在线时间393 小时
UID123826
注册时间2009-4-22
NXP金币2
TA的每日心情 | 难过 2021-12-15 16:01 |
- 377
- 2023-8-16
转自:http://www.for68.com/jidianyingyu/
1. b h curve ==> bh曲线
2. B scope ==> B型显示
3. babbitt metal ==> 巴比特合金
4. back ampere turns ==> 逆向安匝
5. back conductance ==> 反向电导
6. back connection ==> 背面连接
7. back contact ==> 后接点
8. back coupling ==> 反馈耦合
9. back coupling condition ==> 回授条件
10. back current ==> 逆电流
11. back current principle ==> 逆电流原理
12. back discharge ==> 反向放电
13. back electromotive force ==> 反电动势
14. back electromotive force cell ==> 反压电池
15. back fire ==> 逆弧
16. back flashover ==> 反向闪络
17. back flushing ==> 反吹
18. back power ==> 反向功率
19. back pressure turbine ==> 背压透平
20. back pulse front ==> 脉冲背面
21. back resistance ==> 反向电阻
22. back span ==> 反向间隔
23. back to back method ==> 反馈法
24. back-up ==> 后备的,备用的,应急的
25. back-up auxiliary ==> 备用辅机
26. back-up busbar ==> 备用汇流排
27. back-up power supply ==> 备用电源
28. back-up protection ==> 后备保护
29. back-up safety device ==> 备用安全装置
30. back-up supply ==> 备用电源
31. back view ==> 背面图,后视图
32. back wave ==> 间隔信号
33. back wiring ==> 背面布线
34. background ==> 后台背景本底
35. background counts ==> 本底计数
36. background current ==> 基流
37. background mass spectrum ==> 本底质谱
38. background noise ==> 背景噪声
39. background processing ==> 后台处理
40. background program ==> 后台程序,后台程度
41. background reader ==> 后台读出器
42. backing ==> 底座
43. backing coil ==> 反接线圈,补偿线圈
44. backing groove ==> 背面坡口
45. backing memory ==> 后备存储器
46. backing pass ==> 底焊焊道
47. backing plate ==> 底板
48. backing power ==> 倒车功率
49. backing pump ==> 旋转油泵
50. backlash ==> 空转
51. Backman thermometer ==> 贝克曼温度计
52. backplane ==> 背板
53. backscattered electron image ==> 背散射电子象
54. backspace character ==> 退格符
55. backward channel ==> 反向信道
56. backward flow ==> 逆流
57. backward lead ==> 电刷后移
58. backward reading ==> 反读
59. backward resistance ==> 反向电阻
60. backward voltage ==> 反向电压
61. backward wave ==> 反向波
62. bad conductor ==> 不良导体
63. bad contact ==> 不良接触
64. badge punch ==> 标记穿孔机
65. badge reader ==> 标记阅读器
66. baffle ==> 隔离屏
67. baffle wall ==> 隔板
68. bakelite ==> 酚醛塑料
69. balance ==> 天平,平衡
70. balance coil ==> 平衡线圈
71. balance for measuring amount of precipitation ==> 水量秤
72. balance indicator ==> 平衡指示器
73. balance output ==> 对称输出
74. balance quality of rotor ==> 转子平衡精度
75. balance relay ==> 平衡继电器
76. balance wieght ==> 平衡块
77. balanced beam relay ==> 平衡杆式继电器
78. balanced bridge ==> 平衡电桥
79. balanced circuit ==> 平衡电路
80. balanced demodulator ==> 平衡解调
81. balanced line ==> 对称线路
82. balanced load ==> 平衡负载
83. balanced modulator ==> 平衡调制器
84. balanced plug ==> 平衡型阀芯
85. balanced polyphase system ==> 平衡多相系
86. balanced system ==> 平衡系统
87. balanced three phase circuit ==> 平衡三相电路
88. balanced voltages ==> 平衡电压
89. balancer ==> 平衡器均压器
90. balancing ==> 平衡
91. balancing battery ==> 缓冲电池组
92. balancing capacitor ==> 均衡电容器
93. balancing capacity ==> 平衡电容
94. balancing coil ==> 平衡线圈
95. balancing controller ==> 平衡调节器
96. balancing machine ==> 平衡机,平衡试验机
97. balancing machine sensitivity ==> 平衡机灵敏度
98. balancing method ==> 零点法
99. balancing network ==> 平衡网络
100. balancing potentiometer ==> 平衡电位计
101. balancing resistor ==> 平衡电阻器
102. balancing rheostat ==> 平衡变阻器
103. balancing speed ==> 均衡速率,平衡转速
104. balancing transformer ==> 平衡用变压器
105. ball and socket type suspension insulator ==> 球窝式悬挂绝缘子
106. ball bearing ==> 滚珠轴承
107. ball-clevis ==> 球头挂板,由脚球与双片或单片挂板所构成的一种连接件
108. ball-hook ==> 球头挂钩
109. ball insulator ==> 球形绝缘子
110. ball lightning ==> 球状闪电
111. ball pneumatic dead wieght tester ==> 浮球压力计
112. ball screw assembly ==> 滚珠丝杠副
113. ball valve ==> 球阀
114. ballast ==> 稳定器
