在线时间0 小时
UID109929
注册时间2009-2-17
NXP金币0
 该用户从未签到 新手上路
	积分35
最后登录1970-1-1 |
| 新人,请教,MQX中如果判断网络是通的还是断的,我的程序运行时,网线拔了很长时间才能判断出网络断了。我程序的初始化代码如下: if( RTCS_OK != RTCS_create() )
 InUartPrint( "\nRTCS Create Error!\n", strlen( "\nRTCS Create Error!\n" ) );
 _mqx_exit( -1 );
 if( ENET_OK!= ENET_initialize( BSP_DEFAULT_ENET_DEVICE, m_enetaddress, 0, &m_hEnet ) )
 InUartPrint( "\nEnet Initial Error!\n", strlen( "\nEnet Initial Error!\n" ) );
 _mqx_exit( -1 );
 if( RTCS_OK != RTCS_if_add( m_hEnet, RTCS_IF_ENET, &m_hRtcsIf ) )
 InUartPrint( "\nRtcs If Add Error!\n", strlen( "\nRtcs If Add Error!\n" ) );
 _mqx_exit( -1 );
 if( RTCS_OK != RTCS_if_bind( m_hRtcsIf, m_ui32IpAddress, m_ui32Mask ) )
 InUartPrint( "\nRtcs If Bind Error!\n", strlen( "\nRtcs If Bind Error!\n" ) );
 _mqx_exit( -1 );
 if( RTCS_OK != RTCS_gate_add( m_ui32GateWay, INADDR_ANY, INADDR_ANY ) )
 InUartPrint( "\nRtcs Gate Add Error!\n", strlen( "\nRtcs Gate Add Error!\n" ) );
 _mqx_exit( -1 );
 InUartPrint( "Waiting Fec Cable Plug In...\n", strlen( "Waiting Fec Cable Plug In...\n" ) );
 while( !ENET_link_status( m_hEnet ) );   这里面网线插不插都能直接过去,郁闷。。。
 InUartPrint( "Fec Cable connected!\n", strlen( "Fec Cable connected!\n" ) );
 m_hSockServer = socket( PF_INET, SOCK_STREAM, 0 );
 if( m_hSockServer == RTCS_SOCKET_ERROR )
 InUartPrint( "\nServer Socket Create Error!\n", strlen( "\nServer Socket Create Error!\n" ) );
 _mqx_exit( -1 );
 m_ui32Temp = 3000; 这里面的值怎么改都没用
 if( RTCS_OK != setsockopt( m_hSockServer, SOL_TCP, OPT_CONNECT_TIMEOUT, &m_ui32Temp, sizeof( m_ui32Temp ) ) )
 InUartPrint( "\nSet Socket Opt OPT_CONNECT_TIMEOUT Error!\n", strlen( "\nSet Socket Opt OPT_CONNECT_TIMEOUT Error!\n" ) );
 m_ui32Temp = 0; 这里面的值怎么改也没用
 if( RTCS_OK != setsockopt( m_hSockServer, SOL_TCP, OPT_KEEPALIVE, &m_ui32Temp, sizeof( m_ui32Temp ) ) )
 InUartPrint( "\nSet Socket Opt OPT_KEEPALIVE Error!\n", strlen( "\nSet Socket Opt OPT_KEEPALIVE Error!\n" ) );
 再往下就是开读、写、工作线程,读线程在网线断很久后才能返回错误。
 m_ui32RecvDataCount = recv( m_ptrFecData->m_hSockClient, m_ptrFecData->m_ptrReadTempBuffer, sizeof( PcFecDataStyle ), 0 );
 if( m_ui32RecvDataCount == RTCS_ERROR )
 就是这儿,网络断了很久才能进到这里面,不明白为什么?
 break;
 网络芯片用的是ksz8041nl
 请版主指教,非常感谢!
