查看: 29334|回复: 3
电气及半导体词汇词典-C
    发表于 2010-6-17 13:14:03 | 显示全部楼层 |阅读模式
    转自:http://www.for68.com/jidianyingyu/
    1. C Normal Run Selector Switch ==> C正常运行选择键
    2. C scope ==> C型显示
    3. c to c transport ==> 盒对盒薄片转移
    4. cab ==> 司机室
    5. cab signal ==> 机车信号
    6. cabinet ==> 柜,箱
    7. cabinet panel ==> 配电盘
    8. cable ==> 电缆
    9. cable armor ==> 电缆铠装
    10. cable armoring machine ==> 电缆铠装机
    11. cable attenuation ==> 电缆衰减
    12. cable bearer ==> 电缆支架
    13. cable bond ==> 电缆接头
    14. cable box ==> 电缆套
    15. cable bracket ==> 电缆架
    16. cable bridge ==> 电缆桥
    17. cable capacitance ==> 电缆电容
    18. cable car ==> 电缆车
    19. cable charging current ==> 电缆充电电流
    20. cable chart ==> 电缆图表
    21. cable chute ==> 电缆沟
    22. cable circuit diagram ==> 电缆电路图
    23. cable clamp ==> 电缆夹
    24. cable code ==> 水线电码
    25. cable compound ==> 电缆膏
    26. cable concentrator ==> 集线器集中器
    27. cable conductor ==> 电缆芯线
    28. cable conduit ==> 电缆沟
    29. cable connector ==> 电缆接头,电缆连接器
    30. cable core ==> 电缆芯线
    31. cable coupling ==> 电缆套
    32. cable coupling sleeve ==> 电缆联接套管
    33. cable current transformer ==> 电缆用电流互感器
    34. cable dividing box ==> 电缆分线盒
    35. cable drum ==> 电缆卷筒,电缆盘
    36. cable duct ==> 电缆槽,电缆沟
    37. cable engineering ==> 电缆工程
    38. cable fault ==> 电缆损伤
    39. cable fault detector ==> 电缆故障点检验器
    40. cable fault location ==> 电缆故障点检验
    41. cable gallery ==> 电缆廊道
    42. cable grease ==> 电缆滑脂
    43. cable grip ==> 电缆夹
    44. cable hanger ==> 电缆悬挂钩
    45. cable head ==> 电缆终端盒
    46. cable holder ==> 电缆支架
    47. cable hook ==> 电缆挂钩
    48. cable hut ==> 电缆配线房
    49. cable industry ==> 电缆工业
    50. cable inlet ==> 电缆入口
    51. cable installation ==> 电缆敷设
    52. cable insulation ==> 电缆绝缘
    53. cable insulation compound ==> 电缆膏
    54. cable interference ==> 电缆干扰
    55. cable joint ==> 电缆接头
    56. cable junction box ==> 电缆接线箱
    57. cable laying ==> 电缆敷设
    58. cable layout ==> 电缆敷设图
    59. cable lifting ==> 电缆垂直敷设
    60. cable line ==> 电缆线路
    61. cable locator ==> 电缆探测器
    62. cable lug ==> 电缆终端夹
    63. cable manhole ==> 电缆人孔
    64. cable map ==> 电缆图
    65. cable marker ==> 电缆标志
    66. cable message ==> 水线电报
    67. cable network ==> 电缆线路
    68. cable noise ==> 电缆噪声
    69. cable oil ==> 电缆油
    70. cable pit ==> 电缆井
    71. cable protection ==> 电缆保护
    72. cable quad ==> 电缆四芯线组
    73. cable rack ==> 电缆架
    74. cable railway ==> 缆车铁道
    75. cable reel ==> 电缆盘
    76. cable roller ==> 电缆导轨
    77. cable run ==> 电缆敷设路径
    78. cable saddle ==> 电缆鞍
    79. cable sealing box ==> 电缆密封盒
    80. cable set ==> 电缆附件
    81. cable shaft ==> 电缆竖井
    82. cable sheath ==> 电缆外皮
    83. cable shield ==> 电缆包皮
    84. cable ship ==> 海底电缆敷设船
    85. cable shoe ==> 电缆终端,电缆终端套管,电缆帽
    86. cable short circuit ==> 电缆短路
    87. cable sleeve ==> 电缆接续套
    88. cable specification ==> 电缆规格,电缆规范
    89. cable splice ==> 电缆接合
    90. cable splicing ==> 电缆接合
    91. cable stranding machine ==> 电缆绞合机
    92. cable subway ==> 电缆廊道
    93. cable suspender ==> 电缆悬挂钩
    94. cable tank ==> 电缆槽
    95. cable television ==> 电缆电视
    96. cable tension transducer ==> 电缆张力传感器
    97. cable terminal ==> 电缆端
    98. cable terminating set ==> 电缆终端
    99. cable test ==> 电缆试验
    100. cable testing apparatus ==> 电缆试验装置
    101. cable testing car ==> 电缆测试车
    102. cable trailer ==> 电缆盘拖车
    103. cable trailing device ==> 电缆拖拉装置
    104. cable transmission ==> 电缆传输
    105. cable trench ==> 电缆沟
    106. cable trough ==> 电缆暗渠
    107. cable type current transformer ==> 电缆式电流互感器
    108. cable vault ==> 电缆地下室
    109. cable winch ==> 电缆绞车
    110. cable with pilot core ==> 有控制芯的电缆
    111. cablegram ==> 水线电报
    112. cableway ==> 缆道
    113. cabling ==> 敷设电缆
    114. cabtyre cable ==> 厚橡胶软电缆
    115. cabtyre cord ==> 厚橡胶软线
    116. CAD system ==> 计算机辅助设计系统
    117. CAD technique ==> 计算机辅助设计技术
    118. CAD tools ==> 计算机辅助设计工具
    119. CAD workstation ==> 计算机辅助设计工作站
    120. CAD, computer aided design ==> 计算机辅助设计
    121. cadmium ==> 镉
    122. cadmium cell ==> 镉电池
    123. cadmium regulator ==> 镉调节棒
    124. cadmium standard element ==> 标准镉电池
    125. cadmium sulfide photocell ==> 硫化镉光电池
    126. cage ==> 套筒,潜水罐笼
    127. cage antenna ==> 笼形天线
    128. cage dipole ==> 笼形偶极子
    129. cage grid ==> 笼形栅极
    130. cage guiding ==> 套筒导向
    131. cage ring ==> 短路环
    132. cake adhesive retention meter ==> 泥饼粘滞性测定仪
    133. calcination ==> 烧成
    134. calcium carbide furnace ==> 电石炉
    135. calcuated nornal folw coefficient ==> 正常计算流量系数
    136. calculagraph ==> 计时器
    137. calculated maximum flow coefficient ==> 最大计算流量系数
    138. calculating machine ==> 计算机
    139. calculus of variations ==> 变分法
    140. calibrate ==> 定标,校准
    141. calibrated measuringpvolumetric]tank ==> 校准测量[容积计量]容器
    142. calibrated shunt ==> 校准过的分流
    143. calibrating period ==> 校准周期
    144. calibrating terminal ==> 试验端子
    145. calibrating voltage ==> 校准电压
    146. calibration ==> 校准
    147. calibration (of thermometer) ==> (温度计的)标定
    148. calibration accuracy ==> 校准精度
    149. calibration block ==> 标准试块
    150. calibration characteristics ==> 校准特性,分度特性
    151. calibration coefficient of wave height ==> 波高校正系数
    152. calibration component ==> 校准组分
    153. calibration curve ==> 校准曲线,分度曲线
    154. calibration cycle ==> 校准循环
    155. calibration equation ==> 校准公式分度公式
    156. calibration equipment of reversing thermometers ==> 颠倒温度表检定设备
    157. calibration factor of the primary device ==> 一次装置的校准系数
    158. calibration gas mixture ==> 校准混合气
    159. calibration hierarchy ==> 校准层次
    160. calibration instrument ==> 校准仪表
    161. calibration point ==> 校准点,分度点
    162. calibration quantity ==> 校准量
    163. calibration record ==> 校准记录
    164. calibration resistance ==> 校准电阻
    165. calibration rotor ==> 标定转子
    166. calibration scale ==> 校准度盘
    167. calibration solution ==> 校准液
    168. calibration table ==> 校准表(格)
    169. calibration test ==> 校准试验
    170. calibration traceability ==> 校准溯源性
    171. calibration voltage ==> 校准电压
    172. calibrator ==> 校准器,校验器
    173. calibrator above ice point ==> 零上检定器
    174. calibrator below ice point ==> 零下检定器
    175. calibrator for ice point ==> 零点检定器
    176. caliper profiler ==> 横幅厚度计
    177. call ==> 呼叫
    178. call acceptance ==> 呼叫接受
    179. call bell ==> 呼叫铃
    180. call count ==> 通话计数
    181. call finder ==> 呼叫选择器
    182. call forward operation ==> 呼叫转发电话
    183. call forwarding ==> 呼叫转发电话
    184. call in operation ==> 呼叫转发电话
    185. call indicator ==> 呼叫指示器
    186. call instruction ==> 呼叫指令
    187. call sign ==> 呼号
    188. call signal ==> 呼叫信号
    189. call switch ==> 呼叫转换开关
    190. call waiting ==> 得等待
    191. call wire ==> 呼叫线路
    192. callback ==> 回叫
    193. called line ==> 被叫线
    194. calling ==> 呼叫
    195. calling cord ==> 呼叫塞绳
    196. calling device ==> 呼叫装置
    197. calling key ==> 呼叫键
    198. calling lamp ==> 呼叫灯
    199. calling machine ==> 铃龙,铃流发生器,振铃发电机
    200. calling on signal ==> 引导信号
    201. calling plug ==> 呼叫插塞
    202. calling relay ==> 呼叫继电器
    203. calling subscriber ==> 中用户
    204. calomel ==> 甘汞
    205. calomel electrode ==> 甘汞电极
    206. calomel half cell ==> 甘汞半电池
    207. calorie ==> 卡
    208. calorific power ==> 发热量
    209. calorific value ==> 发热量
    210. calorifier ==> 加热器
    211. calorimeter ==> 热量计,量热器
    212. calorimetric power measurement ==> 热量计式功率测量法
    213. calorimetric test ==> 热值测定试验
    214. calorimetry ==> 量热测定
    215. cam bezel ring ==> 卡口式盖环
    216. cam operated switch ==> 凸轮操纵开关
    217. cam program control ==> 凸轮程序控制
    218. CAMAC branch driver ==> CAMAC分支驱动器
    219. CAMAC branch highway ==> CAMAC分支信息公路
    220. CAMAC compatible crate ==> CAMAC兼容机箱
    221. CAMAC crate ==> CAMAC机箱
    222. CAMAC crate assembly ==> CAMAC机箱装置
    223. CAMAC highway ==> CAMAC信息公路
    224. CAMAC module ==> CAMAC模块
    225. CAMAC operation ==> CAMAC操作
    226. CAMAC parallel highway ==> CAMAC并行信息公路
    227. CAMAC serial driver ==> CAMAC串行驱动器
    228. CAMAC serial highway ==> CAMAC串行信息公路
    229. CAMAC system ==> CAMAC系统
    230. camber ==> 挠曲
    231. camber free ceramics ==> 无弯曲的陶瓷
    232. cambric ==> 黄蜡布
    233. cambric insulated wire ==> 黄蜡布绝缘电线
    234. camera ==> 照相机,摄像机
    235. camera alignment ==> 摄像机导
    236. camera chain ==> 摄像机系统
    237. camera length ==> 相机长度
    238. camera lens ==> 摄影机镜头
    239. camera signal ==> 电视摄像机信号
    240. camera tube ==> 电视摄像管
    241. camflex valve ==> 偏心旋转阀
    242. camp ==> 计算机辅助掩模制备
    243. camp on ==> 得等待
    244. Campbell stokes sunshine recorder ==> 聚集日照计,歇贝斯托克日照计
