查看: 7521|回复: 13
MC9S08JM60 12位AD转换的源代码
发表于 2009-2-17 17:52:47 | 显示全部楼层 |阅读模式
MC9S08JM60 12位AD转换的源代码主题部分 :
 * Copyright (c) 2009, LONGQIU S.&T.
 * LONGQIU Application Note
 * File name   : LQadc.c
 * Project name: JM60 Evaluation code
 * Description : This software is the demo code for JM60 ADC module
 * History     :
 * 2009/01/17  : Initial Development
  龙丘MC9S08jm60多功能USB开发板V1.0
  编写:龙丘
  Designed by Chiu Sir
  E-mail:chiusir@163.com
  软件版本:V1.0
  最后更新:2009年01月18日
  相关信息参考下列地址:
  博客:  http://longqiu.21ic.org
  淘宝店:http://shop36265907.taobao.com
使用说明:
  1.串口9600波特率输出;
  2.LCD显示转换后的电压数据;
  3.LED指示数据显示状态,闪烁:程序正常,否则死机;
  4.12位ADC测试功能,模拟输入用ADP11;
  5.总线配置为24MHz;
  6.整数转字符数据格式转换方法.
#include  /* for EnableInterrupts macro */
#include "derivative.h" /* include peripheral declarations */
#include
#include "LQadc.h"
#include "LQ12864.h"
#include "LQprintp.h"
 * ADC_Init: This function initilizes the ADC module
 * Parameters:      none
 * Subfunctions:    none.
 * Return:          void
void ADC_Init(void)
     ADCCFG = 0x61;     //busclk/2, Div by 8,ADCK = 1.5MHz
                        /*  0b0000000 0
                         *    ||||||| |__ bit0,1: ADICLK : input clock select
                         *    |||||||_|
                         *    ||||||_____ bit2,3: MODE :  Conversion Mode selection
                         *    |||||_|
                         *    ||||______ bit4:    ADLSMP: long sample time configuration
                         *    |||_______ bit5,6 : ADIV:   Clock Divide Select
                         *    ||______|
                         *    |_________ bit7:    ADLPC:  Low power configuration
     ADCSC2 = 0x00;  //
                        /*  0b00000000
                         *    ||||||||__ bit0:
                         *    |||||||___ bit1:
                         *    ||||||____ bit2:
                         *    |||||_____ bit3:
                         *    ||||______ bit4: ACFGT: Compare function greater than enable
                         *    |||_______ bit5: ACFE : Compare enable
                         *    ||________ bit6: ADTRG: Conversion trigger select
                         *    |_________ bit7: ADACT: Convert active
    ADCCFG |= 0x04; //BIT2--3      00:8BIT,01:12BIT,10:102BIT,11:RES
    /*Change the channel, to check the releation between pins and channels */
    APCTL1 = 0x00;  //others I/O Enabled
    APCTL2 = 0x08;  //Enable ADP11 ADC input
 * ADC_Cvt :  start to conversion of one channel
 * input:     channel is the channel number which will do conversion
 * Return : None
word ADC_Cvt12B(unsigned char Channel)
   word AdcResult=0;
   if(Channel
demoADC12.rar
139.92 KB, 下载次数: 205, 下载积分: 威望 1
龙丘MC9S08JM60多功能开发板使用手册V10.rar
1.66 MB, 下载次数: 167, 下载积分: 威望 1
发表于 2009-4-30 09:44:10 | 显示全部楼层
RE:MC9S08JM60 12位AD转换的源代码
谢谢
发表于 2009-7-14 22:15:27 | 显示全部楼层
发表于 2010-1-22 16:05:50 | 显示全部楼层
正在搞这个呢。看看。
发表于 2010-1-27 19:34:08 | 显示全部楼层
给个建议:
虽然很个性且不忘记广告,但是最好不要将所有的文件名上都加一个LQ,呵呵。
 楼主| 发表于 2010-2-24 09:36:54 | 显示全部楼层
回复:MC9S08JM60 12位AD转换的源代码
回复第 5 楼 human1984于2010-01-27 11:34:08发表:
给个建议:
好的,谢谢建议!
发表于 2010-4-7 14:26:17 | 显示全部楼层
顶一下!
发表于 2010-7-2 20:40:40 | 显示全部楼层
谢谢!!!
发表于 2010-7-2 20:42:07 | 显示全部楼层
谢谢!!!
发表于 2010-7-21 12:45:14 | 显示全部楼层
能否发一份JM60开发板的串口程序,感谢楼主
GMT+8, 2025-11-22 15:12 , Processed in 0.109080 second(s), 30 queries , Redis On.
