查看: 3936|回复: 0
主机超级终端启动开发板出错,
发表于 2012-6-23 17:33:39 | 显示全部楼层 |阅读模式
启动开发板的Linux内核,开发板是P2020rdb
md: If you don't use raid, use raid=noautodetect
md: Autodetecting RAID arrays.
md: Scanned 0 and added 0 devices.
md: autorun ...
md: ... autorun DONE.
(运行到这里,出现停顿,接着)
JFFS2 error: (1) jffs2_link_node_ref: Adding new ref ef0e98c0 at (0x005c0000-0x0
05c09ac) not immediately after previous (0x005c0000-0x005c0000)
------------[ cut here ]------------
Kernel BUG at c01c7c98 [verbose debug info unavailable]
Oops: Exception in kernel mode, sig: 5 [#1]
SMP NR_CPUS=2 P2020 RDB
Modules linked in:
NIP: c01c7c98 LR: c01c7c98 CTR: c02c68d8
REGS: ef827b70 TRAP: 0700 Not tainted (2.6.32)
MSR: 00029000  CR: 20442022 XER: 20000000
TASK = ef838000[1] 'swapper' THREAD: ef826000 CPU: 1
GPR00: c01c7c98 ef827c20 ef838000 00000096 00021000 ffffffff c02c73ec 0018a520
GPR08: c0646140 c0605ec8 00000001 00021000 20442022 96828168 0000e002 c04d14a4
GPR16: c056c94c c04d14a4 00000000 ef094020 0001c2f4 c04d1488 c0657988 00000000
GPR24: 00003d0c c04d0cd8 ef020ca0 005c0000 000009ac ef9af400 ef908958 ef0e98c0
NIP [c01c7c98] jffs2_link_node_ref+0x228/0x230
LR [c01c7c98] jffs2_link_node_ref+0x228/0x230
Call Trace:
[ef827c20] [c01c7c98] jffs2_link_node_ref+0x228/0x230 (unreliable)
[ef827c50] [c01e1564] sum_link_node_ref+0x64/0x78
[ef827c70] [c01e1e10] jffs2_sum_scan_sumnode+0x898/0xdd0
[ef827ce0] [c01cfef4] jffs2_scan_medium+0x530/0x1ec8
[ef827d70] [c01d41a0] jffs2_do_mount_fs+0x21c/0x930
[ef827dc0] [c01d65cc] jffs2_do_fill_super+0xb4/0x2a8
[ef827de0] [c01d77e4] jffs2_fill_super+0x104/0x118
[ef827e00] [c0315764] get_sb_mtd_aux+0xa0/0xd4
[ef827e30] [c0315894] get_sb_mtd+0xfc/0x220
[ef827e70] [c01d73b4] jffs2_get_sb+0x1c/0x2c
[ef827e80] [c00b5080] vfs_kern_mount+0x58/0x10c
[ef827ea0] [c00b5184] do_kern_mount+0x40/0x100
[ef827ec0] [c00d0468] do_mount+0x308/0x86c
[ef827f10] [c00d0a7c] sys_mount+0xb0/0xdc
[ef827f40] [c05c7bc0] do_mount_root+0x30/0xc0
[ef827f50] [c05c7eac] mount_block_root+0x118/0x260
[ef827fa0] [c05c8250] prepare_namespace+0x140/0x1dc
[ef827fc0] [c05c7378] kernel_init+0x1d8/0x204
[ef827ff0] [c000ff4c] kernel_thread+0x4c/0x68
Instruction dump:
7f25cb78 80820100 7fe6fb78 812b0004 54e7003a 7d1c3a14 5529003a 7d434a14
3c60c056 38632e34 4cc63182 482eb2a5  48000000 9421fff0 7c0802a6
---[ end trace ca80197675d3400c ]---
Kernel panic - not syncing: Attempted to kill init!
Rebooting in 180 seconds..
然后就不断的重启
GMT+8, 2025-12-10 11:26 , Processed in 0.083826 second(s), 19 queries , Redis On.