    245. campell diagram ==> 叶片埃贝尔曲线
    246. can ==> 金属盒
    247. canal rays ==> 阳极射线
    248. canal system power station ==> 运河型水电站
    249. cancellation ==> 熄灭
    250. cancelling ==> 熄灭
    251. candela ==> 新烛光
    252. candela per square meter ==> 新烛光/平方米
    253. candelabra base ==> 蜡台形灯座
    254. candelabrum ==> 烛台
    255. candidate species ==> 可替代的物质
    256. candle ==> 烛
    257. candle lamp ==> 烛形灯
    258. canonical form ==> 标准形
    259. canonical state variable ==> 规范化状态变量
    260. canopy ==> 灯罩
    261. cantilever ==> 悬臂支架
    262. cantilever crane ==> 悬臂起重机
    263. cap ==> 灯座
    264. cap and pin insulator ==> 帽盖针形绝缘子
    265. cap lamp ==> 头灯
    266. cap layer ==> 保护层
    267. cap plate ==> 底板
    268. capability ==> 可能输出功率
    269. capacimeter ==> 电容测量表
    270. capacitance ==> 电容
    271. capacitance balance ==> 电容平衡
    272. capacitance box ==> 电容箱
    273. capacitance bridge ==> 电容电桥
    274. capacitance hygrometer ==> 电视湿度计
    275. capacitance meter ==> 电容测试器
    276. capacitance per unit length ==> 单位长度电容
    277. capacitance pontential device ==> 电容电位计
    278. capacitance pressure transducer ==> 电容式压力传感器
    279. capacitance standard ==> 电容标准
    280. capacitance to case ==> 对壳电容
    281. capacitance to earth ==> 对地电容
    282. capacitance transducer ==> 电容传感器
    283. capacitive bridge ==> 电容电桥
    284. capacitive circuit ==> 电容电路
    285. capacitive component ==> 电容性分量
    286. capacitive coupling ==> 电容性耦合,电容耦合
    287. capacitive current ==> 电容性电流
    288. capacitive diaphragm ==> 电容性窗膜
    289. capacitive divider ==> 电容分压器
    290. capacitive feedback ==> 电容反馈
    291. capacitive impedance ==> 电容性电抗
    292. capacitive iris ==> 电容性窗膜
    293. capacitive load ==> 电容性负载
    294. capacitive micrometer ==> 电容式测微计
    295. capacitive reactance ==> 电容性电抗
    296. capacitive sawtooth generator ==> 电容式锯齿波发生器
    297. capacitive strip ==> 电容带
    298. capacitive susceptance ==> 电容性电纳
    299. capacitive transducer ==> 电容式转换器
    300. capacitive tuning ==> 电容调谐
    301. capacitive unbalance ==> 电容不平衡
    302. capacitive voltage divider ==> 电容分压器
    303. capacitive window ==> 电容性窗口
    304. capacitively loaded line ==> 电容性负载线
    305. capacitor ==> 电容器
    306. capacitor bank ==> 电容器组
    307. capacitor braking ==> 电容器制动
    308. capacitor capacitance ==> 电容器电容
    309. capacitor coupled fet logic ==> 电容耦合式场效应晶体管逻辑
    310. capacitor discharge ==> 电容器放电
    311. capacitor insulation ==> 电容器绝缘
    312. capacitor motor ==> 电容器式电动机
    313. capacitor network ==> 电容器网络
    314. capacitor oil ==> 电容器[绝缘]油
    315. capacitor paper ==> 电容器纸
    316. capacitor parasitics ==> 寄生电容器
    317. capacitor plate ==> 电容偏板
    318. capacitor probe ==> 电容式探针
    319. capacitor start and run motor ==> 电容起动运转电动机
    320. capacitor start motor ==> 电容起动式电动机
    321. capacitor starting ==> 电容起动
    322. capacitor voltage ==> 电容电压
    323. capacitor voltage characteristic ==> 电容电压特性
    324. capacity ==> 容量,电容量
    325. capacity balancing ==> 电容平衡
    326. capacity bridge ==> 电容电桥
    327. capacity correction ==> 容量修正
    328. capacity coupling ==> 电容耦合
    329. capacity factor ==> 容量因子,设备利用率
    330. capacity measurement ==> 电容测试
    331. capacity of electric power supply ==> 供电能力
    332. capacity of line to earth ==> 对地线路电容
    333. capacity probe ==> 容量探示器
    334. capacity test ==> 容量试验
    335. capacity unbalance ==> 电容性失衡
    336. capillarity ==> 毛细管现象
    337. capillary clogging ==> 毛细管堵塞
    338. capillary column ==> 毛细管柱
    339. capillary electrometer ==> 毛细管静电计
    340. capillary gas chromatograph ==> 毛细管气相色谱仪
    341. capillary gas chromatography ==> 毛细管气相色谱法
    342. capillary phenomenon ==> 毛细现象
    343. capillary tube ==> 毛细管
    344. capillary tube of liquid in glass thermometer ==> 玻璃温度计的毛细管
    345. capillary viscometer ==> 毛细管粘度计
    346. capless annealing ==> 无覆盖退火
    347. capping ==> 覆盖
    348. capping annealing ==> 覆盖退火
    349. capping oxidation ==> 覆盖氧化
    350. capping oxide ==> 覆盖氧化物
    351. capstan ==> 织轮
    352. capstan amplifier ==> 转矩放大器
    353. capsulation ==> 封装
    354. capsule ==> 膜盒
    355. capsule (pressure) gauge ==> 膜盒压力表
    356. captive chains calibration ==> 链码校准
    357. captive production ==> 专用生产
    358. capture ==> 捕获
    359. capture cross section ==> 俘获截面
    360. capture of particles ==> 粒子俘获
    361. capture region ==> 俘获区域
    362. capture time ==> 捕获时间
    363. car kilometer ==> 车辆公里
    364. car lighting ==> 车辆照明
    365. car lighting generator ==> 车辆照妹发电机
    366. car radio ==> 汽车收音机
    367. car receiver ==> 汽车接收机
    368. car signal ==> 机车信号
    369. car to car communication ==> 车辆间通讯
    370. carat balance ==> 克拉天平
    371. carbon ==> 碳
    372. carbon and hydrogen analysis meter ==> 碳氢元素分析仪
    373. carbon arc ==> 碳弧
    374. carbon arc cutting ==> 碳弧切割
    375. carbon arc lamp ==> 碳弧灯
    376. carbon arc welding ==> 碳弧焊
    377. carbon arrester ==> 碳精避雷器
    378. carbon black ==> 碳黑
    379. carbon breaker ==> 碳断路器
    380. carbon brush ==> 碳刷
    381. carbon cell ==> 碳极电池
    382. carbon coating ==> 涂碳层
    383. carbon diaphragm ==> 炭膜
    384. carbon dioxide laser ==> 二氧化碳激光器
    385. carbon electrode ==> 碳电极
    386. carbon filament ==> 碳丝
    387. carbon filament lamp ==> 炭丝灯
    388. carbon film resistor ==> 碳膜电阻器
    389. carbon filter ==> 活性碳过滤器
    390. carbon granule ==> 碳粒
    391. carbon granule microphone ==> 炭粒式话筒
    392. carbon holder ==> 炭棒握
    393. carbon humidity dependent resistor ==> 碳湿敏电阻器
    394. carbon markets ==> 排污权交易市场
    395. carbon mircrophone ==> 炭精式话筒
    396. carbon offsets ==> 污染物控制和减排
    397. carbon porous electrode ==> 多孔碳精电极
    398. carbon resistance ==> 碳电阻
    399. carbon resistor ==> 碳电阻器
    400. carbon rheostat ==> 碳变阻器
    401. carbon rod ==> 碳棒
    402. carbon trading ==> 排污权交易
    403. carbonization ==> 增碳
    404. carbonyl iron dust ==> 羰基铁粉
    405. carborundum ==> 金刚砂
    406. carburettor ==> 气化器
    407. carcass ==> 机座
    408. Carcel lamp ==> 卡索灯
    409. carcinotron ==> 返波管
    410. carcinotron oscillator ==> 返波管振荡器
    411. card ==> 插件,卡,卡片
    412. card punch ==> 卡片穿孔机
    413. card reader ==> 卜片阅读机,穿孔卡片阅读器
    414. card stacker ==> 迭卡片机
    415. card to tape converter ==> 卡片磁带转换器
    416. cardan drive ==> 万向关节传动
    417. cardboard ==> 纸板
    418. cardioid diagram ==> 心脏形曲线图
    419. cardioid microphone ==> 心形传声器单向传声器
    420. cardioid pattern ==> 心脏形曲线图
    421. cardioidal reception ==> 心形方向图接收
    422. carey foster bridge ==> 凯雷福斯脱电桥
    423. carlite insulation ==> 一种绝缘层
    424. Carlson type strain gauge ==> 卡尔逊应变计
    425. carmine ==> 深红色的
    426. carnation ==> 粉红色
    427. carriage return ==> 字盘返回
    428. carrier ==> 载波
    429. carrier amplitude ==> 载波振幅
    430. carrier amplitude regulation ==> 载波幅度调节
    431. carrier balance ==> 载波平衡
    432. carrier capture ==> 载流俘获
    433. carrier carrier interaction ==> 载流间相互动作
    434. carrier channel ==> 载波信道
    435. carrier control ==> 载波控制
    436. carrier current ==> 载波电流
    437. carrier current communication system ==> 载波通信制
    438. carrier current protection ==> 高频保护装置
    439. carrier current telegraphy ==> 载波电抱
    440. carrier density ==> 载流密度
    441. carrier dificiency ==> 载流耗尽
    442. carrier drift ==> 载流漂移
    443. carrier flutter ==> 载波颤动
    444. carrier frequency ==> 载波频,载波频率
    445. carrier frequency channel ==> 载频信道
    446. carrier frequency pulse ==> 载频脉冲
    447. carrier frequency terminal equipment ==> 载频终端设备
    448. carrier gas ==> 载气
    449. carrier generation ==> 载流生成
    450. carrier generator ==> 载波发生器
    451. carrier heating ==> 载流加热
    452. carrier killer ==> 载流寿命扼杀剂
    453. carrier leak ==> 载波泄漏
    454. carrier lifetime ==> 载流寿命
    455. carrier mobility ==> 载流迁移率
    456. carrier noise ==> 载波噪声,载波噪音
    457. carrier pair generation ==> 载流对发生
    458. carrier pipe ==> 输送管
    459. carrier recombination ==> 载流复合
    460. carrier relay ==> 载波继电器
    461. carrier relay protecting device ==> 载波中继保护装置
    462. carrier relaying ==> 载波继电保护,高频保护
    463. carrier repeater ==> 载波增音机
    464. carrier ring ==> 夹持环
    465. carrier sense ==> 载波侦听
    466. carrier sense multiple access with collision detection(CSMA/CD) ==> 具有冲突检测的载波侦听多路访问
    467. carrier socket ==> 插座
    468. carrier spacing ==> 载波间隔
    469. carrier storage ==> 载流存储
    470. carrier suppression ==> 载波抑制
    471. carrier sync ==> 载波同步
    472. carrier synchronization ==> 载波同步
    473. carrier system ==> 载波制
    474. carrier tape ==> 带式载体
    475. carrier telegraphy ==> 载波电抱
    476. carrier telephony ==> 载波电话
    477. carrier to noise ratio ==> 载波信噪比,载波噪声比
