查看: 5500|回复: 3
[已解决] 奇怪的指针问题(已解决)
发表于 2012-7-22 17:02:33 | 显示全部楼层 |阅读模式
 大家好!
最近程序遇到些问题,求解决方法,先谢谢大家了,代码如下
我定义了个结构体, RecvBuffer
          RecvBuffer *pointer;
         int *p;
          pointer = (RecvBuffer *)_mem_alloc_zero(RECV_BUFFER_LENGTH);
         p =NULL;
总是报以下错误:
Error[Pe018]: expected a ")" C:\Documents and Settings\Administrator\桌面\pots_demo\Comm.c 159
Error[Pe513]: a value of type "struct recv_buffer *" cannot be assigned to an entity of type "int *" C:\Documents and Settings\Administrator\桌面\pots_demo\Comm.c 159
不知道为什么 只要定义了pointer = (RecvBuffer *)_mem_alloc_zero(RECV_BUFFER_LENGTH);
之后给任何指针赋值NULL都报错,不赋值NULL就没有问题。
 我在vc6.0验证就没有问题,只是把_mem_alloc_zero换成了malloc,难道是_mem_alloc_zero不能这样吗?
 原因是pointer是关键字 不能用pointer。
我知道答案 目前已有2人回答
 楼主| 发表于 2012-7-22 17:11:16 | 显示全部楼层
RE:关于NULL的问题
我把我的函数几乎删除干净了,就只有定义了,还是这样的错误,求高手解决,谢谢!
 楼主| 发表于 2012-7-22 17:12:21 | 显示全部楼层
RE:关于NULL的问题
补充recv_buffer定义
typedef  struct  recv_buffer
    unsigned int IpAddr;
    unsigned int seqNumber;
    unsigned short frameNumber; /*分片*/
    unsigned short frameTotalNumber;
    unsigned int length; /*报文长度*/
    unsigned char *buffer; /*recvb   mdu*/
    unsigned char ttl;
    unsigned char errorStatus; /*0:no error occurs ;1:some error occurs */
    unsigned short hnodeNumber; /*line list node number */
    unsigned char retry;
    unsigned char attrib;
    struct recv_buffer *hnext; /*相同序列号的指针*/
    struct recv_buffer *hprevious;
    struct recv_buffer *vnext; /*哈希表里面的指针*/
    struct recv_buffer *vprevious;
}RecvBuffer;    /*recvs*/
#define RECV_BUFFER_LENGTH sizeof(RecvBuffer)
 楼主| 发表于 2012-7-22 17:17:55 | 显示全部楼层
RE:关于NULL的问题
GMT+8, 2025-10-25 13:28 , Processed in 0.105423 second(s), 24 queries , MemCache On.
