查看: 3123|回复: 3
[其他] QG4 FLASH
发表于 2011-3-25 17:30:56 | 显示全部楼层 |阅读模式
以下的是对FLASH操作,当我单步执行时,能正确读写FLASH,当我全速度执行时,PC却走到了0X100出去,为什么呢?在unsigned char ROM_PGM(unsigned int address,unsigned char data,unsigned char cmd) 有一个指针,    (*((volatile unsigned char *)(address))) = data;//write to somewhere in flash  ,当我删了,程序可执行,问题就出在这里,请高手指点帮我讲解下,谢谢
#define FLASH_CMD_BYTEPROG 0x20
#define FLASH_CMD_PAGEERASE 0x40
void  pagehandle()
  flash_page_erase(0xf800);
  flash_byte_prog(0xf800,0x55);
  flash_byte_prog(0xf801,0xaa);
  flash_byte_prog(0xf802,0xa5);
  tab[0] = flash_byte_read(0xf800);
  tab[1] = flash_byte_read(0xf801);
  tab[2] = flash_byte_read(0xf802);
    __RESET_WATCHDOG();
    DisableInterrupts;
    if (FSTAT&0x10)
      {                     //Check to see if FACCERR is set
        FSTAT = FSTAT|0x10;            //write a 1 to FACCERR to clear
    FCMD = cmd;
    FSTAT = FSTAT|0x80;                //Put FCBEF at 1.
    asm  nop
    asm  nop
    asm  nop
    asm  nop
    if(FSTAT&0x30)
     {                     //check to see if FACCERR or FVIOL are set
      EnableInterrupts;
      return (0xFF);                         //if so, error.
     while ((FSTAT&0x40)==0);
     EnableInterrupts;
     return(0);
void flash_byte_prog(unsigned int addr, unsigned char data)
  //FCMD = 0X20;
  ROM_PGM(addr,data,FLASH_CMD_BYTEPROG);
static  void flash_page_erase(unsigned int addr)
  //FCMD = 0X40;
  ROM_PGM(addr,0,FLASH_CMD_PAGEERASE);
static unsigned char flash_byte_read(unsigned int addr)
  return *(unsigned char *)addr;
我知道答案 目前已有2人回答
发表于 2011-3-25 22:32:22 | 显示全部楼层
RE:QG4 FLASH
做读/写FLASH操作时,FLASH时钟要调低,大约在175KHZ左右.
 楼主| 发表于 2011-3-26 09:00:03 | 显示全部楼层
RE:QG4 FLASH
我用的是166.7K,不是时钟问题
    发表于 2011-3-26 11:01:45 | 显示全部楼层
    RE:QG4 FLASH
    要先写命令,后写入数据。如果先写入数据就进入死循环了。所以你不能操作。
    GMT+8, 2026-4-17 10:01 , Processed in 0.097830 second(s), 24 queries , Redis On.
