> 吸音材料
396. acoustic memory ==> 声存储器(计算机的),音存储器
397. acoustic optic deflector ==> 声光偏传器
398. acoustic oscillation ==> 声振荡
399. acoustic oscillograph ==> 声波示波器
400. acoustic quantity transducer[sensor] ==> 声(学量)传感器
401. acoustic radiation ==> 声辐射
402. acoustic ratio ==> 声比
403. acoustic reflection shell ==> 声反射罩
404. acoustic releaser ==> 声释放器
405. acoustic resistance ==> 声阻
406. acoustic signal ==> 音响信号
407. acoustic spectrum ==> 声谱
408. acoustic thermometer ==> 声学温度计,声波温度表
409. acoustic tide gauge ==> 回声验潮仪
410. acoustic transponder ==> 声应答器
411. acoustic wave ==> 声波
412. acoustical absorption coefficient ==> 吸声系数
413. acoustical circuit ==> 声路
414. acoustical frequency ==> 声频
415. acoustical frequency electric ==> 声频大地电场仪
416. acoustical hologram ==> 声全息图
417. acoustical holography ==> 声全息
418. acoustical holography by electron beam scanning ==> 电子束扫描声全息
419. acoustical holography by laser scanning ==> 激光束扫描声全息
420. acoustical holography by mechanical scanning ==> 机械扫查声全息
421. acoustical imaging by Bragg diffraction ==> 布拉格衍射声成像
422. acoustical impedance method ==> 声阻法
423. acoustical lens ==> 声透镜
424. acoustical reduction coefficient ==> 隔声系数
425. acoustical reflection factor ==> 声反射因数
426. acoustical resistance ==> 声阻
427. acoustical transmission factor ==> 透声系数,传声系数
428. acoustical velocity ==> 声速,音速
429. acoustically transparent pressure vessel ==> 透声压力容器
430. acoustimeter ==> 声强测量器,测声仪
431. acousto electric effect ==> 声电效应
432. acoustodynamic effect ==> 声动效应
433. ACPI, Advanced Configuration and Power Interface ==> 高级电源配置电源接口
434. acquisition price ==> 收购价
435. acquisition time ==> 取数据时间
436. across frequency ==> 交叉频率,分频频率
437. across the line moter ==> 直接起动电动机
438. across the line starter ==> 直接起动器
439. across the line starting ==> 直接起动
440. acryl resin ==> 丙烯树脂
441. acrylic fitting ==> 压克力配件
442. acrylic plastic glazing ==> 丙烯酸有机玻璃
443. ACSI, Abstract Common Service Interface ==> 抽象通信服务接口
444. ACSR ==> 钢芯铝线
445. ACST, access time ==> 存取时间
446. acting area (spot) lighting ==> 舞台前台(聚光)照明
447. actinometer ==> 光能计,直接日射强度表,日射表
448. action correction ==> 动作校正
449. action current ==> 作用电流,动作电流
450. action potential ==> 动作电位
451. action principle ==> 动作原理
452. activated absorption ==> 活性吸附
453. activated atom ==> 激活原子
454. activated cathode ==> 激活阴极
455. activated electrode ==> 激活电极
456. activated phosphor ==> 激活荧光粉
457. activated substance ==> 激活物质
458. activating isotope ==> 活化同位素
459. activation ==> 激活
460. activation cross section ==> 活化载面
461. activation heat ==> 活化热
462. activator ==> 活化剂
463. active ==> 活动的,有效的
464. active acidity ==> 有效酸度
465. active alkali ==> 活性碱
466. active area ==> 有效面积,工作面积
467. active assay ==> 有源[活化]分析
468. active augmentation methods ==> 有[外动力]源的强化换热方法
469. active balance ==> 等效平衡
470. active balance return loss ==> 有源平衡回程损耗
471. active biological surface ==> 活性生物表面
472. active block ==> 有源组件
473. active carbon ==> 活性碳
474. active circuit ==> 有源电路,有效电路
475. active coating ==> 激活层
476. active coil ==> 有效线圈
477. active component ==> 有效部分
478. active component of current ==> 电流有功分量
479. active conductor ==> 有效导体
480. active constituent ==> 有功部分
481. active cooling surface ==> 有效冷却面,有效散热面
482. active current ==> 有效电流
483. active defect ==> 运行故障
484. active device ==> 有源器件
485. active drift ==> 正阻力
486. active electric network ==> 有源网络,有源电网络
487. active electrode ==> 有效电极
488. active electron ==> 激活电子
489. active energy meter ==> 有功电度表,瓦时计
490. active filter ==> 有源滤波器
491. active four terminal network ==> 有源四端网络
492. active gauge length ==> 有效基长
493. active gauge width ==> 有效基宽
494. active lattice ==> 堆心栅格(反应堆的)
495. active line ==> 工作线路
496. active load ==> 有效负载
497. active logic ==> 常用逻辑
498. active loss ==> 有功损耗,实际损耗
499. active market ==> 买卖活跃的市场
500. active material ==> 活性物质
