查看: 4702|回复: 9
[MAC] SMAC
发表于 2011-2-23 17:18:18 | 显示全部楼层 |阅读模式
      大家好,请问有哪位知道HCS08单片机光盘中自带的用于zigbee无线通信的SMAC软件如何使用?谢谢
我知道答案 目前已有8人回答
    发表于 2011-2-23 22:15:29 | 显示全部楼层
    RE:SMAC
    我没有见过这个软件,你可以上传上来让我看看吗?
     楼主| 发表于 2011-2-24 09:07:39 | 显示全部楼层
    回复:SMAC
    不符合附件的类型传不上去,安装后里边有device_header,driver,MC13192_hw_config等的头文件和 C source file,其中MC13192_hw_config.c source file具体内容如下:
    * transceiver hardware interconnections. Initialization is accomplished by the
     * MC13192_hw_config.c source file.
     * $Author: flr005 $
     * $Date: 2006/02/23 16:24:36 $
     * $Name:  $
    #include "device_header.h"
    #include "pub_def.h"
    #include "drivers.h"
    #include "MC13192_hw_config.h"
    /* Globals */
    extern UINT8 gu8RTxMode;
     * MC13192Init: Initialize the MC13192 register map.
     * Parameters: None
     * Return : None
    void MC13192Init(void)
    /* Please refer to document MC13192RM for hidden register initialization */
        SPIDrvWrite(0x11,0x80FF);   /* Eliminate Unlock Conditions due to L01 */
        SPIDrvWrite(0x1B,0x8000);   /* Disable TC1. */
        SPIDrvWrite(0x1D,0x8000);   /* Disable TC2. */
        SPIDrvWrite(0x1F,0x8000);   /* Disable TC3. */
        SPIDrvWrite(0x21,0x8000);   /* Disable TC4. */
        SPIDrvWrite(0x07,0x0E00);   /* Enable CLKo in Doze */
        SPIDrvWrite(0x0C,0x0300);   /* IRQ pull-up disable. */
        SPIDrvRead(0x25);           /* Sets the reset indicator bit */
        SPIDrvWrite(0x04,0xA08D);   /* New cal value */
        SPIDrvWrite(0x08,0xFFF7);   /* Preferred injection */
        SPIDrvWrite(0x05,0x8351);   /* Acoma, TC1, Doze, ATTN masks, LO1, CRC */
        SPIDrvWrite(0x06,0x4720);   /* CCA, TX, RX, energy detect */
        /* Read the status register to clear any undesired IRQs. */
        SPIDrvRead(0x24);           /* Clear the status register, if set */
        gu8RTxMode = IDLE_MODE;     /* Update global to reflect MC13192 status */
    发表于 2011-2-24 10:23:56 | 显示全部楼层
    RE:SMAC
    你做成RAR的格式就能上传了。
    这个是原程序,需要你烧写到开发板中使用的。
     楼主| 发表于 2011-2-24 10:59:42 | 显示全部楼层
    回复:SMAC
    请问,如何烧写呢?
    SMAC4.1c Source Code Packet.rar
    2.86 MB, 下载次数: 5
    发表于 2011-2-24 21:32:06 | 显示全部楼层
    RE:SMAC
    你可以使用BDM或者PE来烧写的。不知道你的板子都带了那些东西。
     楼主| 发表于 2011-2-25 09:44:06 | 显示全部楼层
    回复:SMAC
    两块13192 SARD板,一个P&E,剩下就是线缆。用P&E烧写就是指在线下载吧?
    发表于 2011-2-26 08:56:47 | 显示全部楼层
    RE:SMAC
    是的。PE是仿真器,就像JLINK一样。
     楼主| 发表于 2011-2-26 22:28:32 | 显示全部楼层
    回复:SMAC
    那我这个zigbee无线通信该如何下手呢?谢谢
    发表于 2011-2-28 08:36:14 | 显示全部楼层
    RE:SMAC
    先看资料,了解他是如何通信的。
    GMT+8, 2025-10-28 01:45 , Processed in 0.109076 second(s), 31 queries , MemCache On.