    478. carrier transfer ==> 载流传输
    479. carrier transfer device ==> 载流转移装置
    480. carrier transit time ==> 载流渡越时间
    481. carrier transmission ==> 载波传输
    482. carrier transport ==> 载流输运
    483. carrier wave ==> 载波
    484. carry flip flop ==> 进位触发器
    485. carrying capacity ==> 积载量
    486. carson transformation ==> 卡森变换
    487. carton ==> 纸箱,纸板
    488. cartridge ==> 盒式磁带
    489. cartridge disk ==> 盒式磁盘
    490. cartridge disk drive ==> 盒式磁盘机
    491. cartridge fuse ==> 筒状保安器
    492. carved glass ==> 花雕玻璃
    493. cascade ==> 级联
    494. cascade amplifier ==> 级联放大器
    495. cascade circuit ==> 级联电路
    496. cascade connected ==> 级联的
    497. cascade connection ==> 串级连接,级联
    498. cascade control ==> 串级控制
    499. cascade converter ==> 串联变换器
    500. cascade generator ==> 串级发电机
     楼主| 发表于 2010-6-17 13:16:40 | 显示全部楼层
    回复:电气及半导体词汇词典-C
    1501. cmos process ==> cmos工艺
    1502. cmos transistor ==> 互补mos晶体管
    1503. cmosic cmos ==> 集成电路
    1504. cmr ==> 共横抑制
    1505. cmrr ==> 共模抑制比
    1506. cmv ==> 共模电压
    1507. CNC ==> 计算机数控
    1508. co channel interference ==> 同波道干扰,同频道干扰
    1509. co diffusion ==> 同时扩散
    1510. co-financier ==> 联合投资者
    1511. co-financing ==> 联合集资
    1512. co ordination of insulation ==> 绝缘配合
    1513. co ordination with SCPD,q,r current tests“SCPD” ==> 配合“q”“r”电流试验
    1514. co3laser communication ==> 二氧化碳激光通信
    1515. coagulation ==> 凝固
    1516. coal ==> 煤
    1517. coal breaker ==> 碎煤机
    1518. coal bunker ==> 煤斗
    1519. coal consumption ==> 耗煤量
    1520. coal conveyor ==> 运煤机
    1521. coal crusher ==> 碎煤机
    1522. coal drier ==> 煤干燥器
    1523. coal dust ==> 煤粉
    1524. coal gas ==> 煤气
    1525. coal microphone ==> 炭精送话器
    1526. coal washer ==> 洗煤机
    1527. coal yard ==> 煤场
    1528. coalite ==> 半焦炭
    1529. coanda effect ==> 期效应
    1530. Coanda effect ==> 附壁效应
    1531. coarse adjustment ==> 粗调
    1532. coarse alignment ==> 粗对准
    1533. coarse control ==> 粗调
    1534. coarse control rod ==> 粗掉
    1535. coarse reading ==> 粗读数
    1536. coarse synchronizing ==> 粗同步
    1537. coarse tuning ==> 粗调谐,粗调平直调谐
    1538. coarse vacuum ==> 粗真空,前级真空
    1539. coast station ==> 海岸台
    1540. coastal refraction ==> 海岸折射
    1541. coastal transmitter ==> 海岸发射机
    1542. coastal zone color scanner(CZCS) ==> 海岸带水色扫描仪
    1543. coasting ==> 惰行
    1544. coasting method ==> 惰行法
    1545. coated electrode ==> 敷料焊条
    1546. coated optical fiber ==> 涂层光学纤维
    1547. coater ==> 涂料器
    1548. coating ==> 复盖层,涂层,覆盖
    1549. coating composition ==> 涂层成分
    1550. coating striation ==> 涂层条纹
    1551. coaxial ==> 同轴的
    1552. coaxial antenna ==> 同轴天线
    1553. coaxial attenuator ==> 同轴衰减器
    1554. coaxial cable ==> 同轴电缆
    1555. coaxial cavity ==> 同轴空腔谐振器
    1556. coaxial conductor ==> 同轴导线
    1557. coaxial connector ==> 同轴连接器
    1558. coaxial feeder ==> 同轴传输线
    1559. coaxial filter ==> 同轴滤波器
    1560. coaxial line ==> 同轴线
    1561. coaxial line circulator ==> 同轴环形器
    1562. coaxial line resonator ==> 同轴线谐振器
    1563. coaxial phase shifter ==> 同轴移相器
    1564. coaxial probe ==> 同轴探针
    1565. coaxial resonator ==> 同轴谐振器
    1566. coaxial short ==> 同轴短路
    1567. coaxial stub ==> 同轴短线
    1568. coaxial switch ==> 同轴转换开关
    1569. coaxial to waveguide transducer ==> 同轴线波导管匹配变换器
    1570. coaxial transmission line ==> 同轴传输线
    1571. coaxial tuner ==> 同轴调谐器
    1572. coaxial wavemeter ==> 同轴波长计
    1573. coaxiality ==> 同轴度
    1574. cobalt ferrite ==> 铁酸钴
    1575. cock ==> 龙头
    1576. cockcroft walton accelerator ==> 科克罗夫特沃尔顿加速器
    1577. codan ==> 载频控制的干扰抑制器
    1578. code ==> 代码,代号,规程,规范,符号
    1579. code book ==> 电码本
    1580. code chip ==> 代码单元
    1581. code combination ==> 代码组合
    1582. code conversion ==> 代码转换
    1583. code converter ==> 代码转换器
    1584. code dictionary ==> 电码本
    1585. code division multiple access ==> 分码多址访问
    1586. code element ==> 代码单元,电码单元
    1587. code extension character ==> 代码扩充字符
    1588. code message ==> 编码信息
    1589. code modulation ==> 编码调制
    1590. code point ==> 码点
    1591. code selector ==> 选码器
    1592. code signal ==> 编码信号
    1593. code transformation ==> 代码转换
    1594. code translation ==> 译码
    1595. code translator ==> 代码转换器译码器
    1596. code transmission ==> 符号传输
    1597. code transparent data communication ==> 代码透明的数据通信
    1598. code unit ==> 代码单元
    1599. codec ==> 编码译码器
    1600. coded circle ==> 编码度盘
    1601. coded hologram ==> 编码全息照相
    1602. coded identification ==> 符号辨识
    1603. coded program ==> 编码程序
    1604. coded signal ==> 编码信号
    1605. coder ==> 编码器
    1606. coder decoder ==> 编码译码器
    1607. coding ==> 编码
    1608. coefficient ==> 系数
    1609. coefficient for orifice ==> 孔口系数
    1610. coefficient matrix ==> 系数矩阵
    1611. coefficient of absorption ==> 吸收系数
    1612. coefficient of accumulation of heat ==> 蓄热系数
    1613. coefficient of admission ==> 充满系数
    1614. coefficient of aerodynamic force ==> 气动系数
    1615. coefficient of air infiltration ==> 透风系数
    1616. coefficient of air resistance ==> 空气阻力系数
    1617. coefficient of amplification ==> 放大系数
    1618. coefficient of area ==> 面积系数
    1619. coefficient of atmospheric transparency ==> 大气透明度
    1620. coefficient of attenuation ==> 衰减系数
    1621. coefficient of autocorrelation ==> 自相干系数
    1622. coefficient of blackness ==> 黑度系数
    1623. coefficient of brightness ==> 亮度系数
    1624. coefficient of building occupation ==> 建筑系数
    1625. coefficient of capacitance ==> 电容系数
    1626. coefficient of capacity ==> 电容系数
    1627. coefficient of charge ==> 占空系数,装载系数
    1628. coefficient of chromatic aberration ==> 色差系数
    1629. coefficient of combination ==> 组合系数
    1630. coefficient of compressibility ==> 压缩系数
    1631. coefficient of condenser coupling ==> 电容耦合系数
    1632. coefficient of conductivity ==> 传导系数
    1633. coefficient of consolidation ==> 固结系数
    1634. coefficient of contraction ==> 收缩系数
    1635. coefficient of convection ==> 对流系数
    1636. coefficient of correction ==> 修正系数
    1637. coefficient of correlation ==> 相关系数
    1638. coefficient of coupling ==> 耦合系数
    1639. coefficient of cubical expansion ==> 体积膨胀系数
    1640. coefficient of damping ==> 阻尼系数
    1641. coefficient of deformation ==> 变形系数
    1642. coefficient of dependent ==> 带眷系数
    1643. coefficient of deviation ==> 偏差系数,离差系数
    1644. coefficient of dielectrical loss ==> 介质损耗系数,介电常数
    1645. coefficient of diffusion ==> 扩散系数
    1646. coefficient of dilatation ==> 膨胀系数
    1647. coefficient of dilution ==> 稀释系数
    1648. coefficient of discharge ==> 放电系数,流量系数
    1649. coefficient of drag ==> 阻力系数
    1650. coefficient of ductility ==> 延性系数
    1651. coefficient of earth pressure ==> 土压力系数
    1652. coefficient of effect of action ==> 作用效应系数
    1653. coefficient of effective heat emission ==> 散热量有效系数
    1654. coefficient of efficiency ==> 效率
    1655. coefficient of elasticity ==> 弹性系数
    1656. coefficient of electron coupling ==> 电子耦合系数
    1657. coefficient of electrostatic induction ==> 静电感应系数
    1658. coefficient of elongation ==> 伸长系数
    1659. coefficient of emission ==> 放射系数
    1660. coefficient of expansion ==> 膨胀系数
    1661. coefficient of extension ==> 伸长系数,延伸率
    1662. coefficient of fatigue ==> 疲劳系数
    1663. coefficient of feedback ==> 反馈系数
    1664. coefficient of fineness ==> 细度系数
    1665. coefficient of flow ==> 流量系数
    1666. coefficient of frequency modulation ==> 调频系数
    1667. coefficient of friction ==> 摩擦系数
    1668. coefficient of grounding ==> 接地系数
    1669. coefficient of heat conductivity ==> 导热系数
    1670. coefficient of heat expansion ==> 热膨胀系数
    1671. coefficient of heat passage ==> 导热系数
    1672. coefficient of heat supply ==> 供热系数
    1673. coefficient of heat transfer ==> 传热系数
    1674. coefficient of heat transmission ==> 传热系数
    1675. coefficient of hydraulic stability ==> 水力稳定性系数
    1676. coefficient of hysteresis ==> 磁滞损失系数
    1677. coefficient of induction ==> 诱导系数,感应系数
    1678. coefficient of inductive coupling ==> 感应耦合系数
    1679. coefficient of interference ==> 干扰系数
    1680. coefficient of internal friction ==> 内摩擦系数
    1681. coefficient of leakage ==> 泄漏系数
    1682. coefficient of leaking ==> 泄漏系数
    1683. coefficient of lift ==> 升力系数
    1684. coefficient of linear expansion ==> 线膨胀系数
    1685. coefficient of local heat loss ==> 局部热损失系数
    1686. coefficient of local resistance ==> 局部阻力系数
    1687. coefficient of losses ==> 损耗系数
    1688. coefficient of magnetic dispersion ==> 漏磁系数
    1689. coefficient of magnetic leakage ==> 漏磁系数
    1690. coefficient of magnetization ==> 磁化系数,磁化率
