查看: 4265|回复: 5
[其他] MCF52233TCP客户端
发表于 2011-11-23 17:19:48 | 显示全部楼层 |阅读模式
使用MCF52233Demo创建TCP客户端连接,程序如下:(CW10.1)
为何在使用connect链接服务器10.3.0.58的2011端口时,返回RTCSERR_SOCK_INVALID_AF错误呢?
服务器端有个监听的程序一直在工作的呀!
在使用Connect时需要注意哪些,具体流程如何?
请指教一下!
 * TCP_MSG_Task.c
 *  Created on: 2011-11-22
 *      Author: qaby
#include "TCP_MSG_Task.h"
void TCP_MSG_Task(uint_32 initial_data)
 char Table[]="i am on line";
 sockaddr_in laddr, raddr;
 uint_32 sock, listensock;
 int_32 count;
 uint_32 index;
 uint_32 error;
 uint_16 rlen;
 _time_delay(10000);//wait all task is created
 raddr.sin_family=AF_INET;
 raddr.sin_port = 2011;
 raddr.sin_addr.s_addr=INADDR_SERVER;//10.3.0.58
 /* Create a stream socket: */
 sock = socket(PF_INET, SOCK_STREAM, 0);
 if (sock == RTCS_SOCKET_ERROR)
  printf("\nFailed to create the stream socket.");
  _task_block();
 do
  index=connect(sock,&raddr,sizeof(raddr));
  if(index!=RTCS_OK)
   printf("\nFailed to connect server.");
 }while(index!=RTCS_OK);
 while(1)
  /* Send back a quote: */
   count = send(sock, Table, strlen(Table), 0);
   if (count == RTCS_ERROR)
    printf("send() failed with error code\n");
   else
    printf("message sended\n");
  _time_delay(1000);
我知道答案 目前已有4人回答
发表于 2011-11-23 21:12:56 | 显示全部楼层
回复:MCF52233TCP客户端
RTCS初始化了没?
 楼主| 发表于 2011-11-23 21:54:17 | 显示全部楼层
RE:MCF52233TCP客户端
如下:
main_task中有初始化,查看了下TCP中的错误好像是,TCP buffer有问题
但又不知道如何修改。
#include "main.h"
const SHELL_COMMAND_STRUCT Shell_commands[] = {
   /* RTCS commands */
   { "arpadd",    Shell_arpadd },
   { "arpdel",    Shell_arpdel },
   { "arpdisp",   Shell_arpdisp },
   { "exit",      Shell_exit },
   { "gate",      Shell_gate },
   { "gethbn",    Shell_get_host_by_name },
   { "getrt",     Shell_getroute },
   { "help",      Shell_help },
   { "ipconfig",  Shell_ipconfig },
   { "netstat",   Shell_netstat },
#if RTCSCFG_ENABLE_ICMP
   { "ping",      Shell_ping },
#endif
   { "telnet",    Shell_Telnet_client },
   { "telnetd",   Shell_Telnetd },
   { "walkrt",    Shell_walkroute },
   { "?",         Shell_command_list },
   { NULL,        NULL },
const SHELL_COMMAND_STRUCT Telnetd_shell_commands[] = {
   /* RTCS commands */
   { "pause",     Shell_pause },
#endif
   { NULL,        NULL }
TASK_TEMPLATE_STRUCT MQX_template_list[] =
/*  Task number, Entry point, Stack, Pri, String, Auto? */
   {MAIN_TASK,   Main_task,   2000,  9,   "main", MQX_AUTO_START_TASK},
   {TCPMSG_TASK,  TCP_MSG_Task,   2000,  7,   "Message",MQX_AUTO_START_TASK},
   {0,           0,           0,     0,   0,      0,                 }
/*TASK*-----------------------------------------------------------------
* Function Name  : Main_task
* Comments       :
*    This task initializes MFS and starts SHELL.
*END------------------------------------------------------------------*/
void Main_task(uint_32 initial_data)
   /* RTCS init */
    rtcs_init();
   * START YOUR CODING HERE
   for (;;)
      /* Run the shell */
      Shell(Shell_commands, NULL);
      printf("Shell exited, restarting...\n");
 楼主| 发表于 2011-11-24 10:13:56 | 显示全部楼层
RE:MCF52233TCP客户端
Failed to connect server  with error code 1612
 楼主| 发表于 2011-11-24 11:13:49 | 显示全部楼层
RE:MCF52233TCP客户端
问题解决了,RTCS手册上说Receive-Buffer Size和Send-Buffer Size默认值是4380,可实际创建的Socket为-1,需要使用setsockopt重新设置就好了。
    发表于 2011-11-24 22:26:37 | 显示全部楼层
    RE:MCF52233TCP客户端
    楼主自学能力强,希望多和论坛的网友交流交流,我在这里谢谢楼主了。
    GMT+8, 2025-10-27 23:22 , Processed in 0.080958 second(s), 26 queries , MemCache On.
