查看: 3112|回复: 1
调试出现的问题,急,在线等高手解决,谢谢
发表于 2011-3-28 14:09:43 | 显示全部楼层 |阅读模式
我用的是MC9S08AC32芯片。为什么在调试时,运行以后,执行HALT后,寄存器没有数据,再次运行后再挂起,才有数据,另外脱机后,上电不能正常工作。
初始化程序如下:
void MCU_init(void)
  /* Common initialization of the write once registers */
  /* SOPT: COPE=0,COPT=1,STOPE=0 */
  SOPT = 0x53;
  SPMSC1 = 0x1C;
  SPMSC2 = 0x00;
  SMCLK &= (unsigned char)~0x17;
  ICGC1 = 0x4E;
  ICGC2 = 0x72;
  if (*(unsigned char*far)0xFFBE != 0xFF) {
    ICGTRM = *(unsigned char*far)0xFFBE;
  while(!ICGS1_LOCK) {
  /* PTFPE: PTFPE3=0,PTFPE2=0,PTFPE1=0,PTFPE0=1 */
  PTFPE = (PTFPE & (unsigned char)~0x0E) | (unsigned char)0x01;
   PTASE = 0x3F;
   PTBSE = 0x00;
    PTCSE &= (unsigned char)~0x7F;
    PTDSE = 0x00;
   PTESE = 0x00;
  PTFSE = 0x2D;
  PTGSE = (PTGSE & (unsigned char)~0x06) | (unsigned char)0x79;
    PTADS = 0x3F;
    PTBDS = 0x00;
  PTCDS = 0x00;
  PTDDS = 0x00;
  PTEDS = 0x00;
  PTFDS = 0x2F;
   PTGDS = 0x78;
  PTADD = 0x37;
    PTDDD &= (unsigned char)~0xFC;
    PTFPE |= (unsigned char)0x10;
    PTFDD = (PTFDD & (unsigned char)~0x90) | (unsigned char)0x20;
    PTGDD = (PTGDD & (unsigned char)~0x07) | (unsigned char)0x78;
  (void)(TPM1C2SC == 0);
   TPM1C2SC = 0x64;
  TPM1C2V = 0xFAU;
  (void)(TPM1C3SC == 0);
  TPM1C3SC = 0x64;
  TPM1C3V = 0x01F4U;
  (void)(TPM1C4SC == 0);
  TPM1C4SC = 0x64;
  TPM1C4V = 0x01F4U;
  (void)(TPM1C5SC == 0);
  TPM1C5SC = 0x24;
  TPM1C5V = 0x01F4U;
  TPM1SC = 0x00;
  TPM1MOD = 0x01F4U;
  (void)(TPM1SC == 0);
  TPM1SC = 0x49;
   APCTL1 = 0xFF;
  APCTL2 = 0x03;
  ADC1CFG = 0x00;
   ADC1CV = 0x00U;
   ADC1SC2 = 0x00;
   ADC1SC1 = 0x1F;
    TPM2SC = 0x00;
  TPM2MOD = 0x0270U;
  (void)(TPM2SC == 0);
    TPM2SC = 0x48;
  asm CLI;
} /*MCU_init*/
 楼主| 发表于 2011-3-28 16:09:07 | 显示全部楼层
回复:调试出现的问题,急,在线等高手解决,谢谢
谢谢,安老师。我在看看时钟。
GMT+8, 2025-12-10 23:02 , Processed in 0.084429 second(s), 21 queries , Redis On.