115. ballast leakage ==> 镇流漏电
116. ballast leakage resistance ==> 镇流漏泄电阻
117. ballast resistance ==> 平稳电阻
118. ballistic galvanometer ==> 冲击电流计
119. ballistic galvanometer constant ==> 冲击电流计常数
120. ballistic method ==> 冲击法
121. balzed grating ==> 闪耀光栅
122. band ==> 带,频带
123. band adjustment ==> 区域调节
124. band brake ==> 带闸
125. band elimination filter ==> 带阻滤波器
126. band fuse ==> 片形保险丝
127. band gap voltage reference ==> 带隙电压参考
128. band of frequencies ==> 频率带
129. band pass filter ==> 带通滤波器
130. band rejection filter ==> 带阻滤波器
131. band spread ==> 频带展宽
132. band stop filter ==> 带阻滤波器
133. band switch ==> 波段转换开关
134. band width ==> 频带宽度
135. band width of video amplifier ==> 视频放大器频宽
136. banding insulation ==> 绑扎绝缘
137. bandwidth ==> 带宽
138. bandwidth control ==> 带宽控制
139. bang bang controller ==> 继电器式控制器
140. bang bang servo ==> 开关伺服系统
141. bank of resistors ==> 电阻组
142. bank winding ==> 迭绕线圈
143. bar armature ==> 条线圈电枢
144. bar electromagnet ==> 条形电磁铁
145. bar insulation ==> 条绝缘
146. bar photometer ==> 条形光度计
147. bar primary bushing type current transformer ==> 棒形电流互感器
148. bar type transformer ==> 条形铁心变流
149. bar winding ==> 条形绕法
150. bar wound machine ==> 条绕电机
151. bare conductor ==> 裸线
152. bare electrode ==> 裸极
153. bare wire ==> 裸线
154. barium ==> 钡
155. barkhausen kurz oscillations ==> 巴克好森库尔兹振荡
156. barn ==> 靶恩
157. barograph ==> 气压计,气压记录嚣
158. barometer ==> 气压表
159. barometer cistern ==> 气压表水银槽
160. barometric correction ==> 气压表器差修正
161. barometrograph ==> 空盒气压计
162. barothermograph ==> 气压温度计
163. barrel ==> 桶
164. barrel distortion ==> 桶形畸变,负畸变
165. barrel winding ==> 桶形绕法
166. barretter ==> 镇流电阻器
167. barrier layer capacitance ==> 阻挡层电容
168. barrier layer cell ==> 光电池
169. BAS, Building Automation System ==> 楼宇自动化系统
170. base ==> 基底,灯座
171. base address register ==> 基址寄存器
172. base bias ==> 基极偏压
173. base electrode ==> 基极
174. base insulator ==> 支座绝缘子
175. base line ==> 基线
176. base-load ==> 基本负荷,基底负荷
177. base-load capacity ==> 基荷容量
178. base-load control ==> 基荷控制
179. base-load generator ==> 基荷发动机,基底负载发电机
180. base-load heat source ==> 基本热源
181. base-load hydro-plant ==> 基荷水电站
182. base-load operation ==> 基荷运行
183. base-load plant ==> 基荷发电厂
184. base-load power ==> 基荷动力
185. base-load power station ==> 基荷电站
186. base-load regime ==> 基荷工况
187. base-load station ==> 基底负载发电厂
188. base-load supply ==> 基荷电源
189. base-load thermal power plant ==> 基本负荷火力发电厂
190. base-load turbine ==> 基荷汽轮机
191. base-load unit ==> 基荷机组
192. base map ==> 工作草图
193. base metal ==> 母体金属
194. base metal thermocouple ==> 基金属热电偶
195. base peak ==> 基峰
196. base plate ==> 底座板
197. base region ==> 基极区
198. base register ==> 基址寄存器
199. base resistance ==> 基级电阻
200. base terminal ==> 基极引出端
201. base unit(of measurement) ==> 基本(测量)单位
202. baseband LAM ==> 基带局域网
203. baseline drift ==> 基线漂移
204. baseline noise ==> 基线噪声
205. baseline potential ==> 空白电位
206. baseline value ==> 空白值
207. basic industry ==> 基础工业
208. basic network ==> 基本网络
209. basic NMR frequency ==> 基本核磁共振频率
210. basic noise ==> 基本噪声
211. basic operating system ==> 基本操作系统
212. basic standard ==> 基础标准
213. basic time ==> 基本时限
214. basic vector ==> 基本向量
215. basin ==> 硫
216. basket coil ==> 笼形线圈
217. basket removal panel ==> 元件盒检修护板
218. batch control ==> 批量控制
219. batch control station ==> 批量控制站
220. batch inlet ==> 分批进样
221. batch of strain gauge ==> 应变计[片]批
222. batch process ==> 分批法
223. batch processing ==> 成批处理
224. batch processing simulation ==> 批处理仿真
225. batch total ==> 成批总数
226. bathtub curve ==> 浴盆曲线(产品失效曲线),Bathtub curve showing the failure rate of a population of products versus time.
