查看: 3173|回复: 1
[其他] s8sg8串口问题
发表于 2010-12-22 00:22:33 | 显示全部楼层 |阅读模式
(求助)s8sg8串口问题 s8sg8串口问题,内部晶振,总线频率4mhz,波特率4800,中断接收,进不了中断,为何 程序如下,请指点,谢谢。#define scibandrate  4800void SCI_INIT(void);void DELAY(int x);void MCU_INIT(void);uchar BUFF1=0x66;void main(void) {//ICSTRM=0Xaf;    EnableInterrupts; /* enable interrupts */    /* include your code here */                  MCU_INIT();      SCI_INIT();    for(;;) {        //__RESET_WATCHDOG(); /* feeds the dog */        while(SCIS1_TDRE) {            SCIS1_TDRE=0;            DELAY(100);                SCID=BUFF1;         }/**/     }}     void MCU_INIT(void){    ICSC1=0x04;    ICSC2=0x40;    ICSTRM=0xa8;    SOPT1=0x42;    SOPT2=0x00;}void SCI_INIT(void) {   // ICSC1=0X00;    //ICSC2_HGO=1;    //ICSC2_EREFS=1;    //ICSC2_ERCLKEN=1;    //while(ICSSC_OSCINIT==0);    SCIBD =4000000/16/scibandrate; //设置波特率    SCIC1=0x00;    SCIC2=0x2C;//使能接受中断}void DELAY(int x){    int i,j;    for(i=0;i
我知道答案 目前已有0人回答
    发表于 2010-12-23 16:04:52 | 显示全部楼层
    RE:s8sg8串口问题
    interrupt 15 void SCI_RE(void) { while(SCIS1_RDRF) BUFF1=SCID; SCIS1_RDRF=0; }
    改成:
    interrupt 17 void SCI_RE(void) { while(SCIS1_RDRF) BUFF1=SCID; SCIS1_RDRF=0; }
    GMT+8, 2025-10-27 19:25 , Processed in 0.109280 second(s), 22 queries , MemCache On.