    1691. coefficient of mean value ==> 均值系数
    1692. coefficient of modulation ==> 调制系数
    1693. coefficient of mutual induction ==> 互感系数
    1694. coefficient of non-linear distortion ==> 非线性失真系数
    1695. coefficient of nozzle loss ==> 喷嘴损失系数
    1696. coefficient of of preventative maintenance ==> 预防性安全系数
    1697. coefficient of opacity ==> 不透明系数
    1698. coefficient of oxidation ==> 氧化系数
    1699. coefficient of performance ==> 性能系数
    1700. coefficient of permeability ==> 渗透系数
    1701. coefficient of phase displacement ==> 相位移系数
    1702. coefficient of phase modulation ==> 调相系数
    1703. coefficient of pipe-line orifice ==> 管路的孔口系数
    1704. coefficient of potential ==> 电位系数
    1705. coefficient of proportionality ==> 比例系数
    1706. coefficient of purification ==> 净化系数
    1707. coefficient of radial distortion ==> 径向畸变系数
    1708. coefficient of recovery ==> 回收率
    1709. coefficient of regime ==> 状态系数
    1710. coefficient of resistance ==> 电阻系数
    1711. coefficient of rigidity ==> 刚性系数
    1712. coefficient of rolling friction ==> 滚动摩擦系数
    1713. coefficient of rotational distortion ==> 旋转畸变系数
    1714. coefficient of safety ==> 安全系数
    1715. coefficient of scattering ==> 散射系数
    1716. coefficient of seepage ==> 渗漏系数
    1717. coefficient of self-induction ==> 自感系数
    1718. coefficient of soil reaction ==> 地基系数
    1719. coefficient of sound absorption ==> 吸音系数
    1720. coefficient of sound energy ==> 声能反射率
    1721. coefficient of spherical aberration ==> 球差系数
    1722. coefficient of stabilization ==> 稳定系数
    1723. coefficient of stiffness ==> 刚性系数
    1724. coefficient of thermal conductivity ==> 导热系数
    1725. coefficient of thermal efficiency ==> 热膨胀系数
    1726. coefficient of thermal expansion ==> 热膨胀系数
    1727. coefficient of thermal insulation ==> 热绝缘系数
    1728. coefficient of thermal transmission ==> 传热系数
    1729. coefficient of thrust ==> 推力系数
    1730. coefficient of transformation ==> 转换系数
    1731. coefficient of transparency ==> 透明系数
    1732. coefficient of turbulence ==> 紊流系数
    1733. coefficient of underrating ==> 作功不足系数
    1734. coefficient of utilization ==> 利用系数
    1735. coefficient of utilization maximum load ==> 最大负荷利用系数
    1736. coefficient of utilization of installed capacity ==> 装机容量利用系数
    1737. coefficient of vapour permeability ==> 蒸汽渗透系数
    1738. coefficient of vapour permeation ==> 蒸汽渗透系数
    1739. coefficient of variation ==> 变化系数,变异系数
    1740. coefficient of velocity ==> 速度系数
    1741. coefficient of viscosity ==> 粘性系数
    1742. coefficient of waste ==> 废料系数
    1743. coefficient potentiometer ==> 系数式电位计
    1744. coefficient-setting potentiometer ==> 系数设置电势计
    1745. coefficient structural ==> 结构系数
    1746. coefficient tape ==> 系数带
    1747. coefficient unit ==> 系数给定部件
    1748. Coelinvar ==> 克爱里伐合金
    1749. coercive field strength ==> 矫顽磁场强度
    1750. coercive force ==> 矫顽磁力
    1751. coercivity ==> 矫顽性
    1752. coercivity meter ==> 矫顽力计
    1753. coevaporation ==> 同时蒸发
    1754. coexistance phases ==> 共存相
    1755. coexistance region ==> 双相区
    1756. coexistence border ==> [双相]分界线
    1757. coexistence curve ==> 饱和线,分界线,共存线
    1758. coexistence region ==> 双相区
    1759. cofactor ==> 余因子
    1760. cofferdam ==> 围堰
    1761. cofferdam pilling ==> 围堰板桩
    1762. coffin ==> 容器
    1763. coffinite ==> 铀石
    1764. cogeneration ==> 共生,热电联产,热电合供,热电联供
    1765. cogeneration power plant ==> 热电厂
    1766. cogeneration turbine ==> 供热汽轮机
    1767. cogging ==> 接头
    1768. cogging torque ==> 齿槽效应转矩
    1769. coherence measurement ==> 相干性测量
    1770. coherent ==> 相干的,连贯的,相关的,粘附的,相参的,耦合的,相联接的
    1771. coherent acceleration ==> 相干加速
    1772. coherent amplification ==> 相干放大
    1773. coherent boundary ==> 共格晶界
    1774. coherent carrier system ==> 相干载波系统
    1775. coherent collision ==> 相干碰撞
    1776. coherent cross section ==> 相干截面
    1777. coherent detector ==> 相参检波器,相干检波器
    1778. coherent disturbance ==> 相干扰动
    1779. coherent elastic scattering ==> 相干弹性散射
    1780. coherent generation ==> 相干源
    1781. coherent integral ==> 相干积分
    1782. coherent light ==> 相干光线
    1783. coherent light flux ==> 相干光通量
    1784. coherent light holography ==> 相干光全息术
    1785. coherent neutron scattering ==> 相干中子散射
    1786. coherent noise ==> 相干噪声
    1787. coherent optical arrangement ==> 相干光学装置
    1788. coherent optical radiation ==> 相干光辐射
    1789. coherent optics ==> 相干光学
    1790. coherent oscillation of particles ==> 粒子束相干振荡
    1791. coherent oscillator ==> 相干振荡器
    1792. coherent phase-shift keying ==> 相干相移键控制
    1793. coherent pulse radar ==> 相干脉冲雷达
    1794. coherent radar ==> 相干雷达
    1795. coherent radiation ==> 相干辐射
    1796. coherent reception ==> 相干接收
    1797. coherent rotation ==> 相干转动,一致转动
    1798. coherent scatter ==> 相干散射
    1799. coherent scattering ==> 相干散射
    1800. coherent scattering cross section ==> 相干散射截面
    1801. coherent signal ==> 相干信号
    1802. coherent speckle effect ==> 相干斑纹效应
    1803. coherent sychrotron radiation ==> 相干同步加速辐射
    1804. coherent wave ==> 相干波
    1805. coherer ==> 粉末检波器
    1806. coil ==> 线圈,绕纽
    1807. coil aerial ==> 环形天线
    1808. coil antenna ==> 环形天线
    1809. coil dissipation ==> 线圈耗散
    1810. coil end ==> 线圈端部
    1811. coil end leakage ==> 线圈端漏磁
    1812. coil former ==> 线圈架
    1813. coil galvanometer ==> 线圈式振动子
    1814. coil getter ==> 螺旋管吸气剂
    1815. coil inductance ==> 线圈电感
    1816. coil insulation ==> 线圈绝缘
    1817. coil method ==> 线圈材料,线圈法
    1818. coil pitch ==> 线圈节距
    1819. coil q factor ==> 线圈品质因数
    1820. coil resistance ==> 线圈电阻
    1821. coil section ==> 线圈段
    1822. coil shape factor ==> 线圈形状系数
    1823. coil side ==> 线圈边
    1824. coil span ==> 线圈节距
    1825. coil terminals ==> 线圈端子
    1826. coil to coil insulation ==> 线圈间绝缘
    1827. coil turn counter ==> 线圈圈数计数器
    1828. coil winding ==> 圈式绕组
    1829. coil winding machine ==> 绕线机
    1830. coiled coil filament ==> 盘绕线圈式灯丝
    1831. coiled coil lamp ==> 迭簧丝灯泡
    1832. coiler ==> 绕线机
    1833. coiling ==> 绕
    1834. coin box ==> 投币箱
    1835. coin telephone ==> 投币式公用电话
    1836. coincidence ==> 符合
    1837. coincidence amplifier ==> 重合放大器
    1838. coincidence analyzer ==> 重合分析器
    1839. coincidence circuit ==> 重合电路
    1840. coincidence counter ==> 符合计数管
    1841. coincidence counting ==> 符合计数
    1842. coincidence discrimination ==> 符合鉴别
    1843. coincidence factor ==> 同时最大需用率
    1844. coincidence gate ==> 与电路
    1845. coincidence level ==> 度盘合像装置
    1846. coincident current selection ==> 电流重合法,电流重合选择
    1847. coke ==> 焦炭
    1848. cold carrier ==> 冷载流
    1849. cold cathode ==> 冷阴极
    1850. cold cathode gaseous laser ==> 冷阴极气体激光器
    1851. cold cathode ionization gauge ==> 冷阴极电离真空计
    1852. cold cathode lamp ==> 冷阴极管
    1853. cold cathode source ==> 冷阴极离子源
    1854. cold cathode thratron ==> 冷阴极闸流管
    1855. cold cathode tube ==> 冷阴板电子管
    1856. cold cathode valve ==> 冷阴极管
    1857. cold crucible technology ==> 冷坩埚技术
    1858. cold emission ==> 冷阴极放射
    1859. cold forming ==> 冷模压
    1860. cold junction ==> 冷接点
    1861. cold measurement ==> 冷测定
    1862. cold processing technique ==> 冷加工技术
    1863. cold reserve ==> 冷态备用
    1864. cold resistance ==> 抗寒性
    1865. cold rolled silicon steel plate ==> 冷轧硅钢板
    1866. cold start lamp ==> 冷起动灯
    1867. cold storage ==> 冷藏库
    1868. cold test ==> 寒冷试验
    1869. cold trap chiller ==> 冷捕集器
    1870. cold weld ==> 冷焊
    1871. collapse of frequency ==> 频率崩溃
    1872. collapse of voltage ==> 电压崩溃
    1873. collate ==> 整理
    1874. collating sequence ==> 排序序列
    1875. collation ==> 校对
    1876. collected papers ==> 论文集
    1877. collecting bow ==> 弓形集电器
    1878. collection efficiency ==> 收集效率
    1879. collective lighting ==> 集中供电照明
    1880. collective line ==> 共用线
    1881. collector ==> 集电器,集电极
    1882. collector base capacitance ==> 集电极基极电容
    1883. collector base diode ==> 集电极基极二极管
    1884. collector breakdown ==> 集电极破坏
    1885. collector capacitance ==> 集电极基极电容
    1886. collector characteristic ==> 集电极特性
    1887. collector circuit ==> 集电极电路
    1888. collector current ==> 集电极电流
    1889. collector diffusion ==> 集电极扩散
    1890. collector diffusion isolation ==> 集电极扩散隔离
    1891. collector diffusion isolation technique ==> 集电极扩散隔离技术
    1892. collector electrode ==> 集电极
    1893. collector junction ==> 集电极结
    1894. collector junction capacitance ==> 集电极结电容
    1895. collector mask ==> 集电极掩膜
    1896. collector potential ==> 集电极电位
    1897. collector resistance ==> 集电极电阻
    1898. collector ring ==> 集电环
    1899. collector saturation current ==> 集电极饱和电流
