在线时间393 小时
UID123826
注册时间2009-4-22
NXP金币2
TA的每日心情 | 难过 2021-12-15 16:01 |
- 377
- 2023-8-16
本文内容转自:http://www.for68.com/jidianyingyu/
1. D action, derivative action ==> 微分作用,D-作用
2. D and D/2 pressure tappings ==> D和D/2取压口
3. D port ==> D型端口
4. d‘Alembert‘s principle ==> 达朗贝尔原理
5. d‘Alembertian ==> 达朗贝尔算符
6. d‘arsonval galvanometer ==> 达松伐耳电流计
7. d.c.bridge for measuring high resistance ==> 直流高阻电桥
8. d.c.bridge for measuring resistance ==> 测量电阻用的直流电桥
9. d.c.comparator potentiometer ==> 直流比较仪式电位差计
10. d.c.comparator type bridge ==> 直流比较仪式电桥
11. d.c.potentiometer ==> 直流电位差计
12. d.c.power voltage ripple ==> 直流电源电压纹波
13. d.c.resistance box ==> 直流电阻箱
14. d.c.resistor volt ratio box ==> 直流电阻分压箱
15. d.c.voltage calibrator ==> 直流电压校准器
16. d/a converter ==> 数字模拟转换器
17. D/A converter, digital analogue converter ==> 数—模转换器,D/A转换器
18. D/D converter ==> D/D转换器
19. da ==> 设计自动化
20. dac ==> 数字模拟转换器
21. dacq ==> 数据采集
22. daily load ==> 日负载,昼夜负荷
23. daily load curve ==> 日负载曲线
24. daily load factor ==> 日负载率
25. daily output ==> 日出力,日产量
26. daily service fuel tank level switch ==> 日用油缸液位掣
27. dale ==> 山谷,溪谷,峪
28. Daly detector ==> 戴利检测器
29. dam ==> 水坝
30. dam site ==> 坝址
31. dam type power plant ==> 堰堤式水力发电厂
32. damage ==> 损伤,损毁
33. damage area ==> 损伤区
34. damage probability ==> 损伤概率
35. damage study ==> 破坏研究
36. damp ==> 湿度
37. damp air ==> 湿空气
38. damp course ==> 防潮层
39. damp proof machine ==> 防潮电机
40. damped ==> 衰减的
41. damped alternating current ==> 减幅交流,衰减交流
42. damped angular frequency ==> 衰减角频率
43. damped ballistic galvanometer ==> 阻尼冲击减流计
44. damped cosine function ==> 阻尼余弦函数
45. damped exponential curve ==> 减幅指数曲线
46. damped factor ==> 阻尼系数,衰减系数
47. damped frequency ==> 阻尼频率
48. damped harmonic motion ==> 阻尼谐动
49. damped harmonic system=>减幅谐波系统 ==>
50. damped impedance ==> 阻尼阻抗,衰减阻抗
51. damped natural frequency ==> 阻尼固有频率
52. damped oscillation ==> 阻尼振荡,减幅振荡
53. damped oscillator ==> 阻尼振荡器
54. damped periodic element ==> 阻尼摆动部分
55. damped periodic instrument ==> 阻尼周期性仪表
56. damped sawtooth oscillation ==> 阻尼钜齿波振荡
57. damped sine function ==> 阻尼正弦函数
58. damped sinusoid ==> 阻尼正弦曲线
59. damped sinusoidal quantity ==> 衰减正弦量
60. damped transient ==> 衰减过度过程
61. damped vibration ==> 衰减振动,阻尼振动
62. damped wave ==> 衰减波
63. damped wave equation ==> 衰减波动方程
64. dampen ==> 弄湿,吸音,减震,阻尼
65. dampen pipe ==> 消音器
66. damper ==> 制动器,挡板,阻尼器,防振锤
67. damper bar ==> 阻尼条
68. damper cage ==> 阻尼笼
69. damper cage starting ==> 阻尼笼启动
70. damper circuit ==> 阻尼电路
71. damper coil ==> 阻尼线圈
72. damper current ==> 阻尼电流
73. damper linkage ==> 风闸联动装置
74. damper loss ==> 阻尼损失
75. damper motor ==> 风闸马达
76. damper ring ==> 阻尼环
77. damper segment ==> 阻尼片
78. damper winding ==> 阻尼绕组
79. damping ==> 制动,衰减,阻尼
