查看: 4061|回复: 2
关于MC9S08LG32, reset pin as bi-directional reset and LCD pins as open-drain GPIO
发表于 2010-11-24 23:19:47 | 显示全部楼层 |阅读模式
参考手册里的这句段话是什么意思?
      When using reset  pin as bi-directional reset and LCD pins as open-drain GPIO,the internal pullups are not disable when these pins are used in output mode.This can cause some current leakage through the pads if zero is driven.This is also true for stop 2 mode.
    发表于 2010-11-25 11:13:01 | 显示全部楼层
    RE:关于MC9S08LG32, reset pin as bi-directional reset and LCD pins as open-drain G
    使用外部复位引脚复位,LCD引脚是开漏状态,内部上来不能关闭,并且GPIO引脚继续保持输出模式。
    复位以后,可能LCD上还会继续显示原先的内容。
    发表于 2010-12-12 22:19:11 | 显示全部楼层
    当复位引脚作为双向复位功能使,或当LCD管脚作为开漏GPIO, 这些引脚作为输出时有内部上拉. 在输出低的情况下, 这会引起漏电流(注: 因为有电流从电源通过上拉电阻到低电平). 在stop2模式下, 也同样成立.
    GMT+8, 2026-4-10 01:20 , Processed in 0.078810 second(s), 22 queries , Redis On.
