查看: 29231|回复: 73
翻译接龙第二期:Using the Touch Screen Controller
发表于 2008-5-14 11:44:03 | 显示全部楼层 |阅读模式
有奖翻译第二期同第一期(https://www.nxpic.org.cn/bbs/index_Article_21623.html),我们会选出3名优秀译者,给予积分以及购物券奖励。请大家认领积极参与
获奖名单公布:
chriscbn 、霜筠、moonstar1214
后续内容见15楼
Using the Touch Screen Controller on the MCF5227x
1、The need for graphical user interfaces in industrial and consumer applications is steadily increasing. For instance, LCDs are now on appliances such as washers,dryers, refrigerators, and stoves, allowing enhanced human control. Security and HVAC control systems are other examples of applications that require advanced graphical display interfaces to enable human control of the various system functions. Along with the LCD, the use of touch screens is also increasing. To address this need, Freescale is introducing a family of cost-effective and highly integrated ColdFire microprocessors that feature an integrated LCD controller and an integrated touch screen controller module.
2、The MCF5227x family of ColdFire microprocessors includes an analog signal processor (ASP) module. The module includes an analog-to-digital converter (ADC) and digital logic to automatically manage the I/O switching and timing required for interfacing to a touch screen. As a touch screen controller, it supports resistive 4-wire, 5-wire, 7-wire, and 8-wire touch screens. When the ASP module is not used as a touch screen controller, it can be used as a multi-channel 12-bit general-purpose ADC. Also, if there are channels that aren’t used for touch screen functionality, they can be used as general-purpose ADC inputs.
3、This application note describes how resistive touch screens work and how the ASP module can be used to interface to different types of touch screens. To simplify discussion, this document discusses using the ASP module as a touch screen only. There is no discussion of using the ASP module as a general-purpose ADC or using a mix of touch screen and ADC channels.
 楼主| 发表于 2008-5-14 11:47:08 | 显示全部楼层
RE:翻译接龙第二期:Using the Touch Screen Controller
1 Touch Screen Overview
4、There are a number of touch screen technologies available today. Three of the most common touch screen technologies are resistive, capacitive, and surface acoustic wave (SAW). Of these, resistive touch screens are generally the least expensive but also provide good reliability, durability, and accuracy.
5、Resistive touch screens need only pressure to get a reading. This means that any type of input device can be used to create the touch — finger, stylus, gloved finger, etc. By comparison, capacitive touch screens require a conductive touch device, so they must be used with a finger touch or a special conductive stylus.Surface acoustic wave touch screens rely on the absorption of sound waves to detect a touch so a finger or gloved finger will work. However, a small, hard stylus doesn’t work, so SAW touch screens usually require a special soft-tipped stylus.
6、Resistive touch screens do have some disadvantages. One of the primary disadvantages is that the touch screen uses multiple layers, and the coatings on the layers can reduce light transmission and create some color distortion of the underlying LCD image. The optical quality for resistive touch screens can vary from manufacturer to manufacturer. For applications where resolution and brightness of the display are important, it might be worth the extra investment to purchase a resistive touch screen with better light transmission characteristics, or even move to a different type of touch screen technology.
7、The ASP module on the MCF5227x supports resistive type touch screens. Modes of operation are available for the commonly used interfaces — 4-wire, 5-wire, 7-wire, and 8-wire. The following sections discuss how the different types of resistive touch screens work, along with their advantages and disadvantages
未完待续!
