查看: 4529|回复: 2
[MQX] 使用KEIL MDK编译MQX不运行
发表于 2012-10-21 15:46:27 | 显示全部楼层 |阅读模式
使用KEIL MDK 编译Freescale MQX 3.8 TWRK20D72M/mqx/examples/gpio 例程,程序似乎在 dispatch.s _pend_svc 处死循环了,有高人指点指点吗?
我知道答案 目前已有1人回答
 楼主| 发表于 2012-10-22 10:17:51 | 显示全部楼层
RE:使用KEIL MDK编译MQX不运行
问题解决了:
库文件编译出错,参考K40开发板程序做如下修改
1         ..\mqx\source\bsp\twrk20d72m\init_flashx.c
  //{ "flexram0", (_mem_size)  BSP_INTERNAL_FLEXRAM_BASE, INTERNAL_FLEXRAM_BASE + BSP_INTERNAL_FLEXRAM_SIZE - 1 },
    { "flexram0", (_mem_size) BSP_INTERNAL_FLEXRAM_BASE, (_mem_size) BSP_INTERNAL_FLEXRAM_BASE + BSP_INTERNAL_FLEXRAM_SIZE - 1 },
2        lib\twrk20d72m.uv4\bsp\twrk20d72m.h
///////#define BSP_INTERNAL_FLEXRAM_BASE           ((pointer)__INTERNAL_FLEXRAM_BASE)
//#define BSP_INTERNAL_FLEXRAM_SIZE           ((_mem_size)__INTERNAL_FLEXRAM_SIZE)
//#define INTERNAL_FLEXRAM_BASE                0x14000000
#define BSP_INTERNAL_FLEXRAM_BASE         0x14000000
#define BSP_INTERNAL_FLEXRAM_SIZE          0x00004000
发表于 2013-5-15 10:04:11 | 显示全部楼层
回复:使用KEIL MDK编译MQX不运行
大哥,您是怎么编译过去的?我的一大堆 INCLUDE文件没被包涵,我加了两个小时都没有加完路径,后来我放弃了!
GMT+8, 2025-10-23 12:14 , Processed in 0.094904 second(s), 23 queries , MemCache On.