    1900. collector saturation voltage ==> 集电极饱和电压
    1901. collector series resistance ==> 集电极串联电阻
    1902. collector shoe ==> 集电靴
    1903. collector slipper ==> 集电靴
    1904. collector slit ==> 接收器狭缝
    1905. collector to base capacitance ==> 集电极基极电容
    1906. collector to base conductance ==> 集电极基极电导
    1907. collector to emitter conductance ==> 集电极发射极电导
    1908. collimation ==> 视准
    1909. collimation axis ==> 视轴
    1910. collimation line ==> 视准线
    1911. collimator ==> 准直仪
    1912. collinear ==> 同线的,共线的
    1913. collinear array ==> 直排天线阵
    1914. collineation ==> 直射,共线
    1915. collision ==> 冲突碰撞,碰撞
    1916. collision broadening ==> 碰撞展宽
    1917. collision course indicator ==> 航向防撞指示器
    1918. collision cross section ==> 碰撞横截面
    1919. collision density ==> 碰撞密度
    1920. collision detection ==> 冲突检出
    1921. collision excitation ==> 碰撞激发
    1922. collision ionization ==> 碰撞电离
    1923. collision loss ==> 碰撞损失
    1924. collision number ==> 碰撞数
    1925. collisional activation ==> 碰撞激活
    1926. collisional activation mass spectrometer ==> 碰撞激活质谱计
    1927. collisional heating ==> 碰撞发热
    1928. colloidal graphite ==> 胶体石墨
    1929. color balance ==> 彩色平衡
    1930. color balance control panel ==> 彩色平衡控制盘
    1931. color bar ==> 彩条
    1932. color bar generator ==> 彩条信号发生器
    1933. color bar signal ==> 彩条信号
    1934. color bar test pattern ==> 彩条测试图
    1935. color brilliance ==> 彩色亮度
    1936. color cathode ray tube ==> 彩色阴极射线管
    1937. color center formation ==> 色中心形成
    1938. color channel ==> 彩色通路
    1939. color coder ==> 彩色编码器
    1940. color contamination ==> 彩色混杂
    1941. color contrast ==> 彩色对比度
    1942. color control ==> 色彩调节
    1943. color converter ==> 彩色图象变换器
    1944. color decoder ==> 彩色信号解码器
    1945. color difference information ==> 色差信息
    1946. color difference signal ==> 色差信号
    1947. color display device ==> 彩色显示器
    1948. color dividing electrode ==> 彩色分离电极
    1949. color dividing mask ==> 彩色分离掩膜
    1950. color flicker ==> 彩色闪烁
    1951. color hologram ==> 彩色全息照相
    1952. color holography ==> 彩色全息照相术
    1953. color image ==> 彩色图象
    1954. color image separation ==> 彩色图象分离
    1955. color information ==> 彩色信息
    1956. color killer ==> 消色器
    1957. color kinescope ==> 彩色显象管
    1958. color light signal ==> 色灯信号机
    1959. color lighting ==> 彩色照明
    1960. color lock ==> 彩色同步
    1961. color matrix ==> 彩色矩阵
    1962. color modulator ==> 彩色调制器
    1963. color monitor ==> 彩色监视器
    1964. color noise ==> 彩色信号杂波
    1965. color overload ==> 色过饱和
    1966. color pattern ==> 彩色测试图
    1967. color pattern generator ==> 彩色图样信号发生器
    1968. color phase ==> 彩色相位
    1969. color pickup tube ==> 彩色显象管
    1970. color picture screen ==> 彩色电视荧光屏
    1971. color picture signal ==> 彩色图象信号
    1972. color picture tube ==> 彩色显象管
    1973. color picture tube of 110 ==> 110偏转角彩色显象管
    1974. color position signal ==> 彩色位置信号
    1975. color primaries ==> 基色
    1976. color purity adjustment ==> 色纯度调节
    1977. color purity coil ==> 色纯度控制线圈
    1978. color purity ring ==> 色纯度调节环
    1979. color receiver ==> 彩色电视接收机
    1980. color reference signal ==> 彩色基准信号
    1981. color resolution ==> 彩色分解力
    1982. color sensitivity ==> 感色灵敏度
    1983. color stripe filter ==> 彩条滤色器
    1984. color subcarrier lock ==> 彩色副载波锁相
    1985. color synchronizing ==> 彩色同步
    1986. color television ==> 彩色电视
    1987. color television picture tube ==> 彩色显象管
    1988. color television receiver ==> 彩色电视接收机
    1989. color temperature ==> 色温度
    1990. color test signal ==> 彩色测试信号
    1991. color thermometer ==> 色温度计
    1992. color tv tube ==> 彩色显象管
    1993. colored filter ==> 滤色器
    1994. colored lamp ==> 有色灯
    1995. colorimeter ==> 比色计,色度计
    1996. colorimetry ==> 比色法
    1997. colour breakup ==> 色乱
    1998. colour centre ==> 彩色中心
    1999. colour filter ==> 颜色滤光片
    2000. colour matching ==> 配色
     楼主| 发表于 2010-6-17 13:18:06 | 显示全部楼层
    回复:电气及半导体词汇词典-C
    3001. continuous stabilization ==> 连续稳定化
    3002. continuous system ==> 连续系统
    3003. continuous test ==> 持续试验
    3004. continuous test signal controller ==> 连续试验信号控制器
    3005. continuous tuner ==> 连续调谐器
    3006. continuous wave ==> 连续波
    3007. continuous wave doppler radar ==> 连续波多普勒雷达
    3008. continuous wave irradiation ==> 连续波辐照
    3009. continuous wave laser ==> 连续波激光器
    3010. continuous wave laser operation ==> 连续波激光操作
    3011. continuous wave mode ==> 连续波运行
    3012. continuous wave operation ==> 连续波运行
    3013. continuous wave radar ==> 连续波雷达
    3014. continuous welding ==> 连续焊
    3015. continuously adjustable inductor ==> 平滑调节电感线圈
    3016. continuously loaded cable ==> 连续加感电缆
    3017. continuously operating laser ==> 连续工驻光器
    3018. continuously pumped laser ==> 连续激励激光器
    3019. continuously tunable laser ==> 可连续调谐激光器
    3020. continuously variable transformer ==> 连续可调变压器
    3021. continuouslyrunning duty with intermittent loading ==> 间歇负载持续运行方式
    3022. contour ==> 轮廓
    3023. contour line ==> 等位线
    3024. contouring control ==> 轮廓控制
    3025. contraction ==> 收缩
    3026. contraction coefficient ==> 收缩系数
    3027. contraction scale ==> 缩尺
    3028. contrast ==> 对比
    3029. contrast control ==> 对比度调节
    3030. contrast control device ==> 对比度调节装置
    3031. contrast dynamic range ==> 对比度动态范围
    3032. contrast photometer ==> 对比光度计
    3033. contrast range ==> 对比度范围
    3034. contrast ratio ==> 对比度系数
    3035. contrast threshold ==> 对比阈
    3036. contrifugal governor ==> 离心式调速器
    3037. control ==> 控制,管理,调节
    3038. control accuracy ==> 控制精度
    3039. control action ==> 控制动作
    3040. control action coefficient ==> 控制动作系数
    3041. control algorithm ==> 控制算法
    3042. control and protection of UHV AC system ==> UHV控制保护装置
    3043. control apparatus ==> 控制装置
    3044. control area ==> 控制区域
    3045. control area operator ==> [电力系统]控制区域管理员,控制区域管理公司
    3046. control behavior ==> 控制状态
    3047. control block ==> 控制程序块
    3048. control board ==> 控制盘
    3049. control byte ==> 控制字节
    3050. control cable ==> 控制电缆
    3051. control center ==> 等站
    3052. control channel ==> 控制信道
    3053. control character ==> 控制字符
    3054. control characteristic ==> 控制特性
    3055. control chart ==> 控制图
    3056. control circuit ==> 控制电路
    3057. control circuit apparatus ==> 控制电器
    3058. control coefficient ==> 控制系数
    3059. control computer ==> 控制用计算机
    3060. control console ==> 控制台
    3061. control counter ==> 控制计数器
    3062. control current ==> 控制电流
    3063. control curve steepness ==> 控制特性陡度
    3064. control desk ==> 控制台
    3065. control deviation ==> 控制偏差
    3066. control device ==> 控制器,控制装置
    3067. control diffusion ==> 受控扩散
    3068. control domain ==> 控制区域
    3069. control drive ==> 控制装置
    3070. control electrode ==> 控制电极
    3071. control element ==> 控制元件
    3072. control engineering ==> 控制工程
    3073. control equipment ==> 控制设备
    3074. control error ==> 调节误差
    3075. control factor ==> 控制系数
    3076. control field ==> 控制区域
    3077. control function ==> 控制函数
    3078. control gate ==> 控制栅
    3079. control gear ==> 控制机构
    3080. control grid ==> 控制栅
    3081. control interval ==> 控制区间
    3082. control knob ==> 控制按钮
    3083. control limit ==> 控制极限
    3084. control limit switch ==> 控制极限开关
    3085. control line ==> 控制线
    3086. control loop ==> 控制回路
    3087. control magnet ==> 控制磁铁
    3088. control mode ==> 控制方式
    3089. control motor ==> 控制电动机
    3090. control node ==> 操纵节
    3091. control of horizontal synchronization ==> 行同步控制
    3092. control of rotation velocity ==> 旋转速度控制
    3093. control of vertical synchronizing ==> 场同步控制
    3094. control operation ==> 控制操作
    3095. control orifice ==> 控制孔
    3096. control panel ==> 控制盘
    3097. control performance ==> 控制性能
    3098. control phase ==> 控制相位
    3099. control point ==> 控制点
    3100. control precision ==> 控制精密度
    3101. control process ==> 控制过程
    3102. control pulse ==> 控制脉冲
    3103. control range ==> 控制范围
    3104. control rate ==> 控制速度
    3105. control register ==> 指令寄存器控制寄存器
    3106. control relay ==> 控制继电器
    3107. control response ==> 控制响应
    3108. control rod ==> 控制杆
    3109. control rod shock absorber ==> 控制棒缓冲器
    3110. control room ==> 控制室,操纵室,调度室
    3111. control room operator ==> 控制室操纵人员
    3112. control rotary diaphragm ==> 旋转隔板(抽气式汽轮机用)
    3113. control sample ==> 控制试样
    3114. control sequence ==> 控制序列
    3115. control signal ==> 控制信号
    3116. control stability ==> 控制稳定
    3117. control statement ==> 控制语句
    3118. control station ==> 控制站
    3119. control switch ==> 控制开关
    3120. control system ==> 控制系统
