查看: 3186|回复: 1
[其他] 遇到问题:C5300:Limitation code size 1483>1024 bytes
发表于 2012-3-10 10:20:58 | 显示全部楼层 |阅读模式
我用的是MC9S08DZ60
编译之后出现这个问题,找到错误代码如下
Description
You have a limited version of the compiler or reached the limitation specified in the license file. The actual demo limitation is 1024 bytes of code for 8/16bit targets and 3KByte for 32bit targets (without a license file). Depending on the license configuration, the code size limit may be specified in the license file too.
Tips
Check if you have enough licenses if you are using a floating license configuration. Check for the correct location of the license file. Get a license for a full version of the compiler, or for a code size upgrade.
找同学帮忙说是CodeWarrior这个软件的试用期过了,下了个新的,还是不行,谁能帮我看看这是怎么回事啊
编的程序我附在附件中了,跪求高手帮忙!!!
在线等!!!
我知道答案 目前已有0人回答
Project_5.rar
108.44 KB, 下载次数: 1, 下载积分: 威望 1
    无聊
    2021-11-8 23:15
  • 签到天数: 154 天
    发表于 2012-5-14 20:49:24 | 显示全部楼层
    RE:遇到问题:C5300:Limitation code size 1483>1024 bytes
    评估版式有代码量限制啦, 要另外想办法咯, V6.3 在freescale网站少有64K的license 下载
    GMT+8, 2026-4-16 03:02 , Processed in 0.088334 second(s), 25 queries , Redis On.
