查看: 2685|回复: 1
[其他] 遇到问题:C5300:Limitation code size 1483>1024 bytes
发表于 2012-3-10 10:04:16 | 显示全部楼层 |阅读模式
                                    我用的是MC9S08DZ60
            编译之后出现这个问题,找到错误代码如下
            Description
            You have a limited version of the compiler or reached the limitation specified in the license file. The actual demo limitation is 1024 bytes of code for 8/16bit targets and 3KByte for 32bit targets (without a license file). Depending on the license configuration, the code size limit may be specified in the license file too.
            Tips
            Check if you have enough licenses if you are using a floating license configuration. Check for the correct location of the license file. Get a license for a full version of the compiler, or for a code size upgrade.
            找同学帮忙说是CodeWarrior这个软件的试用期过了,下了个新的,还是不行,谁能帮我看看这是怎么回事啊
            编的程序我附在附件中了,跪求高手帮忙!!!
            在线等!!!
我知道答案 目前已有0人回答
Project_5.rar
108.44 KB, 下载次数: 1, 下载积分: 威望 1
发表于 2012-5-30 00:16:56 | 显示全部楼层
RE:遇到问题:C5300:Limitation code size 1483>1024 bytes
DZ60这么多代码就有限制了,不会吧,现在都64KB免费了啊,下载V6.3的试试
GMT+8, 2026-4-14 02:25 , Processed in 0.084441 second(s), 25 queries , Redis On.