    3121. control system analog simulator ==> 控制系相似模似器
    3122. control theory ==> 控制理论
    3123. control time ==> 控制时间
    3124. control track ==> 控制声道
    3125. control unit ==> 控制单元
    3126. control valve ==> 调节阀,调节活门
    3127. control valve gear ==> 调节装置
    3128. control valve plug ==> 调节阀塞
    3129. control valve stand ==> 调节阀阀座
    3130. control variable ==> 控制变量
    3131. control vector ==> 控制矢量
    3132. control voltage ==> 控制电压
    3133. control wave ==> 控制波
    3134. control waveform ==> 控制波形
    3135. control winding ==> 控制绕组
    3136. control wiring diagram ==> 控制接线图
    3137. control with fixed set point ==> 带有固定给定值的控制
    3138. control with microprocesser ==> 微处理机控制
    3139. control word ==> 控制字码
    3140. controllability ==> 可控性
    3141. controlled atmosphere furnace ==> 可控气氛炉
    3142. controlled damping ==> 控制制动
    3143. controlled diode ==> 控制二极管
    3144. controlled flow ==> 控制流
    3145. controlled inductance ==> 可控电感
    3146. controlled junction depth ==> 受控结深度
    3147. controlled member ==> 控制对象
    3148. controlled nuclear reaction ==> 可控核反应
    3149. controlled object ==> 控制对象
    3150. controlled rectifier ==> 可控整流
    3151. controlled switch ==> 受控开关
    3152. controlled system ==> 受控系统
    3153. controlled valve ==> 可控阀
    3154. controlled variable ==> 控制值
    3155. controller ==> 控制器,调节器
    3156. controlling circuit ==> 控制电路
    3157. controlling device ==> 控制装置
    3158. controlling force ==> 控制力
    3159. controlling magnet ==> 控制磁铁
    3160. controlling switch ==> 控制开关
    3161. controlling torque ==> 控制转矩
    3162. convection ==> 对流
    3163. convection bank ==> 对流管束
    3164. convection barrier ==> 对流栅
    3165. convection boiling ==> 对流沸腾
    3166. convection boundary condition ==> 对流边界条件
    3167. convection coefficient ==> 对流放热系数
    3168. convection cooler ==> 对流冷却器
    3169. convection cooling ==> 对流冷却
    3170. convection current ==> 对流电流
    3171. convection current modulation ==> 对流电流计
    3172. convection effect ==> 对流效应
    3173. convection flow ==> 对流流动
    3174. convection heat losses ==> 对流热损失
    3175. convection heat transfer ==> 对流传热
    3176. convection heating ==> 对流加热,对流采暖
    3177. convection heating surface ==> 对流受热面
    3178. convection loss ==> 对流损耗
    3179. convection pass ==> 对流烟道
    3180. convection type heater ==> 对流热器
    3181. convective cooling ==> 对流冷却
    3182. convective heat transfer ==> 对流传热
    3183. convenience receptacle ==> 插座
    3184. conventional efficiency ==> 约定效率
    3185. conventional power plant ==> 常规电站
    3186. conventional programming ==> 常规编程,用标准程序语言编程
    3187. converge ==> 收敛
    3188. convergence ==> 收敛,会聚,聚焦
    3189. convergence circuit ==> 会聚电路
    3190. convergence coil ==> 收敛线圈,会聚线圈,聚焦线圈
    3191. convergence criterion ==> 收敛性判据
    3192. convergence domain ==> 收敛区域
    3193. convergence rate ==> 收敛速度
    3194. convergence transformer ==> 收敛变压器
    3195. convergent control ==> 收敛控制
    3196. convergent control system ==> 收敛控制系统
    3197. convergent matrix ==> 收敛矩阵
    3198. convergent nozzle ==> 收敛喷管
    3199. convergent oscillation ==> 衰减振荡
    3200. convergent series ==> 收敛级数
    3201. conversation ==> 通话
    3202. conversational mode ==> 对话方式
    3203. conversational processing ==> 对话处理
    3204. converse of a relation ==> 逆关系
    3205. converse piezoelectric effect ==> 反压电效应
    3206. conversion ==> 转换,变换
    3207. conversion chart ==> 换算图,换算表
    3208. conversion check ==> 反校验
    3209. conversion cluster ==> 转换棒束元件
    3210. conversion coefficient ==> 转换系数
    3211. conversion conductance ==> 变频互导
    3212. conversion constant ==> 换算常数
    3213. conversion curve ==> 变换曲线
    3214. conversion cycle ==> 转换循环
    3215. conversion device ==> 转换装置
    3216. conversion diagram ==> 转换图
    3217. conversion effect ==> 转换效应
    3218. conversion efficiency ==> 变换效率,转换效率
    3219. conversion electron ==> 转换电子
    3220. conversion equation ==> 转换公式
    3221. conversion equipment ==> 转换装置
    3222. conversion factor ==> 换算率
    3223. conversion fraction ==> 转换系数
    3224. conversion function ==> 转换函数
    3225. conversion gain ==> 转换增益
    3226. conversion integrated circuit ==> 变换集成电路
    3227. conversion level ==> 转化深度
    3228. conversion loss ==> 变换损耗
    3229. conversion of electrical energy ==> 电能变换
    3230. conversion of energy ==> 能量转换
    3231. conversion of heat into power ==> 热功转换
    3232. conversion pig iron ==> 炼钢生铁
    3233. conversion plant ==> 燃料转化厂
    3234. conversion process ==> 燃料转化过程
    3235. conversion program ==> 转换程序
    3236. conversion rate ==> 变换率
    3237. conversion ratio ==> 转换比
    3238. conversion routine ==> 转换子程序
    3239. conversion screen ==> 转换屏
    3240. conversion table ==> 换算表
    3241. conversion time ==> 变换时间
    3242. conversion transconductance ==> 变频互导
    3243. conversion transformer ==> 转换变压器
    3244. conversion unit ==> 反应设备
    3245. conversion zone ==> 转换区
    3246. convert ==> 变换
    3247. converter ==> 变换器,变换机
    3248. converter arm ==> 换流管桥臂
    3249. converter blocking ==> 换流器闭锁,换流器关断
    3250. converter bridge ==> 换流器桥
    3251. converter deblocking ==> 换流器解锁,换流器启用,换流器导通
    3252. converter display ==> 变换器显示装置
    3253. converter fed motor ==> 换流器供电的电动机
    3254. converter reactor ==> 转换堆,再生反应堆,转换反应堆
    3255. converter relay ==> 换流器继电器
    3256. converter room ==> 变电室
    3257. converter set ==> 换流器组
    3258. converter substation ==> 换流站
    3259. converter transformer ==> 换流变压器
    3260. converter tube ==> 变换管
    3261. converter unit firing control ==> 换流器触发控制
    3262. converter unit protection ==> 换流器保护
    3263. converter unit sequence control ==> 换流器顺序控制
    3264. converter waste heat boiler ==> 转炉废热锅炉
    3265. convex ==> 凸面
    3266. convex programming ==> 凸规划
    3267. conveying pipe ==> 输送管
    3268. conveyor dryer ==> 传送带式干燥机
    3269. convolution ==> 卷积,圈,匝,涡流,回旋
    3270. convolution integral ==> 卷积积分
    3271. convolution theorem ==> 卷积定理
    3272. convolutional code ==> 卷积码
    3273. Cooke, W.F.Cooke ==> 1806-1879,英国科学家
    3274. coolant ==> 冷却剂
    3275. coolant activity ==> 冷却剂放射能
    3276. coolant circuit ==> 冷却剂回路
    3277. coolant circulation ==> 冷却剂循环
    3278. coolant fluid ==> 冷却剂流体
    3279. coolant loop ==> 冷却剂回路
    3280. coolant purification system ==> 冷却剂净化系
    3281. coolant temperature gauge ==> 冷却水温度表
    3282. cooled photodetector ==> 冷却式光电探测器
    3283. cooler ==> 冷却器
    3284. cooling ==> 冷却
    3285. cooling agent ==> 冷却剂
    3286. cooling air temperature ==> 冷却空气温度
    3287. cooling circuit ==> 冷却回路
    3288. cooling coil ==> 冷却用螺管
    3289. cooling column ==> 冷却塔
    3290. cooling duct ==> 冷却道
    3291. cooling ducts ==> 通风沟
    3292. cooling factor ==> 冷却系数
    3293. cooling fan ==> 冷却风扇
    3294. cooling fin ==> 冷却肋片,散热片
    3295. cooling fluid ==> 冷却液
    3296. cooling installation ==> 冷却装置
    3297. cooling jacket ==> 冷却夹套
    3298. cooling medium ==> 冷却介质
    3299. cooling pipe ==> 冷却管
    3300. cooling pond ==> 冷却池
    3301. cooling rate ==> 冷却速率
    3302. cooling surface ==> 冷却面
    3303. cooling system ==> 冷却系统
    3304. cooling tower ==> 冷却塔
    3305. cooling water ==> 冷却水
    3306. cooling water circulation ==> 冷水环流
    3307. coordinate plotter ==> 坐标绘图机
    3308. coordinate sensitive photodetector ==> 坐标敏感光电检测器
    3309. coordinate system ==> 坐标系
    3310. coordinate table ==> 坐标表
    3311. coordinate transformation ==> 坐标变换
    3312. coordinate type potentiometer ==> 坐标电位计
    3313. coordinated operation ==> 协同运行
    3314. coordinated operation of hydroplants ==> 水力发电厂协调运行
    3315. coordinating spark gap ==> 协调火花隙
    3316. coordination control ==> 协调控制
    3317. coordination equation ==> 协调方程
    3318. coordination of insulation ==> 绝缘配合
    3319. coordinatograph ==> 坐标绘图机
    3320. coplanar electrodes ==> 共平面电极
    3321. copper ==> 铜
    3322. copper binding wire ==> 绑扎铜线
    3323. copper brush ==> 铜刷
    3324. copper cable ==> 铜电缆
    3325. copper clad laminate ==> 敷铜箔叠层板
    3326. copper clad steel wire ==> 包铜钢线
    3327. copper collar ==> 铜环
    3328. copper conductivity standard ==> 铜导电率标准
    3329. copper conductor ==> 铜线
    3330. copper constantan thermocouple ==> 铜康铜热电偶
    3331. copper coverved steel wire ==> 包铜钢线
    3332. copper ferrite ==> 铜铁氧体
    3333. copper filled adhesive ==> 填铜粘合剂
    3334. copper foil ==> 铜箔
    3335. copper graphite brush ==> 铜石墨电刷
    3336. copper loss with direct current ==> 直流铜损
    3337. copper losses ==> 铜损
    3338. copper magnesium ferrite ==> 铜镁铁氧体
    3339. copper oxide rectifier ==> 氧化铜整流
    3340. copper plated ==> 镀铜的
    3341. copper plated base material ==> 镀铜的基体材料
    3342. copper plating ==> 镀铜
