查看: 3560|回复: 2
[其他] xep100的PRM文件设置提示out of allocation space
发表于 2012-6-15 15:21:32 | 显示全部楼层 |阅读模式
RT,在设置PRM文件时,提示segment的APPLVECT_AREA out of allocation space。有谁能帮我解答一下嘛?
代码如下:
This file is setup to use the HCS12X core only.
If you plan to also use the XGATE in your project, best create a new project with the
'New Project Wizard' (File|New... menu in the CodeWarrior IDE) and choose the appropriate
project parameters.
NAMES END /* CodeWarrior will pass all the needed files to the linker by command line. But
SEGMENTS /* Here all RAM/ROM areas of the device are listed. Used in PLACEMENT below. */
Z_RAM             =READ_WRITE    0x2000 TO 0x20FF;      //RAM     Register
FLASHDRV_AREA     =READ_WRITE    0x2100 TO 0x24FF;      //RAM     Flash driver
RAM               =READ_WRITE    0x2500 TO 0x3EFF;      //RAM     RAM
STK_RAM           =READ_WRITE    0x3F00 TO 0x3FFF;
EEPDATA_AREA      =READ_WRITE    0x0C00 TO 0x0CFF;       //EEPROM
EEPROM            =READ_ONLY     0x0D00 TO 0x0FFF;
APPLVECT_AREA     =READ_ONLY     0xC000 TO 0xC0FF;
ROM_4000          =READ_ONLY     0x4000 TO 0x7FFF;
FBLHEADER_AREA    =READ_ONLY     0xC100 TO 0xC123;
CODE_AREA         =READ_ONLY     0xC124 TO 0xFF0F;
VECT_AREA         =READ_ONLY     0xFF10 TO 0xFFFF;      //Flash   Interrupt Vector Tabl
/* INTVECTS                 =  READ_ONLY    0xFFC0 TO 0xFFFF; Reserved for Interrupt Vecto
END
PLACEMENT /* Here all predefined and user segments are placed into the SEGMENTS defined abo
DEFAULT_RAM                         /* non-zero page variables */
INTO  RAM;
_PRESTART,                          /* startup code */
STARTUP,                            /* startup data structures */
ROM_VAR,                            /* constant variables */
STRINGS,                            /* string literals */
VIRTUAL_TABLE_SEGMENT,              /* C++ virtual table segment */
DEFAULT_ROM, NON_BANKED,
COPY                                /* copy down information: how to initialize variabl
INTO CODE_AREA; /* ,ROM1: To use "ROM1" as well, pa
_DATA_ZEROPAGE,                     /* zero page variables */
MY_ZEROPAGE                         INTO  Z_RAM;
//add by LH 20120306
FLASHDRV            INTO  FLASHDRV_AREA;
EEPDATA             INTO  EEPDATA_AREA;
APPLVECT            INTO  APPLVECT_AREA;
FBLHEADER           INTO  FBLHEADER_AREA;
FBLVECT             INTO  VECT_AREA;
SSTACK                    /* stack pointer here */
INTO  STK_RAM;
END
求指点啊!
我知道答案 目前已有1人回答
    发表于 2012-6-16 10:01:29 | 显示全部楼层
    RE:xep100的PRM文件设置提示out of allocation space
    你看一下,是不是重复定义了.
    发表于 2012-7-1 21:00:58 | 显示全部楼层
    APPLVECT_AREA 放入的东西太多了吧!超了
    GMT+8, 2025-10-30 08:36 , Processed in 0.097170 second(s), 23 queries , MemCache On.