80. damping action ==> 阻尼作用
81. damping adjustment ==> 阻尼调整
82. damping bar ==> 阻尼条
83. damping by friction ==> 摩擦阻尼,摩擦减震
84. damping capacity ==> 阻尼能力,减震力
85. damping characteristic ==> 阻尼特性
86. damping circuit ==> 阻尼电路
87. damping coefficient ==> 阻尼因数,阻尼系数,衰减系数,减幅系数
88. damping coil ==> 阻尼线圈
89. damping constant ==> 衰减常数,阻尼常数,阻尼衰减常数
90. damping decrement ==> 衰减率
91. damping deflection period ==> 阻尼比
92. damping device ==> 阻尼装置
93. damping diode ==> 阻尼二极管
94. damping effect ==> 阻尼效应
95. damping factor ==> 衰减因数,阻尼因数
96. damping magnet ==> 阻尼磁铁
97. damping mat ==> 阻尼垫
98. damping period ==> 衰减周期
99. damping ratio ==> 阻尼比
100. damping resistance ==> 阻尼电阻
101. damping ring ==> 制动环,阻尼环
102. damping system ==> 阻尼装置
103. damping time ==> 衰减时间
104. damping torque ==> 阻尼力矩
105. damping torque coefficient ==> 阻尼力矩系数
106. damping turn ==> 阻尼线匝
107. damping vane ==> 阻尼叶片
108. damping winding ==> 阻尼绕组
109. danger coefficient ==> 危险系数
110. danger signal ==> 危险信号
111. dangerous articles package ==> 危险品包装
112. dangerous earth potential ==> 危险性对地电势
113. daniell cell ==> 丹聂耳电池
114. dark ==> 暗黑
115. dark current ==> 暗电流
116. dark discharge ==> 暗放电
117. dark field electron image ==> 暗场电子象
118. dark line ==> 暗线
119. dark pulse spectrum ==> 暗脉冲谱
120. dark resistance ==> 暗电阻
121. dark room lamp ==> 暗室灯
122. dark space ==> 暗区
123. dark spot ==> 黑点
124. dark spot signal ==> 黑点信号
125. dark trace screen ==> 暗迹屏
126. darlington amplifier ==> 达灵顿放大器
127. darlington emitter follower ==> 达林顿射极跟随器
128. darrieus generator ==> 达利涡斯发动机
129. DARS, data acquisition and recording system ==> 数据采集和记录系统
130. DAS, data access storage ==> 直接存取存储器
131. DAS, data acquisition system ==> 数据采集系统
132. dasd ==> 直接存取存储器
133. dash pot ==> 缓冲器
134. dashpot ==> 减震器
135. data ==> 数据,资料
136. data acquisition ==> 数据采集
137. data acquisition equipment ==> 数据采集设备
138. data acquisition station ==> 数据采集站
139. data bank ==> 数据库
140. data buoy system ==> 数据浮标系统
141. data capture ==> 数据采集
142. data channel ==> 数据电路
143. data circuit ==> 数据电路
144. data coding ==> 数据符号化
145. data collection ==> 数据采集
146. data communication ==> 数据通信
147. data communication system ==> 数据传送系统
148. data compression ==> 数据压缩
149. data concentration ==> 数据集中
150. data concentrator ==> 数据集中分配器,数据集中器
151. data control block ==> 数据控制块
152. data conversion ==> 数据转换
153. data driven ==> 数据驱动
154. data encryption ==> 数据加密
155. data flow chart ==> 数据流程图
156. data flow diagram ==> 数据流图
157. data gathering ==> 数据采集
158. data handling ==> 数据处理
159. data handling capacity ==> 数据处理能力
160. data handling system ==> 数据处理系统
161. data highway ==> 数据公路
162. data input ==> 数据输入
163. data integrity ==> 数据完整性
164. data line ==> 数据电路
165. data link ==> 数据传输线路,数据链路