227. battery ==> 电池,蓄电池
228. battery acid ==> 电池酸液
229. battery backup module ==> 电池备用组件
230. battery booster ==> 充电调压器
231. battery capacity ==> 蓄电池容量
232. battery car ==> 蓄电池车
233. battery cell ==> 电池,电瓶,原电池
234. battery charge ==> 蓄电池充电
235. battery charger ==> 蓄电池充电器
236. battery clip ==> 蓄电池夹
237. battery clock ==> 电池钟
238. battery cutout ==> 电池电路自动断路器
239. battery dialing ==> 单线拨号
240. battery drive ==> 蓄电池传动
241. battery driven vehicle ==> 蓄电池车辆
242. battery electric traction ==> 蓄电池牵引
243. battery excited generator ==> 蓄电池励磁发电机
244. battery ignition ==> 蓄电池点火
245. battery in quantity ==> 并联电池组
246. battery insulator ==> 蓄电池绝缘子
247. battery jar ==> 电池槽
248. battery light kit ==> 电池式灯具
249. battery locomotive ==> 蓄电池机车
250. battery plate ==> 蓄电池极板
251. battery polarity ==> 电池端子极性
252. battery-powered ==> 用电池供电的
253. battery rack ==> 蓄电池架
254. battery railcar ==> 电瓶机动车
255. battery room ==> 蓄电池室
256. battery separator ==> 蓄电池极板的隔离板
257. battery solution ==> 电液,蓄电池溶液
258. battery supply ==> 蓄电池电源
259. battery terminal ==> 蓄电池夹
260. battery tester ==> 电池测试器
261. battery truck ==> 电瓶车
262. battery voltage ==> 电池电压
263. battery voltage meter ==> 电瓶电压表
264. Baud ==> 波特
265. baudot code ==> 博多码
266. bayonet base ==> 卡口灯座
267. bayonet cap ==> 卡口灯座
268. bayonet socket ==> 卡口插座
269. bdaring support ==> 支承架
270. BDV, blow down valve ==> 疏水阀,排污阀
271. beacon ==> 信标
272. bead ==> 珠
273. bead thermistor ==> 珠形热敏电阻
274. bead transistor ==> 熔珠晶体管
275. beam ==> 射束,横梁,声速
276. beam angle ==> 射束孔径角
277. beam current ==> 射束电流电子束电流
278. beam deflection type proportional amplifier ==> 射束偏转形比例放大器
279. beam deflection ultrasonic flowmeter ==> 声速偏转式超声流量计
280. beam deflector ==> 电子束偏转器
281. beam hole ==> 束孔
282. beam loading thermobalance ==> 水平式热天平
283. beam path distance ==> 声程
284. beam ratio ==> 声束比
285. beam spot diameter ==> 束斑直径
286. beam width ==> 束流表度
287. bearing ==> 轴承,刀承
288. bearing axis ==> 轴承中心线
289. bearing clearance ==> 轴承间隙
290. bearing friction losses ==> 轴承磨擦损耗
291. bearing wear ==> 轴承磨损
292. beat ==> 拍
293. beat frequency ==> 拍频
294. beat frequency oscillator ==> 拍频振荡器
295. beat indicator ==> 拍差指示器
296. beat method ==> 差拍法
297. beat method (of measurement) ==> 差拍(测量)法
298. Beaufort scale ==> 蒲福风级
299. Beckman differential thermometer ==> 贝克曼温度计
300. bed ==> 机座
301. bed plate ==> 底座板
302. bedding ==> 衬垫
303. Beer‘ law ==> 比尔定律
304. beginning of tape marker ==> 磁带起始标记
305. bel ==> 贝
306. bell ==> 钟
307. bell character ==> 报警符号
308. bell insulator ==> 铃形绝缘子
309. bell manometer ==> 钟罩压力计
310. bell prover ==> 钟罩校准器
311. bell shaped insulator ==> 铃式绝缘子
312. bell shaped pulse ==> 钟形脉冲
313. bell trsnsformer ==> 电铃变压器
314. bellows ==> 波纹管,波绞管
315. bellows coupling ==> 波纹管联轴器
316. bellows pressure gauge ==> 波纹管压力表
317. bellows seal bonnet ==> 波纹管密封型上阀盖
318. bellows type pressure gage ==> 膜盒式压力计
319. bellows type sensor ==> 波纹管型传感器
320. belt ==> 皮带
