查看: 11890|回复: 9
[其他] 我的CCSProtocolPlugin:CCS:USB open failure
发表于 2011-11-2 08:52:36 | 显示全部楼层 |阅读模式
CCSProtocolPlugin:CCS:USB open failure   现在又出现显示了,我打了技术支持,还有别人,没问明白,应调整哪里,谢谢各位朋友了
我知道答案 目前已有8人回答
发表于 2011-11-2 09:13:30 | 显示全部楼层
RE:我的CCSProtocolPlugin:CCS:USB open failure
你检查你的链接了,接口使劲拧一下,不行的话就这样:
(A) In windows XP/2000, the parallel port dialog checkbox entitled
"Enable Legacy Plug and Play" should be checked. This setting is
located in the Control Panel-->System-->Hardware->Device
Manager-&gtorts-&gtrinter Port (LPTX) dialog.
(B) Here are the steps to modify the parallel port registry key appropriately:
1. save the winxp1.reg file to your hard drive
2. make sure you are logged in as the system administrator
3. run the winxp1.reg file (by double clicking on it)
4. A question will be displayed "Are you sure you want to add the  information in c:\winxp1.reg to the registry?"
5. Click the Yes button
6. A message will display "Information in c:\winxp1.reg has been successfully entered into the registry."
7. restart your computer to apply the new changes
(C)The Command Converter/Server attempts to get it's parallel port information from the BIOS of your computer. Sometimes this process won't work, for instance if you are using and add-on card, or if your BIOS is simply incompatible. In these instances the port address must be set manually.
1) Run CW and try to debug to your DSP board connected to the PCI parallel port. It will fail as expected.
2) Right click on the CCS icon in your SysTray and select Show CCS Console.
3) at the prompt, type:
delete all
...then press [ENTER], then type:
config cc lpt:0x
发表于 2011-11-2 09:14:25 | 显示全部楼层
如果硬件没问题的话,上面的应该可以解决你的问题
 楼主| 发表于 2011-11-2 13:09:19 | 显示全部楼层
硬件没问题winxp1.reg文件我没有找到
发表于 2012-6-30 10:26:38 | 显示全部楼层
发表于 2012-6-30 18:47:09 | 显示全部楼层
回复:我的CCSProtocolPlugin:CCS:USB open failure
回复第 2 楼 于2011-11-02 09:13:30发表:
delete all
config cc lpt:0xFor instance, if you're card is at ECF8, type:
config cc lpt:0xECF8 [ENTER]
If you don't know the address of your parallel port, you can find out in Window's hardware settings. On Windows 2000, go to:
Start->Settings->Control Panel->System->Hardware(tab)->Device
Start->Settings->Manager-&gtorts
You will see your parallel port here. Double-click on it and go to the Resources tab. The first Input/Output address listed is the address to give CCS. Mine is 0378. It may be different for your setup.
Try to debug. It should now work.
If it does, execute this final command to save your current CCS settings:
config save [ENTER]
This will write out the settings to a config file, which will be
automatically loaded by CCS for future debugging sessions.
If using the address in hex does not work, please try the address in decimal. The syntax is slightly different:
Instead of
config cc lpt:0x378
use
config cc lpt:888
里边的winxp1.reg在哪里找不到啊?
发表于 2014-1-13 15:01:56 | 显示全部楼层
回复第 6 楼 于2012-06-30 18:47:09发表:
delete all
config save [ENTER]
Instead of
config cc lpt:0x378
use
config cc lpt:888
我附上winxp1.reg,但是这个不是问题的解决办法。
winxp1.zip
299 Bytes, 下载次数: 21
发表于 2014-1-13 15:02:57 | 显示全部楼层
你使用的哪种仿真器?是USBTAP,还是其他?CodeWarrior 版本?
发表于 2014-2-20 15:50:01 | 显示全部楼层
回复第 8 楼 于2014-01-13 15:02:57发表:
8楼,你好,我也是遇到同样的问题,一点击“debug”就弹出“CCSProtocolPlugin:CCS:USB open failure”。开发板板是MC56F8006DEMO(REV.B),仿真器是USB TAP,Codewarrior DSC56800E_8.3,实验例程“MC56F8006DEMO_LED_LAB”。求解决办法,谢谢!
发表于 2014-3-4 11:29:47 | 显示全部楼层
回复第 9 楼 于2014-02-20 15:50:01发表:
请在CodeWarrior 8.3中新建一个工程,选择File Menu-> New -> DSP56800x EABI Stationery -> MC56F8006DEMO -> Simple C and Assembly. 然后在Connection Settings中将连接方式设置成USB Tap,并且将JTAG Clock Speed 配置成500, 然后在桌面右下角的任务栏中将CCS退出, 然后重新开始调试,还是同样的错误么?
如果是的话,请检查USBTAP的驱动是否安装好,你可以发一个设备管理器的截图上来,另外你的操作系统是什么?32位还是64位的?
GMT+8, 2025-9-18 13:14 , Processed in 0.188675 second(s), 31 queries , MemCache On.