166. data link layer(DLL) ==> 数据链路层
167. data link protocol specification ==> 数据链路协议规范
168. data link service definition ==> 数据链路服务定义
169. data logger ==> 数据记录器,数据记录装置
170. data logging ==> 数据记录,数据采集
171. data management ==> 数据管理
172. data manipulation language ==> 数据操罪言
173. data mode ==> 数据传送方式
174. data modem ==> 数据调制解调
175. data network ==> 数据网,数据网络
176. data organization ==> 数据组织
177. data output ==> 数据输出
178. data output channel ==> 数据输出通路
179. data packet switching ==> 数据包交换
180. data preprocessing ==> 数据预处理
181. data processing ==> 数据处理
182. data processing equipment ==> 数据处理装置
183. data processing rate ==> 数据处理速度
184. data processing system ==> 数据处理器[机],数据处理系统
185. data processor ==> 数据处理器
186. data reader ==> 数据阅读器
187. data recorder ==> 数据记录器
188. data reduction ==> 数据压缩,数据简化
189. data set ==> 数传机
190. data set control block ==> 数据集控制块
191. data signalling rate ==> 数据传信率
192. data sink ==> 数据宿,数据接收器
193. data slice ==> 位片微处理机
194. data source ==> 数据源
195. data station ==> 数据站
196. data storage ==> 数据存储
197. data transfer ==> 数据传送,数据传递
198. data transfer rate ==> 数据传送率,数据传输速率
199. data transmission ==> 数据传输,数据传送
200. data transmission channel ==> 数据传输通道
201. data transmission interface ==> 数据传输接口
202. data word ==> 数据字
203. database ==> 数据库
204. dataway ==> 机箱数据路
205. dataway operation ==> 机箱数据路操作
206. datum ==> 基准,数据,资料,已知数
207. datum error ==> 数据误差
208. datum grade ==> 基准标高
209. datum level ==> 基准水平线
210. datum line ==> 基准线
211. datum mark ==> 基准点
212. datum plane ==> 基准面
213. datum plane for construction ==> 施工基准面
214. datum plane for sounding ==> 基准水平面
215. datum point ==> 基准点
216. datum speed ==> 给定速度
217. datum temperature ==> 基准温度
218. datum water level ==> 基准水平面
219. day load ==> 日间负载
220. daylight effect ==> 昼光效应
221. daylight factor ==> 昼光系数
222. daylight illumination ==> 日光照明
223. daylight lamp ==> 日光灯
224. daylight ratio ==> 天然照明率
225. daylight saving time ==> 日光节约时,夏令时间
226. DB, data base ==> 数据库
227. DB, data bus ==> 数据总线
228. DBM, data base management ==> 数据库管理
229. DBMS, data base management system ==> 数据库管理系统
230. DC-AC converter ==> 直流交流变换机
231. DC-AC inverter ==> 直流交流逆变器
232. DC-AC power inversion ==> 直流交流功率交换
233. DC amplifier ==> 直流放大器
234. DC breakdown voltage ==> 直流击穿电压
235. DC compensating network ==> 直流补偿网络
236. DC component ==> 直流分量
237. DC composite insulator ==> 直流复合绝缘子
238. DC compound motor ==> 直流复激电动机
239. DC control circuit ==> 直流操作回路
240. DC corona ==> 直流电晕
241. DC corona loss ==> 直流电晕损失
242. DC coupled ==> 直流耦合的
243. DC coupling ==> 直流耦合
244. DC-DC LVDT displacement transducer ==> 直流差动变压器式位移传感器
245. DC drive ==> 直流传动,直流驱动
246. DC form factor ==> 直流波形因数
247. DC push pull amplifier ==> 直流推挽放大器
248. DC servomechanism ==> 直流伺服机构
