查看: 3799|回复: 1
[S12] XS128 SCI 中断接收
发表于 2012-3-4 15:16:59 | 显示全部楼层 |阅读模式
本人用GSM模块与XS通过SCI通讯,XS发送正常,中断接收不对。将GSM模块回复的信息发送到PC机上,显示正确。用PC给XS发信息,XS回复也是正确的》》》蛋疼,求大神
void Clock_set(void)
    CLKSEL=0X00;
    PLLCTL_PLLON=1;
    SYNR = 0x44;
    REFDV = 0x41;
    while(!(CRGFLG_LOCK==1));
    POSTDIV=0x00;
    CLKSEL_PLLSEL=1;
void SCI_Init(void)
  SCI0BDH=0x01;
  SCI0BDL=0x04;
  SCI0CR1=0x64;
  SCI0CR2=0x2c;
  SCI1BDH=0x01;
  SCI1BDL=0x04;
  SCI0CR1=0x64;
  SCI1CR2=0x2c;
uchar Receive1(void)
  while(!SCI1SR1_RDRF);
  SCI1SR1_RDRF=1;
  return SCI1DRL;
#pragma CODE_SEG NON_BANKED
void interrupt 21 SCI1_re(void)
  if(Rx
我知道答案 目前已有0人回答
    发表于 2012-3-5 10:59:16 | 显示全部楼层
    RE:XS128 SCI 中断接收
    return SCI1DRL;
    SCI1SR1_RDRF这个自动清除,你再试试。
    GMT+8, 2026-4-16 01:53 , Processed in 0.079236 second(s), 23 queries , Redis On.
