查看: 5852|回复: 3
关于hcs08程序编译出错问题
发表于 2011-5-20 11:51:39 | 显示全部楼层 |阅读模式
V6.3Code Warrior 编译C源文件时出现下面的错误提示该怎么修改:
error : C1019: incompatible type to previous declaration (found ``,expected `TPM_Enable_Flags`)
出错的源代码如下,请高手指点迷津,谢谢!
#pragma data_seg MY_ZEROPAGE
typedef union
  byte TPM_Byte;
  struct
    byte Flag_Second                   :1;         /* flag of 1 second counter finish Bit  */
    byte Flag_Minute                   :1;         /* flag of 1 minute counter finish Bit  */
    byte Ozone_Ring_Enable             :1;
    byte Count_Down_Enable             :1;
    byte Low_Press_Enable              :1;
    byte High_State_Enable             :1;
    byte byte6                         :1;
    byte byte7                         :1;
  } Bits;
}TPM_Enable_Flags;
volatile TPM_Enable_Flags _Time_Flags;
#define TPM_FLAG_Byte_Operation         _Time_Flags.TPM_Byte
#define SEC_Counter_Finish_Flag         _Time_Flags.Bits.Flag_Second
#define MIN_Counter_Finish_Flag         _Time_Flags.Bits.Flag_Minute
#define FLAG_Ozone_Ring_Enable          _Time_Flags.Bits.Ozone_Ring_Enable
#define FLAG_Count_Down_Enable          _Time_Flags.Bits.Count_Down_Enable
#define FLAG_Low_Press_Enable           _Time_Flags.Bits.Low_Press_Enable
#define FLAG_High_State_Enable          _Time_Flags.Bits.High_State_Enable
#define FLAG_One_Minute_Enable          _Time_Flags.Bits.byte6           //1·ÖÖÓ¼ÆÊ±ÔÊÐí±ê־λ
#define Bit_Counter_Finish_Flag7        _Time_Flags.Bits.byte7
发表于 2011-5-20 18:19:35 | 显示全部楼层
RE:关于hcs08程序编译出错问题
TPM_Enable_Flags 换个名字就好了
    发表于 2011-5-20 21:36:39 | 显示全部楼层
    RE:关于hcs08程序编译出错问题
    _Time_Flags 不能这么定义,开始必须使用字母
     楼主| 发表于 2011-5-21 12:00:57 | 显示全部楼层
    回复:关于hcs08程序编译出错问题
    哎呀,问题解决了,是 位域的 数据类型用错了, 只能用 int      unsigned   signed 三种类型中的一种,居然是自己解决的问题
    GMT+8, 2026-4-10 00:28 , Processed in 0.088851 second(s), 23 queries , Redis On.
