查看: 2479|回复: 3
[其他] 调试出现的问题,急,在线等高手解决,谢谢
发表于 2011-3-28 14:24:35 | 显示全部楼层 |阅读模式
                                    我用的是MC9S08AC32芯片。为什么在调试时,运行以后,执行HALT后,寄存器没有数据,再次运行后再挂起,才有数据,另外脱机后,上电不能正常工作。
            初始化程序如下:
            void MCU_init(void)
              /* Common initialization of the write once registers */
              /* SOPT: COPE=0,COPT=1,STOPE=0 */
              SOPT = 0x53;
              SPMSC1 = 0x1C;
              SPMSC2 = 0x00;
              SMCLK &= (unsigned char)~0x17;
              ICGC1 = 0x4E;
              ICGC2 = 0x72;
              if (*(unsigned char*far)0xFFBE != 0xFF) {
                ICGTRM = *(unsigned char*far)0xFFBE;
              while(!ICGS1_LOCK) {
              /* PTFPE: PTFPE3=0,PTFPE2=0,PTFPE1=0,PTFPE0=1 */
              PTFPE = (PTFPE & (unsigned char)~0x0E) | (unsigned char)0x01;
               PTASE = 0x3F;
               PTBSE = 0x00;
                PTCSE &= (unsigned char)~0x7F;
                PTDSE = 0x00;
               PTESE = 0x00;
              PTFSE = 0x2D;
              PTGSE = (PTGSE & (unsigned char)~0x06) | (unsigned char)0x79;
                PTADS = 0x3F;
                PTBDS = 0x00;
              PTCDS = 0x00;
              PTDDS = 0x00;
              PTEDS = 0x00;
              PTFDS = 0x2F;
               PTGDS = 0x78;
              PTADD = 0x37;
                PTDDD &= (unsigned char)~0xFC;
                PTFPE |= (unsigned char)0x10;
                PTFDD = (PTFDD & (unsigned char)~0x90) | (unsigned char)0x20;
                PTGDD = (PTGDD & (unsigned char)~0x07) | (unsigned char)0x78;
              (void)(TPM1C2SC == 0);
               TPM1C2SC = 0x64;
              TPM1C2V = 0xFAU;
              (void)(TPM1C3SC == 0);
              TPM1C3SC = 0x64;
              TPM1C3V = 0x01F4U;
              (void)(TPM1C4SC == 0);
              TPM1C4SC = 0x64;
              TPM1C4V = 0x01F4U;
              (void)(TPM1C5SC == 0);
              TPM1C5SC = 0x24;
              TPM1C5V = 0x01F4U;
              TPM1SC = 0x00;
              TPM1MOD = 0x01F4U;
              (void)(TPM1SC == 0);
              TPM1SC = 0x49;
               APCTL1 = 0xFF;
              APCTL2 = 0x03;
              ADC1CFG = 0x00;
               ADC1CV = 0x00U;
               ADC1SC2 = 0x00;
               ADC1SC1 = 0x1F;
                TPM2SC = 0x00;
              TPM2MOD = 0x0270U;
              (void)(TPM2SC == 0);
                TPM2SC = 0x48;
              asm CLI;
            } /*MCU_init*/
我知道答案 目前已有2人回答
    发表于 2011-3-28 15:24:53 | 显示全部楼层
    RE:调试出现的问题,急,在线等高手解决,谢谢
    系统时钟配置错误。最高20Mhz的总线时钟,你配置到了36Mhz。
     楼主| 发表于 2011-3-28 16:11:24 | 显示全部楼层
    回复:调试出现的问题,急,在线等高手解决,谢谢
    我发现是TPM1定时出现拉错误,时钟帮我修改一下,谢谢
    发表于 2011-3-28 17:30:33 | 显示全部楼层
    你可以使用PE来配置时钟。这样就不会出错误了。TIM也可以使用时钟PE来配置。
    GMT+8, 2025-10-28 12:13 , Processed in 0.089673 second(s), 24 queries , MemCache On.