    3343. copper sleeve ==> 铜套筒
    3344. copper space factor ==> 铜线占空系数
    3345. copper sulfate ==> 硫酸铜
    3346. copper sulfide rectifier ==> 硫化铜整流
    3347. copper to aluminum adapter board ==> 铜铝过渡板
    3348. copper voltameter ==> 铜解电量计
    3349. copper weld steel wire ==> 包铜钢线
    3350. copper weld wire ==> 铜包钢线
    3351. copper wire ==> 铜线
    3352. copper zinc ferrite ==> 铜锌铁氧体
    3353. coppor sulfate treatment ==> 硫酸铜注入法
    3354. copy ==> 模仿,复制
    3355. copying ==> 复制
    3356. Corbino disk ==> 克宾诺盘
    3357. Corbino effect ==> 克宾诺效应
    3358. cord ==> 接电绳
    3359. cord circuit ==> 塞绳电路
    3360. cord circuit repeater ==> 塞绳增音机
    3361. cord pendant ==> 电灯吊线
    3362. cord switch ==> 绳开关
    3363. cordless switchboard ==> 无塞绳交换机
    3364. core ==> 心,磁心
    3365. core carbon ==> 芯炭棒
    3366. core diameter ==> 铁芯对径
    3367. core end plate ==> 铁芯端板
    3368. core length ==> 铁芯长度
    3369. core logic ==> 磁心逻辑
    3370. core loss ==> 铁损
    3371. core magnet instrument ==> 磁心式仪表
    3372. core material ==> 裂变物质
    3373. core matrix ==> 磁芯矩阵
    3374. core memory ==> 磁芯存储器
    3375. core rod ==> 芯棒
    3376. core stack ==> 叠片铁芯
    3377. core type induction furnace ==> 铁芯式感应炉
    3378. core type magnetic circuit ==> 铁芯式磁路
    3379. core type transformer ==> 内铁芯变压器
    3380. core wire ==> 芯线
    3381. cored electrode ==> 有心焊条
    3382. cored solder ==> 带芯钎焊条
    3383. coreless armature ==> 无铁芯电枢
    3384. coreless type high frequency furnace ==> 无铁芯高频炉
    3385. coreless type induction furnace ==> 无铁芯感应电炉
    3386. coring ==> 晶内偏析
    3387. corkscrew rule ==> 旋转法则
    3388. corner ==> 弯曲软波导
    3389. corner antenna ==> 角反射旗线
    3390. corner cube ==> 角形反射器
    3391. corner post ==> 角端子
    3392. corner reflector ==> 角形反射器
    3393. corona ==> 电晕,电晕放电
    3394. corona charging ==> 电晕荷电
    3395. corona control ring ==> 电晕控制环
    3396. corona counter ==> 电晕[放电]计数管
    3397. corona current ==> 电晕电流
    3398. corona damage ==> 电晕损坏
    3399. corona detector ==> 电晕探测器
    3400. corona discharge ==> 电晕,电晕放电
    3401. corona discharge cooling ==> 电晕放电冷却
    3402. corona discharge valve ==> 电晕放电管
    3403. corona effect ==> 电晕效应
    3404. corona electret ==> 电晕驻极体
    3405. corona field ==> 电晕场
    3406. corona field intensity ==> 电晕场强度
    3407. corona free ==> 无电晕
    3408. corona free design ==> 无电晕设计
    3409. corona frequency analysis ==> 电晕频率分析
    3410. corona generated interference ==> 电晕产生干扰
    3411. corona grading ==> 防电晕
    3412. corona grading paint ==> 防电晕漆
    3413. corona guard ==> 电晕防护设备
    3414. corona inception field strength ==> 电晕起始场强
    3415. corona inception test ==> 电晕起始试验
    3416. corona inception voltage ==> 电晕起始电压
    3417. corona location ==> 电晕定位
    3418. corona loss ==> 电晕损耗
    3419. corona luminescence ==> 电晕发光
    3420. corona luminous layer ==> 电晕发光层
    3421. corona measurement ==> 电晕测量
    3422. corona noise ==> 电晕噪声
    3423. corona point ==> 电晕发电尖端
    3424. corona power loss ==> 电晕功率损失
    3425. corona prevention ==> 电晕防护
    3426. corona preventive screen ==> 防晕屏蔽
    3427. corona proof ==> 防电晕的
    3428. corona proof cable ==> 防电晕电缆
    3429. corona proof coil ==> 防电晕线圈
    3430. corona protection ==> 电晕防护
    3431. corona protective varnish ==> 防电晕漆
    3432. corona pulse ==> 电晕放电脉冲
    3433. corona resistance ==> 电晕放电电阻
    3434. corona resistant ==> 防电晕
    3435. corona resistant insulation ==> 耐电晕绝缘
    3436. corona ring ==> 电晕环
    3437. corona shielding ==> 电晕屏蔽
    3438. corona stabilizer ==> 电晕稳定器
    3439. corona starting gradient ==> 电晕起始梯度
    3440. corona suppression ==> 电晕抑制
    3441. corona test ==> 电晕试验
    3442. corona treatment ==> 电晕处理
    3443. corona voltage ==> 电晕电压
    3444. corona voltmeter ==> 电晕电压表
    3445. corona zone ==> 电晕区,电晕范围
    3446. coroutine ==> 协同程序
    3447. corpuscle ==> 微粒
    3448. correct operation ==> 正确动作
    3449. correcting amplifier ==> 校正放大器
    3450. correcting coil ==> 校正线圈
    3451. correcting current ==> 校正电流
    3452. correcting device ==> 校正装置
    3453. correcting filter ==> 校正滤波器
    3454. correcting lens ==> 校正透镜
    3455. correcting signal ==> 校正信号
    3456. correction ==> 校正
    3457. correction circuit ==> 校正电路
    3458. correction curve ==> 校正曲线
    3459. correction element ==> 校正要素
    3460. correction factor ==> 校正系数
    3461. correction lag ==> 校正延迟
    3462. correction of distortion ==> 失真校正
    3463. correction of phase ==> 相位校正
    3464. correction range ==> 校正范围
    3465. correction table ==> 校正表
    3466. correction time ==> 校正时间
    3467. corrective action ==> 校正动作
    3468. corrective capacity ==> 校正电容
    3469. corrective element ==> 校正要素
    3470. corrective quadripole ==> 四端网络
    3471. corrector circuit ==> 校正电路
    3472. correlation ==> 相关
    3473. correlation analysis ==> 相关分析
    3474. correlation coefficient ==> 相关系数
    3475. correlation function ==> 相关函数
    3476. correlation length measuring instrument ==> 相关式测长仪
    3477. correlation method ==> 相关法
    3478. correlation ratio ==> 相关比
    3479. correlative method INPUT system ==> 相关对比法感应脉冲瞬变系统
    3480. correlator ==> 相关器
    3481. corridor switchboard ==> 双工配电盘
    3482. corrosion ==> 腐蚀
    3483. corrosion control ==> 腐蚀控制
    3484. corrosion crack ==> 腐蚀裂纹
    3485. corrosion environment ==> 腐蚀环境
    3486. corrosion failure ==> 腐蚀破裂,腐蚀损坏
    3487. corrosion fatigue ==> 腐蚀疲劳
    3488. corrosion fouling ==> 腐蚀污垢
    3489. corrosion kinetics ==> 腐蚀动力学
    3490. corrosion loop test ==> 回路腐蚀试验
    3491. corrosion of metal ==> 金属锈蚀
    3492. corrosion proof cable ==> 耐腐蚀电缆
    3493. corrosion proof instrument ==> 防腐式仪器仪表
    3494. corrosion protection covering ==> 防蚀被覆
    3495. corrosion resistance tests ==> 耐腐试验
    3496. corrosion stability ==> 腐蚀稳定性
    3497. corrosion testing machine ==> 腐蚀试验机
    3498. corrosive atmospheres test ==> 腐蚀性大气试验
    3499. corrugated bulb ==> 皱纹灯泡
    3500. corrugated mask ==> 多孔障板
     楼主| 发表于 2010-6-17 13:19:26 | 显示全部楼层
    回复:电气及半导体词汇词典-C
    4001. curing period ==> 养护期
    4002. curing system ==> 硬化装置
    4003. curing temperature ==> 硬化温度
    4004. current ==> 海流,电流
    4005. current amplification ==> 电流放大,电流比
    4006. current amplification factor ==> 电流放大系数
    4007. current amplifier ==> 电流放大器
    4008. current amplitude ==> 电流振幅
    4009. current attenuation ==> 电流衰减
    4010. current balance ==> 电流平衡
    4011. current balance relay ==> 电流平衡继电器
    4012. current bottle ==> 漂流瓶
    4013. current by phase (AMP) ==> 每相电流
    4014. current carrying capacity ==> 载流量
    4015. current center ==> 电流中心
    4016. current circuit ==> 电流电路
    4017. current circuit (of a measuring instrument) ==> (测量仪表的)电流电路
    4018. current circular vector ==> 电流工频矢量
    4019. current coil ==> 电流线圈
    4020. current collector ==> 集电器
    4021. current constant ==> 电流常数
    4022. current cut off ==> 电流切断
    4023. current density ==> 电流密度
    4024. current diagram ==> 电流线图
    4025. current differential protection ==> 电流差动保护
    4026. current directinal relay ==> 逆电流继电器
    4027. current direction ==> 海流方向,电流方向
    4028. current distribution ==> 电流分布,电流分配
    4029. current divider ==> 分流
    4030. current efficiency ==> 电流效率
    4031. current error ==> 电流比值差
    4032. current feedback ==> 电流反馈
    4033. current gain ==> 电流增益
    4034. current generator ==> 电流发生器
    4035. current indicator ==> 电流指示器
    4036. current injection logic ==> 电流注入逻辑
    4037. current input ==> 电流输入
    4038. current intensity ==> 电流密度
    4039. current leakage ==> 电流漏泄
    4040. current limit relay ==> 限流继电器
    4041. current limiter ==> 电流限制器,限流
    4042. current limiting capacity ==> 限流能力
    4043. current limiting characteristic ==> 限流特性
    4044. current limiting fuse ==> 限流熔丝
    4045. current limiting reactor ==> 限流电抗器
    4046. current limiting threshold ==> 限流阈(值)
    4047. current limitting circuit breaker ==> 限料路开关
    4048. current line ==> 测流绳
    4049. current load ==> 电流负载
    4050. current magnitude ==> 电流强度
    4051. current maintenance ==> 日常保养
    4052. current matching transformer ==> 电流匹配互感器
    4053. current measurement ==> 电流测量
    4054. current meter ==> 电流表,海流计,流速计
    4055. current mode logic ==> 电联关逻辑
    4056. current moment ==> 电流矩
    4057. current noise ==> 电流噪声
    4058. current of holes ==> 空穴电流
    4059. current path ==> 电流通路,气流通路
    4060. current peak ==> 电流峰值
    4061. current pole ==> 测流标杆
    4062. current protection ==> 电流保护装置
    4063. current psw ==> 现行psw
    4064. current pulse ==> 电流脉冲
    4065. current ratio ==> 电流比
    4066. current regulator ==> 稳流
    4067. current relay ==> 电流继电器
