查看: 3146|回复: 2
[求助] K53 SPI0 TFFF中断程序
    发表于 2012-9-11 13:38:40 | 显示全部楼层 |阅读模式
    我刚做了个用TFFF的中断,从波形上已经看到没什么问题,但是不知道具体细节是不是正确,所以发给大家帮我看看
    //函数头文件
    typedef struct
      uint16_t pcs:6;
      uint16_t res:4;
      uint16_t ctcnt:1;
      uint16_t eoq:1;
      uint16_t ctas:3;
      uint16_t cont:1;
    }CMD_BIT;
    typedef struct
            uint16_t txData;
            CMD_BIT cmd;
    }APP_MASTER_PUSHR;
    typedef union
      uint32_t word;
      APP_MASTER_PUSHR halfWord;
    }PUSHR_FORMAT;
    #define APP_SPI0_SEND_DATA_LEN 128
    #define SPI0_SEND_DATA_LEN_8BIT 1
    #define PCS0_SEL 1
    #define PCS1_SEL 2
    #define PCS2_SEL 4
    #define PCS3_SEL 8
    #define PCS4_SEL 16
    #define PCS5_SEL 32
    #define CLEAR_CTCNT     1
    #define IS_EOQ          1
    #define CTAR0_SEL       0
    #define CTAR1_SEL       1
    #define SPI0_SEND_WITH_DMA      1
    extern void dma1_isr(void);
    extern void appSpi0SendInitial(void);
    extern void spi0MasterSendInitial(uint8_t dmaFlag);
    //源文件
    #include "common.h"
    #include "appSpi.h"
    #include "HAL_eDMA.h"
    const uint8_t appSendDataTable[] =
      0x00,0x01,0x02,0x03,0x04,0x05,0x06,0x07,0x08,0x09,0x0a,0x0b,0x0c,0x0d,0x0e,0x0f,
      0x10,0x11,0x12,0x13,0x14,0x15,0x16,0x17,0x18,0x19,0x1a,0x1b,0x1c,0x1d,0x1e,0x1f,
      0x20,0x21,0x22,0x23,0x24,0x25,0x26,0x27,0x28,0x29,0x2a,0x2b,0x2c,0x2d,0x2e,0x2f,
      0x30,0x31,0x32,0x33,0x34,0x35,0x36,0x37,0x38,0x39,0x3a,0x3b,0x3c,0x3d,0x3e,0x3f,
      0x40,0x41,0x42,0x43,0x44,0x45,0x46,0x47,0x48,0x49,0x4a,0x4b,0x4c,0x4d,0x4e,0x4f,
      0x50,0x51,0x52,0x53,0x54,0x55,0x56,0x57,0x58,0x59,0x5a,0x5b,0x5c,0x5d,0x5e,0x5f,
      0x60,0x61,0x62,0x63,0x64,0x65,0x66,0x67,0x68,0x69,0x6a,0x6b,0x6c,0x6d,0x6e,0x6f,
      0x70,0x71,0x72,0x73,0x74,0x75,0x76,0x77,0x78,0x79,0x7a,0x7b,0x7c,0x7d,0x7e,0x7f
    uint8_t appSendDataCounter = 0;
    uint32_t SPI0_TXFR0_buffer[4];
    PUSHR_FORMAT appSpi0SendData[APP_SPI0_SEND_DATA_LEN];
    void spi0SendDataBufferSet(void)
      uint8_t i;
      for(i=0;i
    我知道答案 目前已有1人回答
    发表于 2012-9-11 15:02:26 | 显示全部楼层
    RE:K53 SPI0 TFFF中断程序
    就安装ISR.H里面的格式填写,可以改变为你写的代码入口函数。
     楼主| 发表于 2012-9-11 15:23:07 | 显示全部楼层
    我现在想用TFFF产生DMA请求,怎么设置?
    我设置了SPI0_RSER的SPI_RSER_TFFF_RE_MASK和SPI_RSER_TFFF_DIRS_MASK,但是就是不能产生DMA请求
    版主有现成的例子给我参考一下吗
    GMT+8, 2025-10-26 00:13 , Processed in 0.165476 second(s), 23 queries , MemCache On.
