查看: 4957|回复: 1
[其他] 不能进入DEBUG
发表于 2008-12-18 10:27:06 | 显示全部楼层 |阅读模式
小生最近用SH4作个DD,复位脚的接法,我用的是QG8原厂的DEMO把MCU拔了作为仿真器使用,但只能进入DEBUG模式一次,以后就怎么也进不去了
2:我用QG8装回去,可以把代码烧写到QG8里面,说明仿真器没有损坏
3:我看了GQ8 DEMO的原理图,看见它的RESET脚没有接任何器件,所以我也拆掉了SH4 RESET脚的5.6K 0.1uF,但仍然不能进入DEBUG
4:这个是我的初始化代码
void InitializeSystemClock(void)
  /* SOPT1: COPT=0,STOPE=1,IICPS=0,BKGDPE=1,RSTPE=1 */
  SOPT1 = (unsigned char)0x23;
  /* SPMSC1: LVWF=0,LVWACK=0,LVWIE=0,LVDRE=1,LVDSE=1,LVDE=1,BGBE=0 */
  SPMSC1 = 0x1C;
  /* SPMSC2: LVDV=0,LVWV=0,PPDF=0,PPDACK=0,PPDC=0 */
  SPMSC2 = 0x00;
  ICSTRM = *(unsigned char*far)0xFFAF; /* Initialize ICSTRM register from a non volatile memory */
  ICSSC = *(unsigned char*far)0xFFAE;  /* Initialize ICSSC register from a non volatile memory */
  /* ICSC1: CLKS=0,RDIV=0,IREFS=1,IRCLKEN=0,IREFSTEN=0 8M fbus->4M*/
  ICSC1 = 0x04;//ICSC1 = 0x14; /* Initialization of the ICS control register 1 */
  /* ICSC2: BDIV=01,RANGE=0,HGO=0,LP=0,EREFS=0,ERCLKEN=0,EREFSTEN=0 */
  ICSC2 = 0x40;// /* Initialization of the ICS control register 2 */
  while(!ICSSC_IREFST) {               /* Wait until the source of reference clock is internal clock */
  /* ### Init_COP init code */
  SRS = 0xFF;                          /* Clear WatchDog counter */
//下面是端口的
  /*A口初始化*/
      PTADD = (unsigned char)0xFF;
      PTAPE = (unsigned char)0x00;//禁止A口上拉
      PTASE = (unsigned char)0x00;//不限制A口摆率
      PTADS = (unsigned char)0x0F;
      PTASC = (unsigned char)0x00;
      PTAPS = (unsigned char)0x00;
      PTAES = (unsigned char)0x00;
      PTAD  = (unsigned char)0x00;
      /*B口初始化*/
      PTBDD = (unsigned char)0x06;
      PTBPE = (unsigned char)0x00;//禁止B口上拉
      PTBSE = (unsigned char)0x00;//不限制B口摆率
      PTBDS = (unsigned char)0x00;
      PTBSC = (unsigned char)0x00;
      PTBPS = (unsigned char)0x00;
      PTBES = (unsigned char)0x00;
      PTBD  = (unsigned char)0x00;
      /*C口初始化*/
      PTCDD = (unsigned char)0xFB;//方向口控制
      PTCPE = (unsigned char)0x00;//禁止上拉
      PTCSE = (unsigned char)0x00;//不限制摆率
      PTCDS = (unsigned char)0x00;//禁止强驱动
      //GNGC = (unsigned char)0x00;?
      PTCD  = (unsigned char)0x00;
         R5.6K
RESET ----
         0.1uF
         GND
我知道答案 目前已有0人回答
发表于 2009-1-2 12:08:32 | 显示全部楼层
RE:不能进入DEBUG
我觉得和你的代码没什么关系。有可能是芯片设计上Reset管脚与IO口复用引起的小问题。试试点击debug,出现连接Connect那个窗体后,把DEMO板上的PWR_SEL那个跳线拔下来再插上(断一下电再上电)。再点Connect按扭。
GMT+8, 2025-10-27 14:40 , Processed in 0.091405 second(s), 23 queries , MemCache On.
