查看: 5430|回复: 5
[求助] 这么个好玩意怎么能买到???国内有代理吗??
发表于 2011-3-28 00:42:07 | 显示全部楼层 |阅读模式
 http://www.pemicro.com/products/product_viewDetails.cfm?product_id=15320137
is product covers the following Part Numbers: USB-ML-UNIVERSAL
Click image for details
            P&E’s USB Multilink Universal is an all-in-one development interface which allows a PC access to the Background Debug Mode (BDM) or JTAG interface on Freescale HCS08, HC(S)12(X), RS08, ColdFire V1/+V1, ColdFire V2-4*, Qorivva 55xx/56xx, and Kinetis ARM microcontrollers. It connects between a USB port on a Windows machine and the standard debug connector on the target. The Freescale microcontrollers are supported via the multiple headers located on the USB Multilink Universal. The product photos to the left of this page show how the headers can be accessed by simply flipping open the plastic case. Ribbon cables suitable for a variety of architectures are included.
            *NOTE: The USB Multilink Universal includes a ribbon cable for connecting to ColdFire V2-4 targets, however certain devices - such as the MCF5272 & MCF5206(E) - require a separate adapter cable (not included) to synchronize the communications signals.
            By using the USB Multilink Universal, the user can take advantage of the background debug mode to halt normal processor execution and use a PC to control the processor. The user can then directly control the target’s execution, read/write registers and memory values, debug code on the processor, and program internal or external FLASH memory devices.
我知道答案 目前已有4人回答
    发表于 2011-3-28 09:37:35 | 显示全部楼层
    RE:这么个好玩意怎么能买到???国内有代理吗??
    龙丘有,你可以去咨询一下。
    https://item.taobao.com/item.htm?id=9258436737
    发表于 2011-3-29 20:33:47 | 显示全部楼层
    好东西啊!可惜已经有仿真器了
    发表于 2011-3-30 23:51:11 | 显示全部楼层
    多少钱??普通的pe,1000,这个这么强大不会像ti的xds560一样,5000多块吧。
    发表于 2011-5-26 00:24:50 | 显示全部楼层
    与我联系,我可以提供。seastarzheng@sina.com
    发表于 2011-6-8 14:21:45 | 显示全部楼层
    现在fsl官方网站上已经可以订购:
    https://www.freescale.co
    m/webapp/sps/site/prod_summary.jsp?code=UMultilink&fsrch=1&sr=2
    119美刀
    GMT+8, 2025-10-25 01:03 , Processed in 0.105649 second(s), 26 queries , MemCache On.
