查看: 3816|回复: 12
S08 mc9s08ll36 Banked mode 不能调试
发表于 2012-11-19 12:19:58 | 显示全部楼层 |阅读模式
Prm 文件如下
/* This is a linker parameter file for the mc9s08ll36 */
NAMES END /* CodeWarrior will pass all the needed files to the linker by command line. But here you may add your own files too. */
SEGMENTS /* Here all RAM/ROM areas of the device are listed. Used in PLACEMENT below. */
    Z_RAM                    =  READ_WRITE   0x0060 TO 0x00FF;
    RAM                      =  READ_WRITE   0x0100 TO 0x0FFF;
    /* unbanked FLASH ROM */
    ROM                      =  READ_ONLY    0xC000 TO 0xFFAB;
    ROM1                     =  READ_ONLY    0x5000 TO 0x7FFF;
    ROM2                     =  READ_ONLY    0xFFC0 TO 0xFFD1;
 /* INTVECTS                 =  READ_ONLY    0xFFD2 TO 0xFFFF; Reserved for Interrupt Vectors */
    /* banked FLASH ROM */
    PPAGE_2                  =  READ_ONLY    0x02A000 TO 0x02BFFF;
 /* PPAGE_1                  =  READ_ONLY    0x019000 TO 0x01BFFF; PAGE already contained in segment at 0x5000-0x7FFF */
 /* PPAGE_3                  =  READ_ONLY    0x038000 TO 0x03BFFF; PAGE already contained in segment at 0xC000-0xFFFF */
END
PLACEMENT /* Here all predefined and user segments are placed into the SEGMENTS defined above. */
    DEFAULT_RAM,                        /* non-zero page variables */
                                        INTO  RAM;
    _PRESTART,                          /* startup code */
    STARTUP,                            /* startup data structures */
    ROM_VAR,                            /* constant variables */
    STRINGS,                            /* string literals */
    VIRTUAL_TABLE_SEGMENT,              /* C++ virtual table segment */
    NON_BANKED,                         /* runtime routines which must not be banked */
    DEFAULT_ROM,
    COPY                                /* copy down information: how to initialize variables */
                                        INTO  ROM; /* ,ROM1,ROM2: To use "ROM1,ROM2" as well, pass the option -OnB=b to the compiler */
    PAGED_ROM                           /* routines which can be banked */
                                        INTO  PPAGE_2,ROM1,ROM2;
    _DATA_ZEROPAGE,                     /* zero page variables */
    MY_ZEROPAGE                         INTO  Z_RAM;
END
STACKSIZE 0x80
VECTOR 0 _Startup     /* Reset vector: this is the default entry point for an application. */
main 函数代码如下,目的是希望把main 函数放到 PAGED_ROM中,也就是PPAGE_2       =  READ_ONLY    0x02A000 TO 0x02BFFF; 编译链接都没有问题,可是不能运行,求解
void MCU_init(void); /* Device initialization function declaration */
#pragma CODE_SEG PAGED_ROM
void main(void)
 MCU_init(); /* call Device Initialization */
 InitinalLCD();
 /* include your code here */
 for(;;)
  /* __RESET_WATCHDOG(); by default, COP is disabled with device init. When enabling, also reset the watchdog. */
 } /* loop forever */
 /* please make sure that you never leave main */
#pragma CODE_SEG DEFAULT
在map文件中也看到了main被分配到了0x2A000位置。可是不能够运行,提示:could not set the breakpoint at 0x2A000
发表于 2012-11-19 16:09:52 | 显示全部楼层
RE:S08 mc9s08ll36 Banked mode 不能调试
楼主您好,请把工程配置里面的模式改成中模式试一下。如果是小模式的话,可能会访问不到这段空间。
 楼主| 发表于 2012-11-19 17:40:32 | 显示全部楼层
回复:S08 mc9s08ll36 Banked mode 不能调试
多谢你的建议。
small model 时可以的,也就是不能使用0x02A000 TO 0x02BFFF 这段8K空间,我的意思如果一定要使用这段空间,如何做呢?
发表于 2012-11-20 10:08:36 | 显示全部楼层
改成中模式,才能访问到24位的地址.
 楼主| 发表于 2012-11-20 11:21:08 | 显示全部楼层
在编译器选项中->code generation->memory model选择Banked model memory,并选中了MMU support。IDE CW6.3 ,\问题依旧。
 楼主| 发表于 2012-11-20 11:57:01 | 显示全部楼层
1.使用向导产生项目,选择banded 内存模型,编译,链接,下载都没有问题,可是不能运行。
2.用向导产生项目,选择small 内存模型,在main函数前加上
#pragma CODE_SEG __FAR_SEG PAGED_ROM指示后,编译,链接,下载都没有问题,可是不能运行。
这两种内存模型使用向导生成的Prm有点不同,
还是没有找到问题,同行们给点支持吧!
    发表于 2012-11-21 11:10:54 | 显示全部楼层
    我看了一下手册,LL36不支持扩展FLASH编程。支持的地址是:0x8000-0xBFFF。在手册4.5.2.1 Program Page Register (PPAGE)这里介绍到关于FLASH的使用,楼主可以详细看一下这里的介绍。
     楼主| 发表于 2012-11-23 14:49:26 | 显示全部楼层
    感谢“安”,恍然大悟!
     楼主| 发表于 2012-11-23 15:01:22 | 显示全部楼层
    概念理解了,cpu的14位地址寻址16K空间,ppage的两位寻址16位中的高两位。
    项目改回small memory model,
    可是程序代码还是不能放到ppage—2位置执行,
    如下:
    void main(void)
            MCU_init();
            for(;;)
    本应该下载后,直接run stop at main,可是根本执行不了,烦请再看看
    发表于 2012-11-23 16:00:10 | 显示全部楼层
    这段空间根本就访问不到.我不知道你为什么非要用这段空间.
    GMT+8, 2025-11-22 22:28 , Processed in 0.098406 second(s), 28 queries , Redis On.