321. belt brake ==> 带式制动器
322. belt cable ==> 铠装电缆
323. belt drive ==> 皮带传动
324. belt insulation ==> 铠包绝缘
325. bench mark ==> 水准点
326. bench test ==> 试验台上试验
327. benchboard ==> 斜面台
328. benchmark problem ==> 基准问题
329. benchtop supply ==> 工作台电源
330. bend ==> 弯曲
331. bending moment ==> 挠矩
332. bending strength ==> 弯曲强度,抗弯强度
333. bending stress ==> 弯曲应力
334. bending test ==> 反复弯曲试验,弯曲试验
335. bending vibration ==> 弯曲振动
336. bent stem earth thermometer ==> 曲管地温表
337. bessel function ==> 贝塞尔函数
338. Besson nephoscope ==> 贝森测云器
339. betatron ==> 电子回旋加速器,电子感应加速器
340. bezel ring ==> 盖环
341. bi directional vane ==> 双向风向标,双风信标
342. bias ==> 偏
343. bias circuit ==> 偏压电路
344. bias control ==> 偏压控制
345. bias resistance ==> 偏压电阻
346. bias resistor ==> 偏压电阻器
347. bias voltage ==> 偏压
348. bias winding ==> 偏压绕组
349. biased relay ==> 带制动的继电器
350. biaxial cable ==> 双轴电缆
351. bichromate cell ==> 重铭酸电池
352. biconcave ==> 双凹的
353. bid ==> 投标
354. bid bond ==> 投标保证金
355. bid deadline ==> 投标截止日期
356. bid documents ==> 标书
357. bid evaluation ==> 评标
358. bid evaluation criteria ==> 评标准则
359. bid guarantee ==> 投标担保
360. bid invitation ==> 招标
361. bid invitation specification ==> 招标说明书
362. bidder ==> 投标者,投标人
363. bidding condition ==> 投标条件
364. bidding contract ==> 投标契约
365. bidding documents ==> 招标文件
366. bidirectional counter ==> 双向计数器
367. bidirectional diode thyristor ==> 双向二极晶闸管
368. bidirectional drive ==> 双向传动
369. bidirectional transducer ==> 双向变换器
370. bidirectional transistor ==> 双向晶体管
371. bidirectional triode thyristor ==> 双向三极晶闸管
372. bifilar ==> 双线的
373. bifilar coil ==> 双绕线圈
374. bifilar suspension ==> 双线悬吊
375. bifilar winding ==> 双股线圈
376. bifurcational value ==> 分歧值
377. big current ==> 大电流
378. big power network safety and regulation ==> 大电网安全和调控技术
379. big power network,or power grid interconnection,safety and regulation technology ==> 大电网安全和调控技术
380. big power station ==> 大型发电厂
381. bilateral current stabilizer ==> 双向稳流器
382. bilateral impedance ==> 双向阻抗
383. bilateral servomechanism ==> 双向伺服机构
384. bilateral transducer ==> 双向变换器
385. bilateral transistor ==> 双向晶体管
386. billion ==> 十亿
387. bimetal ==> 双金属
388. bimetal controller ==> 双金属调节器
389. bimetal relay ==> 双金属继电器
390. bimetal thermometer ==> 双金属温度计
391. bimetallic ==> 双金属的
392. bimetallic element ==> 双金属元件
393. bimetallic instrument ==> 双金属仪表,双金属式仪表
394. bimetallic plate ==> 双金属板
395. bimetallic strip ==> 双金属条
396. bimetallic temperature transducer[sensor] ==> 双金属温度传感器
397. bimetallic thermometer ==> 双金属温度计
398. bimetallic thermostat ==> 双金属恒温控制器
399. bimetallic wire ==> 双金属线
400. binary ==> 二进制的
401. binary adder ==> 二进加法器
402. binary arithmetic computer ==> 二进制计算机
403. binary base ==> 二进制基数
404. binary bit ==> 二进制位
405. binary cell ==> 二进制元件
406. binary character ==> 二进字符
407. binary circuit ==> 二进位电路
408. binary code ==> 二进码
409. binary code disc ==> 二进符号圆盘
410. binary coded decimal(BCD) ==> 二-十进制编码
