查看: 9402|回复: 5
[S12] 求9S12HY64的D-FLASH读写程序
发表于 2011-12-19 11:14:15 | 显示全部楼层 |阅读模式
求9S12HY64的D-FLASH读写程序.我写了一个,但是总是被它的地址弄晕,现在擦除0x4400地址,然后写入数据,能擦能写,可是D-FLASH的空间是0x10440开始啊,晕.求助各位帮忙
我知道答案 目前已有4人回答
    发表于 2011-12-19 15:20:38 | 显示全部楼层
    回复:求9S12HY64的D-FLASH读写程序
    是0x4400地址,详看下图:
     楼主| 发表于 2012-2-3 12:09:04 | 显示全部楼层
    DFLASH        = READ_ONLY   0x010400 TO 0x0113FF;
    DFlash_Erase(0x4400);
    DFlash_Write(0x4400,Buffer);
    执行后写入数据的地址为0x00400,而非0x010400.为什么?
     楼主| 发表于 2012-2-3 12:11:40 | 显示全部楼层
    int DFlash_Write(word ADDR16,unsigned int Buffer[])
      if(FCLKDIV_FDIVLD ==0)
        FCLKDIV_FDIV = 0x07;
      FSTAT_ACCERR = 1;
       delay(100);
    FSTAT_FPVIOL = 1;
      FCCOBIX_CCOBIX = 0x00;
      FCCOBHI = 0x11;//Program D-Flash Command
      FCCOBLO = 0x00;//0x00;
        delayl(100);
      FCCOBIX_CCOBIX = 0x01;
      FCCOB = ADDR16;
      FCCOBIX_CCOBIX = 0x02;  //word0
      FCCOB = Buffer[0];
      FCCOBIX_CCOBIX = 0x03;  //word1
      FCCOB = Buffer[1];
      FCCOBIX_CCOBIX = 0x04;  //word2
      FCCOB = Buffer[2];
      FCCOBIX_CCOBIX = 0x05;  //word3
      FCCOB = Buffer[3];
       delayl(100);
      FSTAT_CCIF = 1;//launch command
      while (FSTAT_CCIF == 0);
      if (FSTAT_ACCERR || FSTAT_FPVIOL || FSTAT_MGSTAT)
        FSTAT_ACCERR = 1;
        FSTAT_FPVIOL = 1;
        return -1;
       return 1;
    发表于 2012-5-26 08:55:47 | 显示全部楼层
    大哥怎样设定DFLASH位的呀 还是仪器自动识别的呢
    发表于 2012-6-14 14:34:08 | 显示全部楼层
     我也晕了,搞不定啊
    GMT+8, 2026-4-16 01:29 , Processed in 0.109790 second(s), 29 queries , Redis On.
