查看: 4673|回复: 1
[求助] keil kinetis 问题
发表于 2011-7-20 16:34:23 | 显示全部楼层 |阅读模式
e2448:FMC: Flash prefetch could result in incorrect read data
Errata type: Errata
Description: A flash read access could result in incorrect data being returned if the SIM_DIV1 register is
written to change the divide value for the flash clock and a flash prefetch occurs during the
clock change sequence.
Workaround:1. Create a function in the SRAM that performs the following operations:
a. Save value of FMC_PFAPR[23:16].
b. Disable flash prefetching by writing 8’hff to FMC_PFAPR[23:16].
c. Change value of flash divider SIM_DIV1[OUTDIV4].
d. Wait for clock change.
e. Re-enable flash prefetching by restoring the saved FMC_PFACR[23:16] value.
f. Return from the function.
2. Call the SRAM code function.
3. Once the function returns from its SRAM execution, the flash clock divider has been safely
altered.
/* SIM_CLKDIV1: OUTDIV1=0,OUTDIV2=0,OUTDIV3=1,OUTDIV4=1,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0 */
  SIM->CLKDIV1 = (uint32_t)0x00110000u; /* Update system prescalers */
keil中没有到ram里去分频啊,而是直接在flash里分频了
我知道答案 目前已有0人回答
发表于 2011-7-27 16:17:59 | 显示全部楼层
RE:keil kinetis 问题
如果你不改flash clock divider的话,就当没看到这个errata。
另外,如果你要改变MCG mode的话,请在切换到PLL模式或FLL模式之前更改clock divider这个寄存器。
如果一定要改flash clock divider,若KEIL wizard新建的工程没有把更改代码放到ram中运行,请自行更改代码。
GMT+8, 2025-10-25 03:44 , Processed in 0.088253 second(s), 22 queries , MemCache On.
