查看: 21624|回复: 39
[MPC] 安版主,MPC5604B的FlexCAN官方例程,发不出数据,怎么回事?
发表于 2012-3-17 18:21:21 | 显示全部楼层 |阅读模式
目标板:TRK-MPC5604B
程序代码是官方例程 直接贴出,希望安版主可以指点迷津!
#include "MPC5604B_M27V.h" /* Use proper include file */
uint32_t  RxCODE;              /* Received message buffer code */
uint32_t RxID;                 /* Received message ID */
uint32_t  RxLENGTH;            /* Recieved message number of data bytes */
uint8_t  RxDATA[8];            /* Received message data string*/
uint32_t RxTIMESTAMP;          /* Received message time */
void initModesAndClks(void) {
  ME.MER.R = 0x0000001D;          /* Enable DRUN, RUN0, SAFE, RESET modes */
                                  /* Initialize PLL before turning it on: */
/* Use 1 of the next 2 lines depending on crystal frequency: */
  CGM.FMPLL_CR.R = 0x02400100;    /* 8 MHz xtal: Set PLL0 to 64 MHz */
/*CGM.FMPLL_CR.R = 0x12400100;*/  /* 40 MHz xtal: Set PLL0 to 64 MHz */
  ME.RUN[0].R = 0x001F0074;       /* RUN0 cfg: 16MHzIRCON,OSC0ON,PLL0ON,syclk=PLL */
  ME.RUNPC[1].R = 0x00000010;    /* Peri. Cfg. 1 settings: only run in RUN0 mode */
  ME.PCTL[16].R = 0x01;           /* MPC56xxB/P/S FlexCAN0: select ME.RUNPC[1] */
  ME.PCTL[17].R = 0x01;           /* MPC56xxB/S FlexCAN1:  select ME.RUNPC[1] */
  ME.PCTL[68].R = 0x01;           /* MPC56xxB/S SIUL:  select ME.RUNPC[1] */
                                  /* Mode Transition to enter RUN0 mode: */
  ME.MCTL.R = 0x40005AF0;         /* Enter RUN0 Mode & Key */
  ME.MCTL.R = 0x4000A50F;         /* Enter RUN0 Mode & Inverted Key */
  while (ME.GS.B.S_MTRANS) {}     /* Wait for mode transition to complete */
                                  /* Note: could wait here using timer and/or I_TC IRQ */
  while(ME.GS.B.S_CURRENTMODE != 4) {} /* Verify RUN0 is the current mode */
void initPeriClkGen(void) {
  CGM.SC_DC[1].R = 0x80;     /* MPC56xxB/S: Enable peri set 2 sysclk divided by 1 */
void disableWatchdog(void) {
  SWT.SR.R = 0x0000c520;     /* Write keys to clear soft lock bit */
  SWT.SR.R = 0x0000d928;
  SWT.CR.R = 0x8000010A;     /* Clear watchdog enable (WEN) */
void initCAN_0 (void)
  uint8_t   i;
  CAN_0.MCR.R = 0x5000003F;       /* Put in Freeze Mode & enable all 64 msg bufs */
  CAN_0.CR.R = 0x04DB0006;        /* Configure for 8MHz OSC, 100KHz bit time */
  for (i=0; i
我知道答案 目前已有38人回答
FlexCAN1.rar
121.46 KB, 下载次数: 153, 下载积分: 威望 1
发表于 2012-3-20 11:04:56 | 显示全部楼层
RE:安版主,MPC5604B的FlexCAN官方例程,发不出数据,怎么回事?
这个是要对SBC进行配置的,楼主可以参考一下33904怎么配的
    发表于 2012-3-20 17:13:04 | 显示全部楼层
    真对不住楼主,我对MPC5604B也不熟悉,还是参考例程吧。
     楼主| 发表于 2012-3-22 10:59:02 | 显示全部楼层
    回复:安版主,MPC5604B的FlexCAN官方例程,发不出数据,怎么回事?
    谢谢,版主、小不点的回复,SBC是得配置一下啊!不知道怎么配置啊,调不通,郁闷呢?
    发表于 2012-3-22 16:42:25 | 显示全部楼层
    先把SPI调通了,至少能够写数据读数据吧,调通了再说,这个调不通肯定不行的,我调了很久才整出来
     楼主| 发表于 2012-3-25 13:30:42 | 显示全部楼层
    回复第 5 楼 于2012-03-22 08:42:25发表:
    还是要谢谢您,我没使用MCZ33905S,用的外部接的1040,CAN数据可以正常发送了!
    发表于 2012-8-16 18:07:03 | 显示全部楼层
    同求 我的也是不能收发数据
    发表于 2012-8-31 10:07:07 | 显示全部楼层
    谁有用MPC5646C????
    发表于 2012-9-3 15:46:37 | 显示全部楼层
    有在用MPC5634   必须先通过SPI将MC33905的CAN收发器使能   然后才能进行CAN收发
    DSPI_B.PUSHR.R = 0x000160C0;  //使能MC33905CAN收发
    DSPI_B.PUSHR.R = 0x00012100;  //读取CAN状态   回来的如果是C0说明CAN正常,之后就可以进行正常的CAN收发了
    发表于 2012-9-3 15:48:58 | 显示全部楼层
    回复第 6 楼 于2012-03-25 13:30:42发表:
    MC33905还是很方便使用的  集成度也很高   只是需要SPI进行配置   相应的命令看懂手册以后其实很简单的 建议可以使用下哦
    GMT+8, 2025-10-30 12:10 , Processed in 0.098011 second(s), 31 queries , MemCache On.
