查看: 7438|回复: 7
[MPC] 如何在官网上下载MPC5604的代码初始化例子
发表于 2011-12-18 21:00:58 | 显示全部楼层 |阅读模式
  RT   老弟我最近为这事郁闷了找半天没找到,我想写一个脉冲捕捉的初始化,没找到例程,不知中断函数如何写了。
安版主:我怎么找到中断向量表呢  MOC5604
我知道答案 目前已有6人回答
发表于 2011-12-19 08:47:59 | 显示全部楼层
回复:如何在官网上下载MPC5604的代码初始化例子
为什么要用中断啊?我就直接用上升沿计数,然后每固定周期读COUNT寄存器的值,不是直接就可以算出来了么?
    发表于 2011-12-19 09:15:39 | 显示全部楼层
    RE:如何在官网上下载MPC5604的代码初始化例子
    中断向量列表在手册的中断一章有介绍。例程下载地址:根据你的需求可以选择下载。
    https://www.freescale.co
    m/webapp/sps/site/prod_summary.jsp?code=MPC560xB&fpsp=1&tab=Documentation_Tab
     楼主| 发表于 2011-12-19 21:06:10 | 显示全部楼层
    回复第 3 楼 于2011-12-19 01:15:39发表:
    在这个下载的不是PDF RPM吗   我需要的代码初始化啊
     楼主| 发表于 2011-12-19 21:08:05 | 显示全部楼层
    回复第 2 楼 于2011-12-19 00:47:59发表:
    我用脉冲捕捉是因为我需要在上升沿的时候去读数
    发表于 2011-12-20 14:12:51 | 显示全部楼层
    对应的手册里面有一些简单的例子,你也可以参考一下。
     楼主| 发表于 2011-12-20 14:44:22 | 显示全部楼层
    回复第 6 楼 于2011-12-20 06:12:51发表:
    手册里没有例子啊 就一个说明啊
    In SAIC mode (MODE[0:6] = 0000010), when a triggering event occurs on the input pin, the value on the
    selected time base is captured into register A2. The FLAG bit is set along with the capture event to indicate
    that an input capture has occurred. Register EMIOSA[n] returns the value of register A2. As soon as the
    SAIC mode is entered coming out from GPIO mode the channel is ready to capture events. The events are
    captured as soon as they occur thus reading register A always returns the value of the latest captured event.
    Subsequent captures are enabled with no need of further reads from EMIOSA[n] register. The FLAG is set
    at any time a new event is captured.
    The input capture is triggered by a rising, falling or either edges in the input pin, as configured by EDPOL
    and EDSEL bits in EMIOSC[n] register.
    发表于 2012-4-23 22:11:38 | 显示全部楼层
     sese
    GMT+8, 2026-4-16 07:18 , Processed in 0.103195 second(s), 28 queries , Redis On.
