查看: 6380|回复: 10
[其他] CAN
发表于 2011-12-16 10:07:06 | 显示全部楼层 |阅读模式
谁给一个MPC5604Pcan的例子,不要发官方那个,那个调不通
我知道答案 目前已有9人回答
    发表于 2011-12-16 15:42:33 | 显示全部楼层
    RE:CAN
    你好,请问一下怎么调试不通过?出现了什么问题?
     楼主| 发表于 2011-12-16 15:58:49 | 显示全部楼层
    RE:CAN
    直接贴代码吧,就是发送的时候用CANoe接收不到信号,也就是报文没有发出来。
    void initPIT(void)
      PIT.PITMCR.R = 0x00000001;
      PIT.PITMCR.B.MDIS = 1;
      PIT.CH[0].LDVAL.R = 64000000;
      PIT.CH[0].TCTRL.R = 0x03;
      INTC_InstallINTCInterruptHandler(PITISR,59,2);
      PIT.PITMCR.B.MDIS = 0;
      INTC.CPR.B.PRI = 0;
    void initModesAndClks(void) {
    ME.MER.R = 0x0000001D;                // Enable DRUN, RUN0, SAFE, RESET Modes
    CGM.CMU_0_CSR.R = 0x000000004;
    // 8 MHz XTAL: Set PLL0 To 64 MHz
    // 0x05400100: 0000 0101 0100 0000 0000 0001 0000 0000
    CGM.FMPLL[0].CR.B.IDF  = 1;
    CGM.FMPLL[0].CR.B.ODF  = 1;
    CGM.FMPLL[0].CR.B.NDIV = 64;
    CGM.FMPLL[0].CR.B.EN_PLL_SW = 1;
    ME.RUN[0].R = 0x001F0074;             // RUN0 Configuration: 16MHz IRCON, OSC0ON, PLL0ON, SysClk = PLL0
    ME.RUNPC[1].R = 0x00000010;           // Peripheral Configuration 1 Settings: Only Run In RUN0 Mode
    ME.PCTL[92].R = 0x01;
    ME.PCTL[16].R = 0x01;           /* MPC56xxB/P/S FlexCAN0:  select ME.RUNPC[1] */
    ME.PCTL[26].R = 0x01;           /* MPC56xxP SafetyPort: select ME.RUNPC[1] */
    ME.MCTL.R = 0x40005AF0;
    ME.MCTL.R = 0x4000A50F;
    while(ME.GS.B.S_MTRANS) {}
    while(ME.GS.B.S_CURRENTMODE != 4) {}
    void disableWatchdog(void) {
      SWT.SR.R = 0x0000c520;     /* Write keys to clear soft lock bit */
      SWT.SR.R = 0x0000d928;
      SWT.CR.R = 0x8000010A;     /* Clear watchdog enable (WEN) */
    void initCAN_0 (void) {
    uint8_t   i;
    CAN_0.MCR.R = 0x5000001F;       /* Put in Freeze Mode & enable all 32 msg bufs */
    /* Use 1 of the next 2 lines depending on crystal frequency: */
    CAN_0.CR.R = 0x04DB0006;        /* Configure for 8MHz OSC, 100KHz bit time */
    CAN_0.RXGMASK.R = 0xFFFFFFFF;
    for (i=0; i
     楼主| 发表于 2011-12-17 16:50:26 | 显示全部楼层
    RE:CAN
    麻烦安版主有时间帮忙看看啊
     楼主| 发表于 2011-12-19 09:12:58 | 显示全部楼层
    RE:CAN
    再顶一下,希望斑竹帮帮忙啊
    发表于 2012-3-17 18:32:22 | 显示全部楼层
    回复:CAN
    这个必须顶一下,我的也是同样问题啊!
     楼主| 发表于 2012-3-20 11:02:16 | 显示全部楼层
    RE:CAN
    这个我调通了。。
    发表于 2012-3-22 10:56:24 | 显示全部楼层
    回复:CAN
    回复第 7 楼 于2012-03-20 03:02:16发表:
    这个我调通了。。
    楼主,调试通了,分享点经验呗,我都还不知道TRK的那个demo板上有什么特殊的跳线帽么?还没有调通
     楼主| 发表于 2012-3-22 16:38:25 | 显示全部楼层
    RE:CAN
    官方的没有配SBC,你配一下就行了,还有就是用33905供电,所以要把那个供电的跳线接上
    发表于 2012-4-7 09:35:07 | 显示全部楼层
    RE:CAN
    ,小不点,能不能具体点啊,遇到同样的问题,纠结中~~~
    GMT+8, 2026-4-16 15:31 , Processed in 0.107990 second(s), 30 queries , Redis On.