249. DC servomotor ==> 直流伺服电动机
250. DC static convertor ==> 直流静止变流
251. DC tachogenerator ==> 直流测速发电机
252. DC, data cell ==> 数据单元
253. DC, data channel ==> 数据通道
254. DC, data collection ==> 数据收集
255. DC, data communication ==> 数据通信
256. DC, direct current ==> 直流电
257. DC, drawing change ==> 图纸更改
258. DC/AC converter ==> 直流电/交流电转换器
259. dccd ==> 数字电荷耦合装置
260. dccl ==> 直接电荷耦合逻辑
261. DCE, data circuit terminating equipment ==> 数据电路终接设备
262. DCS, Distributed Control System ==> 集散控制系统
263. dctl ==> 直接耦合晶体管逻辑
264. dctl gate ==> 直接耦合晶体管逻辑门
265. DDRTS, digital dynamic real time simulator ==> 数字动态实时仿真系统(北京博电殷图)
266. de-blocking scheme system ==> 解除闭锁方案的系统
267. de-emphasis ==> 去加重
268. de-emphasis network ==> 去重网络
269. De Meritens alternator ==> 德梅里登同步发电机
270. dead ==> 不带电,静的,固定连接的,失效的,不灵敏的
271. dead band ==> 死区
272. dead band error ==> 死区误差
273. dead beat discharge ==> 不摆放电
274. dead beat galvanometer ==> 速指电流计
275. dead circuit ==> 无效电路
276. dead coil ==> 死线圈
277. dead earth ==> 完全接地
278. dead earthed neutral system ==> 中性点接地系统
279. dead-end clamp ==> 耐拉线夹
280. dead-end insulator ==> 耐张绝缘子
281. dead-end pole ==> 终端杆
282. dead-end switch ==> 终端开关
283. dead-end tie ==> 导线的终端扎结
284. dead-end tower ==> 终端塔
285. dead ground ==> 完全接地
286. dead halt ==> 完全停机
287. dead hole ==> 盲孔
288. dead in line ==> 轴线重合
289. dead joint ==> 固定连接
290. dead layer ==> 死层
291. dead load ==> 固定负载
292. dead point ==> 死点
293. dead short circuit ==> 完全短路
294. dead space ==> 死区,不灵敏区
295. dead storage ==> 死库容
296. dead time ==> 停歇时间,不动时间,无感时间,时滞,死时
297. dead turns ==> 死匝
298. dead volume ==> 死体积,静容量
299. dead weight ==> 自重,静重
300. dead weight tester ==> 活塞式压力计
301. dead zone ==> 不灵敏区,盲区
302. dead zone error ==> 死区误差
303. deaphragm gas meter ==> 膜式煤气表
304. deaphragm(pressure)gauge ==> 膜片压力表
305. debug time ==> 调试时间
306. debugging ==> 调试
307. debugging on-line ==> 联机程序的调试
308. debugging routine ==> 调试程序
309. debunching of a beam ==> 束立聚
310. deburring ==> 去毛刺
311. Debye length ==> 德拜长度
312. Debye temperature ==> 德拜温度
313. decade ==> 十进位
314. decade capacitance box ==> 十进电容箱
315. decade counter ==> 十进数计数器
316. decade counter tube ==> 十进计数管
317. decade inductance box ==> 十进电感箱
318. decade resistance ==> 十进制电阻
319. decade resistance box ==> 十进位电阻箱,十进电阻箱
320. decade scaler ==> 十进定标器,十进制计数器
321. decade voltage divider ==> 十进制分压器
322. decalibration ==> 标定降级
323. decanter ==> 沉淀分取器
324. decapsulation ==> 解封装
325. decarbonization ==> 脱碳
326. decarburizing ==> 脱碳
327. decatron ==> 十进制计数管,十进制计数管
328. decay ==> 衰减,衰变
329. decay characteristic ==> 衰变特性
330. decay constant ==> 衰变常数
331. decay cooling ==> 衰变冷却
332. decay curve ==> 衰变曲线,衰减曲线
333. decay energy ==> 衰变能量
334. decay heat removal ==> 衰变热排出
