查看: 2839|回复: 1
[其他] 我的mscan调试没成功请教高手,下面我的程序
发表于 2012-5-6 18:55:53 | 显示全部楼层 |阅读模式
#include       /* common defines and macros */
#include "derivative.h"      /* derivative-specific definitions */
 int a[8],W=0,W1;
void setbusclock(void)   //PLL setting
    CLKSEL=0X00;    //disengage PLL to system
    PLLCTL_PLLON=1;   /https://www.nxpic.org.cn/file:///C:/DOCUME~1/lm/LOCALS~1/Temp/@IR3P(8S$C$Z$TY~5I%7BQEPC.gif on PLL
    SYNR=0xc2;
    REFDV=0xc1;          //pllclock=2*osc*(1+SYNR)/(1+REFDV)=64MHz;
    _asm(nop);          //BUS CLOCK=48M
    _asm(nop);
    while(!(CRGFLG_LOCK==1));   //when pll is steady ,then use it;
    CLKSEL_PLLSEL =1;          //engage PLL to system;
void delay(){
long j=6000;
while(j--);
j=6000;
while(j--);
j=6000;
while(j--);
j=6000;
while(j--);
void CANinit(){
 CAN0CTL0_INITRQ=1;
while (!CAN0CTL1&0x01);   // 等待MSCAN进入初始化状态
/CAN0IDAC=0X20;
 CAN0IDMR0=0XFF;
 CAN0IDMR1=0XFF;
 CAN0IDMR2=0XFF;
 CAN0IDMR3=0XFF;
 CAN0IDMR4=0XFF;
 CAN0IDMR5=0XFF;
 CAN0IDMR6=0XFF;
 CAN0IDMR7=0XFF;
 CAN0BTR0=0X40;
 CAN0BTR1=0X3F;
 CAN0CTL1=0X80;
  CAN0CTL0_INITRQ=0;
while(CAN0CTL1&0x01) ;    // 等待MSCAN进入正常运行模式
while(!(CAN0CTL0&0x10));
 CAN0RIER_RXFIE=1;
void CAN0_TX(){
uchar i;
i=CAN0TFLG;
CAN0TBSEL=i;
i=CAN0TBSEL;
CAN0TXIDR1=0X01;
CAN0TXIDR2=0X00;
CAN0TXDSR0=0X01;
CAN0TXDSR1=0X02;
CAN0TXDSR2=0X03;
CAN0TXDSR3=0X04;
CAN0TXDSR4=0X05;
CAN0TXDSR5=0X06;
CAN0TXDSR6=0X07;
CAN0TXDSR7=0X08;
CAN0TXDLR=0X08;
CAN0TFLG=i;
void main(void) {
  /* put your own code here */
 setbusclock();
 CANinit();
EnableInterrupts;
   DDRS=0X00;
  for(;;) {
  if(PTIS_PTIS7==0) {
     CAN0_TX();
    _FEED_COP(); /* feeds the dog */
  } /* loop forever */
  /* please make sure that you never leave main */
 #pragma CODE_SEG __NEAR_SEG NON_BANKED
void interrupt 38 CAN0_RX(void) {
W1=1;
CAN0CTL0_RXFRM=1;
a[0]=CAN0RXDSR0;
delay();
a[1]=CAN0RXDSR1;
delay();
a[2]=CAN0RXDSR2;
delay();
a[3]=CAN0RXDSR3;
delay();
a[4]=CAN0RXDSR4;
delay();
a[5]=CAN0RXDSR5;
delay();
a[6]=CAN0RXDSR6;
delay();
a[7]=CAN0RXDSR7;
CAN0RFLG=0X01;
两个单片机一样的程序,为什么不能通信,请高手帮忙,谢谢
我知道答案 目前已有0人回答
    发表于 2012-5-7 09:23:06 | 显示全部楼层
    RE:我的mscan调试没成功请教高手,下面我的程序
    一个要收,一个要发。还有CAN总线上要加个120欧姆的电阻,测试CAN总线最好的方法是,先用CAN收发器来接收,看看你发的数据和波特率对不对。
    GMT+8, 2026-4-14 00:06 , Processed in 0.088887 second(s), 23 queries , Redis On.
