查看: 4389|回复: 3
[求助] i.mx27接WM9712
发表于 2012-2-8 09:55:02 | 显示全部楼层 |阅读模式
各位大侠,我用i.mx27的SSI1接WM9712芯片,AC97接口,驱动能够运行,SSI1的4个IO口用IO方式能够控制,但做为SSI信号口后,一直没有动静,AUDMUX我配置如下,
 mxc_audmux_v1_configure_port(MX27_AUDMUX_HPCR1_SSI0,
   MXC_AUDMUX_V1_PCR_SYN |
   MXC_AUDMUX_V1_PCR_TFSDIR |
   MXC_AUDMUX_V1_PCR_TCLKDIR |
   //MXC_AUDMUX_V1_PCR_RFSDIR |
   //MXC_AUDMUX_V1_PCR_RCLKDIR |
   MXC_AUDMUX_V1_PCR_TFCSEL(MX27_AUDMUX_PPCR1_SSI_PINS_1) |
   //MXC_AUDMUX_V1_PCR_RFCSEL(MX27_AUDMUX_PPCR1_SSI_PINS_1) |
   MXC_AUDMUX_V1_PCR_RXDSEL(MX27_AUDMUX_PPCR1_SSI_PINS_1)
 mxc_audmux_v1_configure_port(MX27_AUDMUX_PPCR1_SSI_PINS_1,
      MXC_AUDMUX_V1_PCR_SYN | /* 4wire mode */
      //MXC_AUDMUX_V1_PCR_TCLKDIR |
      //MXC_AUDMUX_V1_PCR_TFCSEL(MX27_AUDMUX_HPCR1_SSI0) |
      MXC_AUDMUX_V1_PCR_RXDSEL(MX27_AUDMUX_HPCR1_SSI0)
按照i.mx21的Programming Audio Applications in the i.MX21 Application Note, Rev. 1文档配置了很多次,都一直没反应,而且i.mx27的文档中SSI1,SSI2的寄存器地址都为0x1001,1000,但BSP里面SSI1的地址为0x1001,0000,SSI2的地址为0x1001,1000,这两种地址我都设置过,但依然IO口没输出,神马回事,有哪位大侠了解??
我知道答案 目前已有2人回答
    发表于 2012-2-8 15:34:35 | 显示全部楼层
    RE:i.mx27接WM9712
    SSI没有输出是吗?这个时候需要把SSI引脚配置为输出,然后再控制就可以了。还有一种可能是SPI模块没有开启。
     楼主| 发表于 2012-2-8 16:33:16 | 显示全部楼层
    RE:i.mx27接WM9712
    太感谢管理员了,我现在用的linux 3.0.4内核,用的phyCore pca100那个板子的代码,我已经改过的,你看看,
            /* SSI1 */
            PC20_PF_SSI1_FS  | GPIO_PUEN,
            PC21_PF_SSI1_RXD | GPIO_PUEN,
            PC22_PF_SSI1_TXD | GPIO_PUEN,
            PC23_PF_SSI1_CLK | GPIO_PUEN,
    #define PC20_PF_SSI1_FS                (GPIO_PORTC | GPIO_PF | GPIO_OUT | 20)
    #define PC21_PF_SSI1_RXD        (GPIO_PORTC | GPIO_PF | GPIO_IN | 21)
    #define PC22_PF_SSI1_TXD        (GPIO_PORTC | GPIO_PF | GPIO_OUT | 22)
    #define PC23_PF_SSI1_CLK        (GPIO_PORTC | GPIO_PF | GPIO_OUT | 23)
     楼主| 发表于 2012-2-8 16:41:55 | 显示全部楼层
    RE:i.mx27接WM9712
    但是还是没输出,我把AUDMUX设置后,也读回来看了,
    [    0.106599] mxc_audmux_v1_configure_port: org=0xcc007000, redback=0xcc007000----zengfh
    [    0.106645] mxc_audmux_v1_configure_port: org=0x1000, redback=0x1000----zengfh
    AUDMUX没有时钟控制,SSI有,我直接在初始化的时候就
            clk_enable(&ssi1_clk);了
    GMT+8, 2025-12-1 22:26 , Processed in 0.083674 second(s), 24 queries , Redis On.