411. binary control ==> 二进制控制
412. binary counter ==> 二进制计数器
413. binary digital ==> 二进制数字
414. binary elastic scattering event ==> 双弹性散射过程
415. binary elastic scattering peak ==> 双弹性散射峰
416. binary element ==> 二进制元,二进制元件
417. binary encoding ==> 二进制编码
418. binary flip-flop ==> 二进制触发器
419. binary hologram ==> 二元全息图
420. binary logic ==> 二进制逻辑
421. binary multiplier ==> 二进乘法器
422. binary notation ==> 二进制记数法
423. binary nubmer ==> 二进制数
424. binary number system ==> 二进计数制
425. binary operation ==> 二进制运算
426. binary output ==> 二进制输出
427. binary place ==> 二进制数位
428. binary point ==> 二进制小数点
429. binary recording ==> 二进位记录
430. binary representation ==> 二进位表示
431. binary row ==> 二进制行
432. binary scaler ==> 二进换算电路
433. binary scaling circuit ==> 二进换算电路
434. binary search method ==> 二分检索法
435. binary signal ==> 二进制信号
436. binary to decimal conversion ==> 二十进制变换
437. binary to decimal converter ==> 二进十进制变换器
438. binary translation ==> 二进变换
439. bind ==> 绑缚
440. binder ==> 胶合剂
441. binding ==> 绑扎
442. binding energy ==> 结合能
443. binding material ==> 胶合剂
444. binding wire ==> 扎线
445. binomial ==> 二项式
446. binomial distribution ==> 二项式分布
447. biochemical fuel cell ==> 生化燃料电池
448. biochemical oxygen demand (BOD) microbial transducer[sensor] ==> 微生物BOD传感器
449. biochemical oxygen demand meter for seawater ==> 海水生化需氧量测定仪
450. biochemical quantity transducer[sensor] ==> 生化量传感器
451. bioelectricity ==> 生物电
452. biogalvanic battery ==> 生物电池
453. biography ==> 简历
454. biological dosimetry ==> 生物学剂量测定
455. biological quantity transducer[sensor] ==> 生物量传感器
456. biological shield ==> 生物屏蔽
457. biomedical analyzer ==> 生物医学分析仪
458. bionics ==> 仿生学
459. biopotential ==> 生物电势
460. biosensor ==> 生物传感器
461. Biot number ==> 毕奥数
462. biot savart‘s law ==> 毕奥萨伐尔定律
463. Biot, J.B.Biot ==> 1774-1862,毕奥,法国科学家
464. biotechnology ==> 生物技术
465. bipartition ==> 对分,分为两部分
466. biperiodical regime ==> 双周期状态
467. bipolar ==> 二极的,双极的
468. bipolar armature ==> 双极电枢
469. bipolar armature winding ==> 双极电枢绕组
470. bipolar dynamo ==> 双极发电机
471. bipolar machine ==> 两极电机
472. bipolar motor ==> 两极电动机
473. bipolar transistor ==> 双极晶体管
474. bipolar winding ==> 双极绕组
475. BIPV ==> 建筑物集成太阳能电池
476. biquinary code ==> 二五进制码
477. bird receiving system ==> 吊舱接收系统
478. bisector ==> 等分线
479. bismuth spiral ==> 铋磁探头
480. bistable circuit ==> 双稳定电路
481. bistable device ==> 双稳定装置
482. bistable multivibrator ==> 双稳态多谐振荡器
483. bit ==> 比特,位
484. bit error rate ==> 误码率
485. bit pattern ==> 位组合
486. bit rate ==> 位速率
487. bit serial ==> 位串行
488. bit serial highway ==> 位串行信息公路
489. bits per second ==> 位/秒
490. bitumen insulated wire ==> 沥青绝缘线
491. bitumen insulation ==> 沥青绝缘
492. bivane ==> 双向风向标,双风信标
493. bivariate normal distribution ==> 双变量正态分布
494. black ==> 黑的,炭黑
495. black absorber ==> 黑吸收体
496. black absorber rod ==> 黑吸收棒
497. black alum ==> 黑矾
498. black annealing ==> 初退火
499. black anodized ==> 阳极氧化致黑
500. black ash ==> 黑灰
