查看: 3176|回复: 2
关于9s08dz48的mscan的问题~~请大家指点啊
发表于 2011-1-11 10:44:30 | 显示全部楼层 |阅读模式
 在进行仿真时,出现这句话MSCAN Error - Transmit Buffer #0 not initialized,使程序不能跑起来,请问这是什么原因?
unsigned char cantxdbuffer[8];
void CANTxD(unsigned long id, unsigned short datalen, void *buf) {
    unsigned char *dbuffer = (unsigned char *)buf;
    unsigned short i2 = 0;
    if(!CANTFLG){
        return;
    if (datalen > 8) {
        return;
    for (i2 = 0 ; i2 < datalen ; i2 ++) {
        cantxdbuffer[i2] = dbuffer[i2];
    CANTBSEL = 0x01;/* CAN0TFLG; */
    //sel = CANTBSEL;
    CANTIDR0 = (unsigned char)((id >> 24) & 0xFF);
    CANTIDR1 = (unsigned char)((id >> 16) & 0xFF);
    CANTIDR2 = (unsigned char)((id >> 8) & 0xFF);
    CANTIDR3 = (unsigned char)(id & 0xFF);
    CANTDSR0 = cantxdbuffer[0];
    CANTDSR1 = cantxdbuffer[1];
    CANTDSR2 = cantxdbuffer[2];
    CANTDSR3 = cantxdbuffer[3];
    CANTDSR4 = cantxdbuffer[4];
    CANTDSR5 = cantxdbuffer[5];
    CANTDSR6 = cantxdbuffer[6];
    CANTDSR7 = cantxdbuffer[7];
    CANTDLR = (unsigned char)datalen;
    CANTFLG = CANTBSEL;
    for ( i2 = 0 ; i2 < 2048 ; i2 ++ ) {
        if ( ( CANTFLG & 0X01) == 1 ) {
            break;
    发表于 2011-1-11 11:19:14 | 显示全部楼层
    RE:关于9s08dz48的mscan的问题~~请大家指点啊
    没有初始化buffer0
     楼主| 发表于 2011-2-24 14:02:38 | 显示全部楼层
    回复:关于9s08dz48的mscan的问题~~请大家指点啊
    回复第 2 楼 安 于2011-01-11 03:19:14发表:
    没有初始化buffer0
    我有一个问题不明白,就是那个通过实参传进来的指针buf赋值给dbuffer指针,然后在程序中就调用数组dbuffer[ ],这样可以吗?
    GMT+8, 2025-11-22 19:20 , Processed in 0.084406 second(s), 21 queries , Redis On.