    4068. current resonance ==> 并联谐振
    4069. current responsivity ==> 电流反应度
    4070. current reversal ==> 电流反向
    4071. current reverser ==> 电流反向开关
    4072. current riple ==> 电流脉动
    4073. current rush ==> 电流骤增,冲激电流
    4074. current sensitivity ==> 电流灵敏度,电灵敏度
    4075. current source ==> 电源,电流源
    4076. current spiral vector ==> 电流螺旋矢量
    4077. current stability ==> 电流稳定度
    4078. current standard ==> 电流标准
    4079. current supply ==> 供电
    4080. current telemetering ==> 电流遥测
    4081. current terminal ==> 电流端子
    4082. current transducer ==> 电流变换器
    4083. current transformer ==> 变流,电流互感器
    4084. current transformer for relaying ==> 继电保护用电流互感器
    4085. current transformers in idle shunt ==> 空载分路中的电流互感器,与保护系统相连,但不载一次电流的电流互感器。
    4086. current transmission system ==> 电流传输系统
    4087. current velocity[speed] ==> 海流速度
    4088. current voltage characteristic ==> 伏安特性,电流电压特性曲线
    4089. current voltage diagram ==> 伏安特性
    4090. cursor ==> 光标,指针
    4091. cursor positioning ==> 光标定位
    4092. curtail ==> 减少,降低,衰减
    4093. curtailability ==> 送电公司的停电权利(电力市场)
    4094. curtailed inspection ==> [简化]抽样检查
    4095. curvature ==> 曲率
    4096. curvature of field ==> 场曲率
    4097. curve ==> 曲线
    4098. curve analyzer ==> 曲线分析器
    4099. curve follower ==> 曲线阅读器曲线输出器
    4100. curve peak ==> 曲线峰值
    4101. curve plotter ==> 曲线描绘仪
    4102. curve resistance ==> 曲线电阻
    4103. curved waveguide ==> 弯曲波导管
    4104. curvilinear ordinates recording instrument ==> 曲线坐标记录仪
    4105. cushioned socket ==> 防震管座
    4106. cusped magnetic field ==> 会切磁场
    4107. custom approach ==> 定制集成电路技术
    4108. custom chip ==> 定制集成电路
    4109. custom hardware ==> 定制硬件
    4110. custom IC ==> 用户集成电路
    4111. custom IC design ==> 定制集成电路设计
    4112. custom implementation ==> 定制集成电路制造
    4113. custom integrated circuit ==> 定制集成电路
    4114. custom layout ==> 定制集成电路布置布线图
    4115. custom memory ==> 用户定制存储器
    4116. custom monolithic circuit ==> 定制单片集成电路
    4117. custom photomask ==> 定制光掩模
    4118. custom power ==> 定质电力
    4119. custom power technology ==> 用户电力技术,定质电力技术
    4120. custom route ==> 定制路由
    4121. customer ==> 用户
    4122. customer average interruption duration index ==> 用户平均断电持续时间指标
    4123. customer loop ==> 用户环路
    4124. customer power electronics technology ==> 电力用户定制电力电子技术
    4125. customer substation ==> 用户变电所
    4126. customization ==> 实现定制集成电路
    4127. cut ==> 切断
    4128. cut core ==> 切割铁心
    4129. cut in ==> 接通,插通
    4130. cut off ==> 截止
    4131. cut off frequency ==> 截止频率
    4132. cut off relay ==> 截止继电器
    4133. cut off switch ==> 切断开关
    4134. cut out ==> 开孔
    4135. cut out switch ==> 切断开关
    4136. cutoff ==> 保险装置
    4137. cutoff attenuator ==> 截止衰减器
    4138. cutoff bias ==> 截止偏压
    4139. cutoff current ==> 截止电流
    4140. cutoff frequency ==> 截止频率
    4141. cutoff point ==> 截止点
    4142. cutoff region ==> 截止区
    4143. cutoff relay ==> 断电继电器
    4144. cutoff state ==> 截止状态
    4145. cutoff voltage ==> 截止电压
    4146. cutoff waveguide ==> 截止波导
    4147. cutoff wavelength ==> 截止波长
    4148. cutout ==> 保险装置,断流
    4149. cutter head ==> 机械录音头
    4150. cutting ==> 切
    4151. cutting blade ==> 切割刀片
    4152. cutting pliers ==> 钳子
    4153. cutting stylus ==> 录音针
    4154. cvd ==> 化学汽相淀积
    4155. cvd oxide ==> 化学汽相淀积氧化物
    4156. cvd polysilicon ==> 化学汽相淀积多晶硅
    4157. cvd silicon ==> 化学汽相淀积硅
    4158. CVSR, cut set static voltage stability region ==> 电力系统静态电压稳定的安全域
    4159. cw lasing ==> 连续波激光振荡
    4160. cw pumped laser ==> 连续激励激光器
    4161. cw radar ==> 连续波雷达
    4162. cyanometer ==> 天空蓝度测定仪
    4163. cybernetic system ==> 控制论系统
    4164. cybernetics ==> 控制论
    4165. cycle ==> 周,循环
    4166. cycle control ==> 循环控制
    4167. cycle counter ==> 周波表,频率计,周波计数,转数计
    4168. cycle criterion ==> 周期判据,循环判据,循环准则
    4169. cycle duration ==> 循环时间,周期长度
    4170. cycle economy ==> 循环经济性
    4171. cycle efficiency ==> 循环效率
    4172. cycle fluid ==> 循环工质
    4173. cycle frequency ==> 循环频率
    4174. cycle generator ==> 周波发生器
    4175. cycle heat rate ==> 循环热耗
    4176. cycle index ==> 循环次数
    4177. cycle index counter ==> 循环次数计数器
    4178. cycle interrupt ==> 周期性中断,循环式中断
    4179. cycle length ==> 运行周期,循环时间
    4180. cycle life ==> 循环寿命
    4181. cycle of concentration ==> 循环倍率,浓缩周期
    4182. cycle of fluctuation ==> 波动周期
    4183. cycle of magnetization ==> 磁化循环
    4184. cycle of measurement ==> 测量周期
    4185. cycle of operation ==> 动作循环,工作周期
    4186. cycle of stress ==> 应力循环
    4187. cycle of vibration ==> 振动周期
    4188. cycle order ==> 循环次序
    4189. cycle per second ==> 周/秒
    4190. cycle performance ==> 循环性能
    4191. cycle period ==> (燃料)循环周期
    4192. cycle repeat timer ==> 周期脉冲发送器
    4193. cycle time ==> 循环时间,周期
    4194. cycle timer ==> 循环时间记录器
    4195. cyclesound ==> 往复探测器
    4196. cyclic ==> 循环
    4197. cyclic accelerator ==> 循环加速器
    4198. cyclic addressing ==> 循环寻址
    4199. cyclic admittance ==> 相序导纳
    4200. cyclic binary code ==> 循环二进制码
    4201. cyclic change ==> 循环变化
    4202. cyclic check ==> 循环效验
    4203. cyclic check bits ==> 循环效验位
    4204. cyclic code ==> 循环码
    4205. cyclic control system ==> 闭环控制系统
    4206. cyclic counter ==> 循环计数器
    4207. cyclic current method ==> 回路电流法
    4208. cyclic daily duty ==> 日周期工作方式,日周期负载
    4209. cyclic damp heat test ==> 循环湿热试验
    4210. cyclic decimal code ==> 循环十进码
    4211. cyclic deformation ==> 交叉变形
    4212. cyclic depletion ==> 周期亏耗,多年亏耗
    4213. cyclic-digit code ==> 循环数码
    4214. cyclic digital telemetering ==> 循环数字遥测(CDT)
    4215. cyclic duration factor ==> 周期持续系数
    4216. cyclic duty ==> 周期性负载,周期式工作方式
    4217. cyclic-duty alternator ==> 周期式工作的同步发电机
    4218. cyclic failure criteria ==> 循环失效判据
    4219. cyclic frequency ==> 角频率
    4220. cyclic impedance ==> 相序阻抗
    4221. cyclic integrator ==> 循环积分器
    4222. cyclic irregularity ==> 周期不规则性
    4223. cyclic iterative method ==> 循环迭代法
    4224. cyclic life ==> 循环期限
    4225. cyclic life test ==> 循环寿命试验
    4226. cyclic load ==> 循环负荷
    4227. cyclic loading spectrum ==> 循环载荷谱
    4228. cyclic magnetic condition ==> 循环磁状态
    4229. cyclic magnetization ==> 周期磁化,循环磁化
    4230. cyclic process ==> 周期性过程
    4231. cyclic quadrilateral ==> 圆内接四边形
    4232. cyclic reactance ==> 相序电抗
    4233. cyclic recovery ==> 周期复原
    4234. cyclic remote control ==> 循环遥控
    4235. cyclic service ==> 周期性运行
    4236. cyclic shift ==> 循环移位
    4237. cyclic stealing ==> 周期挪用
    4238. cyclic strain ==> 循环应变
    4239. cyclic stress ==> 循环应力
    4240. cyclic tape ==> 循环磁带
    4241. cyclic transformation ==> 循环变换
    4242. cyclic unit ==> 中间负荷机组
    4243. cyclic variation ==> 循环变化,周期性变化
    4244. cyclic variation of stress ==> 应力周期变化
    4245. cyclic(al) ==> 循环的,周期性的
    4246. cycling ==> 循环
    4247. cycling-load ==> 循环负荷,周期性变负荷
    4248. cycling operation ==> 周期性运行,调峰运行
    4249. cycling service ==> 周期性运行
    4250. cycling solenoid valve ==> 周期电磁阀
    4251. cycling unit ==> 循环负荷机组
    4252. cycloconverter ==> 双向离子变频器
    4253. cycloid ==> 摆线,旋轮线
    4254. cycloidal mass spectrometer ==> 摆线质谱计
    4255. cyclometer ==> 周期计,回转计
    4256. cyclone ==> 旋风筒,旋风分离器
    4257. cyclone air lock ==> 旋风筒气封
    4258. cyclone burner ==> 旋流燃烧器
    4259. cyclone capacity ==> 旋风筒出力
    4260. cyclone discharge line ==> 旋流排出管道
    4261. cyclone efficiency ==> 旋风筒效率
    4262. cyclone filter ==> 旋风过滤器
    4263. cyclone muff ==> 旋风筒筒体
    4264. cyclotron ==> 回旋加速器
    4265. cyclotron frequency ==> 回旋加速频率
    4266. cyclotron maser ==> 回旋加速脉泽
    4267. cyclotron resonance ==> 回旋加速共振
    4268. cylinder ==> 气缸
    4269. cylinder efficiency ==> 气缸效率
    4270. cylindrical array ==> 柱面阵
    4271. cylindrical capacitor ==> 圆柱形电容器
    4272. cylindrical cathode ==> 圆柱形阴极
    4273. cylindrical coil ==> 圆柱形线圈
    4274. cylindrical controller ==> 鼓形控制器
    4275. cylindrical coordinates ==> 圆柱坐标
    4276. cylindrical magnetic domain ==> 圆柱形磁畴
    4277. cylindrical plasma reactor ==> 圆柱形等离子体反应器
    4278. cylindrical reactor ==> 圆柱形反应堆
    4279. cylindrical reflector ==> 柱面反射器
    4280. cylindrical rotor machine ==> 非突极电机
    4281. cylindrical rotor motor ==> 隐极电动机
    4282. cylindrical throat Venturi nozzle ==> 圆筒形喉部文丘里喷嘴
    4283. cylindrical wave ==> 柱面波
    4284. cymometer ==> 波长计
    4285. cypher ==> 密码
    4286. cz ==> 切克劳斯基法
    4287. czochralski grown crystal ==> 切克劳斯基法生长晶体
    4288. czochralski grown ingot ==> 切克劳斯基法生长晶体
    4289. czochralski method ==> 切克劳斯基法
    4290. czochralski production system ==> 切克劳斯基晶体生长装置
    4291. czochralski silicon ==> 切克劳斯基法生长硅
    GMT+8, 2025-10-19 09:07 , Processed in 0.103915 second(s), 21 queries , MemCache On.