发表于 2008-5-14 12:04:05 | 显示全部楼层
又有翻译活动了,偶来参加下,请各位大侠指教。
目前,对于图像用户界面的需求正在工业和消费应用领域不断增加。举例来说,除去传统的电视显示,LCD已经开始在洗衣机、烘干机、冰箱以及炉具上出现,以此来增加用户管控效果。安全和HVAC控制系统的应用是另外一个事例,它需要更加先进的图形显示界面来提升用户控制的各种系统功能。与LCD的大规模应用一样,触摸屏的使用也在逐渐风靡。为了满足目前的巨大需求,飞思卡尔公司推出了集成LCD控制器和触摸屏控制模块的低成本、高集成度ColdFire微处理器系列。
嘿嘿
发表于 2008-5-14 12:27:14 | 显示全部楼层
回复:翻译接龙第二期:Using the Touch Screen Controller
[quote]原帖由windrain于2008-05-14 12:04发表:
嘿嘿,借下
发表于 2008-5-14 13:07:26 | 显示全部楼层
CoidFire微处理器MCF5227x系列包括一个模拟信号处理器模块(ASP) 。这个模块由一个模拟—数字信号转换器(ADC)以及自动开关和定时进行输入/输出的数字逻辑组成,后者是触摸屏界面所必需的。作为一个触摸屏控制器,它支持四线、五线、七线和八线电阻式触摸屏。当这个模拟信号处理器不被用作触摸屏控制器时,它可以被用作多通道十二位通用模数转换器。而且如果有通道不被用作触摸屏功能,他们也可以用来作为通用模数转换器输入设备。
说明书描述了电阻式触摸屏是怎样工作的以及模拟信号处理器模块怎样被用来连接不同型号的触摸屏。为了简化讨论,这个文件只探讨作为触摸屏使用的模拟信号处理器模块。不涉及对使用通用模数转换器和同时使用触摸屏以及模数转换器通道的讨论。
发表于 2008-5-14 16:55:55 | 显示全部楼层
现在有许多的触摸屏技术,三种最常见的触摸屏技术是电阻式,电容式和表面声波触摸屏。其中,电容式触摸屏是相对而言最便宜的而且提供了可靠,持续和准确的服务。
电阻式触摸屏只需要压力就能阅读信息,这意味着任何可输入的设备都可以用来触摸--手指,指示笔
带着手套的手指,等等,相比较而言,电容式触摸屏需要有传导性的设施,因此他们必须配合着手指的触摸或者特殊的有传导性的指示笔。表面声波触摸屏依靠对声波的吸收来对触摸做出反应,所以带不带手套的手指都可以对它产生作用。不过,细小的,坚硬的指示笔并不起作用,所以表面声波触摸屏(SAW)通常需要配备一种特殊的软头的指示笔。
 楼主| 发表于 2008-5-14 18:38:35 | 显示全部楼层
moonstar1214, 有段字好小,调调
发表于 2008-5-15 22:46:23 | 显示全部楼层
    电阻式触摸屏存在一些先天不足。其中,最为主要的是采用了多层复合的结构,这样覆于各层上的薄膜就会降低光的透射率并造成触摸屏之下的LCD图像的色彩失真。电阻式触摸屏的光学性能是因制造厂商的不同而异的。对分辨率和亮度比较在意的兄弟,您花上点儿钱再买上一块电阻式触摸屏(盖在你那没触摸的LCD上)其实是比较划算的:你会因此获得更好的光透射率。或者干脆你就别用电阻式的了,换别的吧。
发表于 2008-5-16 15:35:16 | 显示全部楼层
原帖由霜筠于2008-05-14 13:07发表:
嘿嘿,好像一般产品名称都不直接翻译。CoidFire微处理器,翻译成冷火微处理器感觉怪怪滴
发表于 2008-5-16 15:47:15 | 显示全部楼层
还有这句话偶觉得应该这样翻译啦:欢迎拍砖
ColdFire微处理器MCF5227x系列包括一个模拟信号处理器(ASP)模块,该模块则是由一个模数转换器(ADC)以及触摸屏界面所需时钟、I/O转换自动控制数字逻辑模块组成。作为一个触摸屏控制器,它支持4线、5线、7线和8线电阻式触摸屏。当不需要模拟信号处理器模块担任触摸屏控制器时,它可以被用作多通道12位通用模数转换器。而且,在支持触摸屏功能时,如果有些通道没被使用,他还能充当通用模数转换器输入设备。
GMT+8, 2025-11-3 13:16 , Processed in 0.087959 second(s), 28 queries , MemCache On.