335. decay heat removal circuit ==> 衰变热排出回路
336. decay heat removal process ==> 衰变热排出过程
337. decay heating ==> 衰变发热
338. decay length ==> 衰变长度
339. decay line ==> 衰变管线,滞留管线
340. decay of power ==> 功率降低
341. decay of turbulence ==> 湍(tuān)流衰减
342. decay of wave ==> 波的衰减
343. decay ooze ==> 腐泥
344. decay power ==> 衰变功率
345. decay product ==> 衰变产物
346. decay time ==> 衰变时间,衰减时间,衰落时间
347. decay tube ==> 衰变管
348. decaying ==> 衰减,衰退
349. decaying conduction current ==> 衰减传导电流
350. decaying current ==> 减幅电流,衰减电流
351. decaying datalyt ==> 失活催化剂
352. decaying vector ==> 衰减矢量,山村昌在发展螺旋矢量理论(spiral vector theory)的初期提出的概念,后改为螺旋矢量(spiral vector)
353. decaying wave ==> 减幅波
354. decaymodular ==> 衰减,衰退
355. decelerate ==> 减速
356. decelerating ==> 减速性能
357. decelerating electrode ==> 减速电极
358. decelerating flow ==> 减速流
359. decelerating relay ==> 减速继电器
360. decelerating torque ==> 减速力矩
361. decelerating valve ==> 减速阀
362. decelerating voltage ==> 减速电压
363. deceleration ==> 减速
364. deceleration time ==> 时延
365. decentrality ==> 分散性
366. decentralization ==> 分散化
367. decentralized control ==> 分散控制,局部控制
368. decentralized control system ==> 分散控制系统
369. decentralized deta processing ==> 分散数据处理
370. decentralized model ==> 分散模型
371. decentralized robust control ==> 分散鲁棒控制
372. decentralized stochastic control ==> 分散随机控制
373. decibel ==> 分贝
374. decibel curve ==> 分贝曲线
375. decibelmeter ==> 分贝计
376. decimal ==> 十进位的
377. decimal add ==> 十进制加法
378. decimal add circuit ==> 十进制加法电路
379. decimal addition ==> 十进制加法
380. decimal base ==> 十进制
381. decimal-binary ==> 十进-二进制
382. decimal-binary conversion ==> 十进制-二进制转换
383. decimal code ==> 十进码
384. decimal digit ==> 十进位数
385. decimal number system ==> 十进数数系
386. decimal rheostat ==> 十进变阻器
387. decimal system ==> 十进位制
388. decimal to binary conversion ==> 十二进制转换
389. decimetre range ==> 分米波段
390. decimetric wave ==> 分米波
391. decision analysis ==> 决策分析
392. decision element ==> 判定元件
393. decision function ==> 判定函数
394. decision instruction ==> 判定指令
395. decision model ==> 决策模
396. decision program ==> 决策程序
397. decision space ==> 决策空间
398. decision support system ==> 决策支持系统
399. decision table ==> 判定表
400. decision theory ==> 决策(理)论,判定理论
401. decision tree ==> 决策树
402. declaration of conformity ==> 符合标准声明
403. declination ==> 偏角
404. decline ==> 下倾,低落,衰退
405. declining balance depreciation ==> 衰减平衡折旧
406. declinometer ==> 磁偏计
407. decoder ==> 解码器
408. decoder circuit ==> 译码电路
409. decoding ==> 译码
410. decoding circuit ==> 译码电路
411. decoding matrix ==> 译码矩阵
412. decommissioning ==> 解除运作;停止运作
413. decomposition ==> 分解
414. decomposition and reconstruction ==> 分解和重构
415. decomposition principle ==> 分解原理
416. decomposition reaction ==> 分解反应
