在线时间0 小时
UID346449
注册时间2012-3-10
NXP金币0
- 25
- 1970-1-1
| 遇到问题:C5300:Limitation code size 1483>1024 bytes | 我用的是MC9S08DZ60
编译之后出现这个问题,找到错误代码如下
Description
You have a limited version of the compiler or reached the limitation specified in the license file. The actual demo limitation is 1024 bytes of code for 8/16bit targets and 3KByte for 32bit targets (without a license file). Depending on the license configuration, the code size limit may be specified in the license file too.
Tips
Check if you have enough licenses if you are using a floating license configuration. Check for the correct location of the license file. Get a license for a full version of the compiler, or for a code size upgrade.
找同学帮忙说是CodeWarrior这个软件的试用期过了,下了个新的,还是不行,谁能帮我看看这是怎么回事啊
编的程序我附在附件中了,跪求高手帮忙!!!
在线等!!!
