查看: 3370|回复: 2
请教S08FL16的编程问题
发表于 2012-7-4 20:12:21 | 显示全部楼层 |阅读模式
FL16编程问题,没办法下载,提示如下:
fl::target -lc "LC for Simple Flash"
fl::target -b 0x80 0x3c0
fl::target -v off -l off
cmdwin::fl::device -d "MC9S08FL16_FLASH" -o "16kx16x1" -a 0xc000 0xffff
cmdwin::fl::erase all
Beginning Operation ...
Performing target initialization ...
Device MC9S08FL16_FLASH is secured
Can't autodetect flash clock divider.
Set FCDIV register manually and use Active Debug Context for run configuration in target task.
Erasing .............
Error: Erase Command Failed. Command timeout.
An invalid preference was passed to the GDI protocol plugin(HC/RS/S12Z GDI Protocol Adapter)
Error: Erase Command Failed.Command timeout.
该如何解除保护呢?在哪个界面?
我用的评估板的BDM口,不是专用BDM,在16位上很好用的,8位BDM能用吗?
    发表于 2012-7-5 14:38:28 | 显示全部楼层
    RE:请教S08FL16的编程问题
    不能,8位的和16位的不通用。需要用8位的BDM。
     楼主| 发表于 2012-7-5 15:58:59 | 显示全部楼层
    回复:请教S08FL16的编程问题
    谢谢了
    GMT+8, 2025-11-22 20:53 , Processed in 0.079987 second(s), 20 queries , Redis On.