417. decomposition technique ==> 分解技术
418. decomposition temperature ==> 分解温度
419. decomposition voltage ==> 分解电压
420. decompression chamber ==> 减压室
421. decontamination ==> 净化,去污
422. decontamination area ==> 消除污染区域
423. decontamination cell ==> 去污小室
424. decontamination cycle ==> 净化循环
425. decontamination device ==> 去污设施
426. decontamination equipment ==> 去污设备
427. decontamination plant ==> 去污装置,净化装置
428. decoration ==> 染色
429. decorative illumination ==> 装饰照明
430. decorative lighting ==> 装饰照明;灯饰
431. decoupling ==> 去耦
432. decoupling filter ==> 去耦滤波器
433. decreasing time function ==> 减少时间函数
434. decrement ==> 衰减量
435. decrement of oscillation ==> 振荡衰减量
436. decrement ratio ==> 减幅比
437. decremeter ==> 衰减计
438. dedicated chip ==> 专用芯片
439. dedicated circuit ==> 专线
440. dedicated integrated circuit ==> 专用芯片
441. dedicated storage ==> 专用存储器
442. dedicated system ==> 专用系统
443. deenergized line ==> 断开线路
444. deep ==> 深的
445. deep acceptor ==> 深受主
446. deep bar motor ==> 深槽电动机
447. deep bar rotor ==> 深槽转子
448. deep bore well pump ==> 深钻井泵
449. deep center ==> 深杂质中心
450. deep depletion ccd ==> 深耗尽层电荷耦合装置
451. deep depletion transistor ==> 深耗尽层晶体管
452. deep diffusion ==> 深扩散
453. deep donor ==> 深施主
454. deep etching ==> 深腐蚀
455. deep kerf ==> 深槽
456. deep sea cable ==> 深水电缆
457. deep sea instrument capsule ==> 深海仪器舱
458. deep slot effect ==> 深槽效应
459. deep slot motor ==> 深槽式电动机
460. deep slot squirrel cage induction motor ==> 深槽鼠笼式感应电动机
461. deep trap ==> 深陷阱
462. deep uv exposure ==> 远紫外线曝光
463. deep uv light ==> 远紫外线
464. deep uv lithography ==> 远紫外线光刻
465. deep uv mask ==> 远紫外线掩模
466. deep uv projection aligner ==> 远紫外线投影曝光对准器
467. deep uv rays ==> 远紫外线
468. deep uv resist ==> 远紫外线灵敏抗蚀剂
469. deexcitation ==> 去激
470. defect ==> 缺陷
471. defect concentration ==> 缺陷密度
472. defect conduction ==> 晶体缺陷导电
473. defect density ==> 缺陷密度
474. defect density distribution ==> 缺陷密度分布
475. defect free crystal ==> 无缺陷晶体
476. defect liability period ==> 故障修理责任期;保用期
477. defect motion ==> 缺陷移动
478. defective silicon ==> 有缺陷硅
479. defectograph ==> 钢缆探伤仪;故障检查仪
480. defence in depth ==> 纵深防御
481. deficit power ==> 不足功率
482. defining fixed point ==> 定义固定点
483. definite sequence ==> 固定次序
484. definite time ==> 定时
485. definite time relay ==> 定时限继电器
486. definition ==> 清晰度
487. definition technique ==> 图象形成技术
488. definitionm ==> 清晰度
489. deflect ==> 偏转
490. deflecting coil ==> 偏转线圈
491. deflecting electrode ==> 致偏电极
492. deflecting field ==> 偏转场
493. deflecting mirror ==> 偏转镜
494. deflecting plate ==> 偏转板
495. deflecting system ==> 偏向系统
496. deflecting torque ==> 偏转力矩,转动力矩
497. deflecting voltage ==> 偏转电压
498. deflecting yoke ==> 偏转系统
499. deflection ==> 偏转,偏转;挠度,挠度
500. deflection amplifier ==> 偏转放大器
