查看: 7222|回复: 12
[其他] BDM无法编程
发表于 2010-8-30 14:25:15 | 显示全部楼层 |阅读模式
COMMAND窗口里显示这些,程序无法成功下载了,救命啊~~~~
Reset command file correctly executed.
FP: FLASH parameters loaded for MC9S12XF512_V1(NVMIF2 rev 3,3,4,6) from D:\Program ***\Freescale\CodeWarrior for HCS12 V4.7\prog\FPP\mcu02E4.fpp
(> 2000 ms)
Program counter: 0x00000063
Block Module Name      Address Range   Status
0  FLASH_4000        FF00 - 11DFF   Programmed - Unselected
(> 2000 ms)
1  FLASH_8000        FF00 - 11DFF   Programmed - Unselected
(> 2000 ms)
2  FLASH_C000        FF00 - 10DFF   Programmed - Unselected
3  ALL_PPAGES      FFFFFF -1FFFFFD   Skipped - Unselected
FP: The UNPROTECT command is not available for the FLASH_4000 flash module => Skipped.
FP: The UNPROTECT command is not available for the FLASH_8000 flash module => Skipped.
FP: The UNPROTECT command is not available for the FLASH_C000 flash module => Skipped.
FP: Call of a command not implemented!
Please modify "flags" in ALL_PPAGES module INFO applet.
0  FLASH_4000      FFFFFF -1FFFFFD   Skipped - Selected
1  FLASH_8000      FFFFFF -1FFFFFD   Skipped - Selected
2  FLASH_C000      FFFFFF -1FFFFFD   Skipped - Selected
3  ALL_PPAGES      FFFFFF -1FFFFFD   Skipped - Selected
executing .\cmd\P&E_Multilink_CyclonePro_vppon.cmd
!// Before programming the flash, the commands written below will be executed
done .\cmd\P&E_Multilink_CyclonePro_vppon.cmd
Vppon command file correctly executed.
FP: The ERASE command is not performed for the FLASH_4000 flash module (AEFSKIPERASING) => Skipped.
FP: The ERASE command is not performed for the FLASH_8000 flash module (AEFSKIPERASING) => Skipped.
FP: The ERASE command is not performed for the FLASH_C000 flash module (AEFSKIPERASING) => Skipped.
FP: The ERASE command is not performed for the ALL_PPAGES flash module (AEFSKIPERASING) => Skipped.
executing .\cmd\P&E_Multilink_CyclonePro_vppoff.cmd
!// After programming the flash, the commands written below will be executed
done .\cmd\P&E_Multilink_CyclonePro_vppoff.cmd
我知道答案 目前已有11人回答
    发表于 2010-8-30 15:35:34 | 显示全部楼层
    RE:BDM无法编程
    请详细说明问题原因:
    1、以前使用正常吗?
    2、我看本次说明,是正常的,没有错误,不知道你如何判断没有烧写成功
     楼主| 发表于 2010-8-30 15:38:18 | 显示全部楼层
    回复:BDM无法编程
    1.以前使用正常的
    2.在这个窗口里,有显示TIMEOUT>2000ms的字样。而且烧写过程较长,程序下进去后根本不运行的
    发表于 2010-8-30 15:48:14 | 显示全部楼层
    RE:BDM无法编程
    如果是这样,建议重新插拔一下BDM、电路板重新上电。检查连接线是否连接正常。
     楼主| 发表于 2010-8-30 15:52:49 | 显示全部楼层
    回复:BDM无法编程
    已经弄过这些,也换过电脑试过了
    发表于 2010-8-30 15:54:22 | 显示全部楼层
    RE:BDM无法编程
    换个板子试试,确认是不是BDM的问题。
     楼主| 发表于 2010-8-30 16:08:13 | 显示全部楼层
    RE:BDM无法编程
    换过了~~~~
    这个问题可能是因为我刚才在烧写芯片把BDM给拔造成的。
    但我想芯片应该没那么脆弱吧,好像又像是芯片被锁了,但是解不了锁
    发表于 2010-8-30 16:18:54 | 显示全部楼层
    RE:BDM无法编程
    别的板子能用还是不能用?
     楼主| 发表于 2010-8-30 16:51:24 | 显示全部楼层
    回复:BDM无法编程
    是啊~
    我想请问一下您,使用DEBUGER里面UNSECURE里面的参数该怎么设置?
    发表于 2010-8-30 17:06:01 | 显示全部楼层
    RE:BDM无法编程
    1、确认换了别的板子,BDM能够正常使用,确定BDM没有问题
    2、确定是你使用板子MCU出现了问题
    3、如果你使用的MCU出现了问题,建议恢复出厂设置,如果真的只是MCU出问题,我看看手册,有没有办法恢复。
    GMT+8, 2026-4-2 02:10 , Processed in 0.110791 second(s), 31 queries , Redis On.
