查看: 2774|回复: 1
[其他] 使用Xgate三步法
发表于 2012-7-3 14:32:36 | 显示全部楼层 |阅读模式
一:在main.c中把某个中断事件指向Xgate;
二:在xgate.cxgate中创建中断函数;
三:在xgate.cxgate中设置这个中断的向量表;
以PIT0为例,具体操作如下:
使用mc9s12xdt512芯片和codewarrior4.7
---------------------以下在main.c中------------------------- -- -----
#define SOFTWARETRIGGER0_VEC 0x72 /* vector address= 2 * channel id */
// ①: Config PIT channel 0 interrupt register: define vector number
#define PIT_CH0_VEC           0x7A
static void SetupXGATE(void) {
/* initialize the XGATE vector block and
     set the XGVBR register to its start address */
XGVBR= (unsigned int)(void*__far)(XGATE_VectorTable - XGATE_VECTOR_OFFSET);
/* switch software trigger 0 interrupt to XGATE */
ROUTE_INTERRUPT(SOFTWARETRIGGER0_VEC, 0x81); /* RQST=1 and PRIO=1 */
// ②: Config PIT channel 0 interrupt register
ROUTE_INTERRUPT(PIT_CH0_VEC, 0x81); // RQST=1: route PIT_ch0 to XGATE; PRIO=1: priority = 1
/* enable XGATE mode and interrupts */
XGMCTL= 0xFBC1; /* XGE | XGFRZ | XGIE */
/* force execution of software trigger 0 handler */
XGSWT= 0x0101;
在main(void)中初始化PIT,xgate(codewarrior自动生成)
-------------------以下在xgate.cxgate-------------------------------
加入#include "mc9s12xdt512.h" 头文件
// ⑤: define a digit
unsigned char digit=0;
// ⑥: PIT channel 0 thread on XGATE
interrupt void PIT_CH0_Handler(unsigned int dummy)
{   char asd;
    PITTF |= 0x01;             // wrire 1 to clear the channel 0 time out flag
    asd =digit;
    digit++;
<span lang="EN-US" style="font-size: 10.5pt; color: red; font-family: "Arial Unicode MS"">    PORTB = asd
我知道答案 目前已有0人回答
 楼主| 发表于 2012-7-3 14:33:23 | 显示全部楼层
RE:使用Xgate三步法
目前正在学习xgate,就找到了这些资料,希望大家能提供更多的资料,谢谢了啊!
GMT+8, 2026-4-11 00:15 , Processed in 0.086995 second(s), 23 queries , Redis On.
